HI i'M LOOKING TO REPLACE A MAIN BD FOR OLEVIA S40-811
HI i'M LOOKING TO REPLACE A MAIN BD FOR OLEVIA 240-811...WOULD YOU KNOW WHERE I CAN PURCHASE THIS?
  • 11,896 Answers
Www.PartStore.com
or
www.shopjimmy.com/olevia
Posted on Sep 30, 2009
HI i have olevia 540-b11, will not come on, no lights, etc
If even the indicator light in the front isn't lit, you might be lucky enough to have something simple such as a blown fuse that is in line with everything.
Normally, if the main power supply fails, a small 'always-on' supply that services the low voltage circuits that are kept alive even when the set is'off,' in wait for a command from your remote, survives. Our Olevia has an 'off' indicator that extinguishes when the set is turned on, don't know if yours has the odd arrangement.
If you open the set (allow overnight with the AC plug pulled) and find no user accessible fuse to replace, you are probably looking at some labor charges for a service call. Without a power-off rest period, you may encounter some nasty voltages inside.
In case it needs something, be advised that Olevia is bankrupt so other than 'commodity' parts common to other sets, you may not get the part you need.
Good luck-
Dec 12, 2009 | Olevia LT42HVi 42 in. LCD Television
When turned on picture fluctuates and emits hig
The high pitched noise is coming from the Tcon board. It is not properly decoding the signal coming form the main board correctly. The only way to fix it is to replace the Tcon board. You might have a hard time coming across the part because Olevia has since gone out of business. Also, usually Tcon boards are not available sepertaly and most manufactures make you purchase the whole LCD panel of which the Tcon is included.
Nov 09, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Made some noises. Turned off/on. Unplug.
You have a bad main logic bd, this is a common problem with the units and your logic bd needs to be replaced or fixed. If insturctions are needed on how to remove the logic bd please let me know i can pot something up for you.
I also can repair or replace your logic bd if needed.
Rory Cardenas
708-597-4222 x240
Sep 17, 2009 | Zebra Z4M Printer
Need code for included blu-ray universal to work with an Olevia TV
if Samsung never included the brand Olevia on there remote, then its not going to work because it was never design to work with that brand. The only way to get around that is to get a learning remote or universal remote that has olevia pre program into the remote.. Olevia did come out with some learning remotes that is able to learn from other remotes.. the model its called Olevia RC-LRN ..
This company called Amergence Technology sells the RC-LRN remote made by Olevia contact them at this toll free number 866-965-3842
Apr 19, 2009 | Samsung BD-P1500 Blu-Ray Player
Kyocera KM-1510
BD steady-state problem • BD steady-state problem is detected. (jam code 98)
BD steady-state problem • The VTC detects a BD error for 800 ms after the polygon motor rotation has been stabilizad.
Poor contact of the connector terminals. Defective LSU. Defective main PCB.
Check the connection of connector CN18 on the main PCB and the continuity across the connector terminals. Remedy or replace if necessary. Replace the LSU. Replace the main PCB and check for correct operation.
Dec 30, 2008 | Kyocera KM-1505 Copier
Phaser 6300 / 6350dx
If you are looking for them free, I really can't tell you how to get one. Only place I can tell you where you can purchase the documentation is 1-800-828-5881 and follow the prompts. That is te line to Xerox parts.
Not sure thats the route you want to go. But honestly it's the only one I know to get proper service documentation.
Mar 10, 2008 | Xerox Phaser 6100/BD Laser Printer
Olevia 32" Video question
if unit is still under warranty, utilize it. otherwise your y-sus bd is failing. the problem will get worse. hope this helps.
Feb 18, 2008 | Olevia LT32HVM 32 in. LCD Television
No picture
This problem sounds like a failed control pwb. This is somewhat difficult to replace and the the back must be removed, and the control bd is located underneath the main digital bd. assy. The main bd is the bd with all the inputs.
Jan 25, 2008 | LG 42PC3DV 42 in. Plasma EDTV
OLEVIA 540-B11 42" LCD-Inverter supposedly shot craps
Hi , I had the same problem but a got the power inverter from somebody, here in denver for $260 brand new , if somebody needs this part, contact me and I will send the information , also please write the part number
Sergio
Dec 22, 2007 | Olevia LT42HVi 42 in. LCD Television
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
Electro Med Services...
