Question about Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder
Picture is distorted and not got anysound. Have tried changing signal but no change. What could be the problem?
    Brigadier General:
  • 3,006 Answers
The Sagem PVR 6280 is specifically listed as a model which will have problems with the retune.
Seethe address below for a chart of affected models, but the officialadvice is that you must contact Sagem directly on 0845 0900 316 foreither an over the air update or an update DVD depending upon themanufacturer.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
SorryI can't provide you with a definite solution but I hope that I've atleast reassured you that it's not something which you have or haven'tdone!
Please return the favour by rating my answer.
Posted on Oct 02, 2009
I cannot hear anysound (incoming calls, speaker or even rigingtones and music)
check if your speaker is fine.if yes then reinstall the phone software or go to lg care to change the speaker.check also if you get soung by plugging the headphones
Apr 03, 2012 | LG P500 Cell Phone
I have a 42" Toshiba
The main logic tv Tuner signal board it is the problems and the causes.That the board where the tv incomming broadcasting signal cable plug into it.This tv repair by a tvs shops will cost u like $500 for a refurbish tv Tuner signal board part and labors.If u have some basic mechanical skills like take things aparts and putting it back together again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement by urself like $110 -120 plus shipping and handdling.
Aug 21, 2011 | Toshiba REGZA 46RV530U LCD TV
I have a Samsung 46 LCD, model LN46A550P3F, that about six months ago had the well known problem of cycling off and on, with the clicking noise, and making occasional LOUD static noises with a distorted...
Power supply board u fixed before was good,but the tv main Tuner signal board it was working on it last leg.Distorted picture screen loud static noises are the indications of the tv main Tuner signal board are not regulating signals of all of those ICS output on the tv main Tuner signal board it is dying and now it is dead.Don't change the T-CON bord it is good.Tries Shopjimmy.com,Ebay.com to buy a whole refurbish tv main Tuner signal board for the replacement.
Aug 01, 2011 | Samsung LN46A650 46 in. LCD HDTV
We have a LG42lx6500. when you turn it on after being off for a few hours the picture colour is distorted for a couple of minutes before correcting. At times you can see the individual pixels. Sometimes...
Hello
Make sure TV is on the correct channel or input. Check the cables for correct routing from TV to any other devices. Check cables to ensure they are tight and secure.
An analog signal converted to high defintion resolution will cause lines, blurriness or fuzziness in the picture. Change the resolution to a lower or native setting using the media device (cable box, DVD,). This may be an issue that requires a service call to cable provider.
A problem on one channel may just be a error on that channel. If using an antenna, it might need to be adjusted in order to ensure good signal strength. For digtal channels, go into TV Menu. Check the DTV signal. Weak signal can cause picture distortion.
If another device is being used such as a cable box, DVD player or VCR switch between devices and test picture. Check routing of cables that are used to control the image. This should be a series of red, white and yellow cables.
If a VCR with a cable box, make sure the VCR and TV are set to the correct channels for video signal to pass through. If problem is still occuring, try another set of cables. bad cables can cause picture distortion.
Bad cables can cause picture distortion as well. Try another set of cables. If picture is better than when using the cables replaced, this was the issue. If cables are not an issue TV may require service.
Apr 26, 2011 | LG Televison & Video
I have a Hyundai rear television HY5111W.I noticed that picture became distorted then disappeared. Can you help me fix it
Hello
Watching standard cable on an HDTV can be quite a shock; the images are likely to be in a smaller aspect ratio, and have grainy or pixelated distortions. Additionally, the use of non-HD compatible devices, such as a DVD player, VCR, or older gaming system, will produce a less than stellar picture.
If you've changed the aspect ratio or your television, or have changed the zoom in or out, you may be encountering distortion that would otherwise not be noticeable. Setting the picture to a 1:1 ratio and turning off any overscan can help ensure a better quality image.
If you're using a system that supports HD, such as a Blu-ray player or an HD-compliant gaming system without the use of an HDMI cable, the image may be distorted. HDMI cables transmit both HD quality digital images and sound over one cable, and provide the best possible picture A/V signals.
Apr 11, 2011 | Televison & Video
Analog Audio Out signal has very high distortion. Signal wanes in and out, wanders from one channel to another, and develops high static. This happens when Audio Out is configured for Fixed Output. When...
The problem is more likely to be with the wireless headphone set rather than the TV. It makes no sense that the signal changes channels. The only difference betweent he fixed and variable output is whether or not the volume changes the output signal amplitude. The channel selection process is not handled there. The distortion is likely due to the input of the wireless being overdriven. If available, turn down the input gain on the wireless and try again. Please update this with the results.
Thanks,
Dan
Feb 28, 2011 | Televison & Video
Phillips 28in wide screen tv. Picture OK through Sky, but has two moving distortions on ordinary aerial. Actual picture is good but the distortions moving up the screen make it very difficult to watch.
Even digital signals can be sensitive to electrical interference and using an antenna, you could be getting garbage from any nearby 'noisy' source. Something you might try is to temporarily switch off any electrical device in your home, one at a time and look for changes in the banding you have.
If the antenna you are using is outside (rooftop) and is rotor equipped, try changing the position to see if there is any increase or decrease of the problem. If an indoor antenna, rotate it slowly while watching the TV display for change. You may be able to determine the general direction of the source of interference. Some seemingly innocent devices that can cause problems; - Light dimmers/controllers - Poorly designed network routers - Cordless phones - Power supplies
Dec 01, 2010 | Philips Televison & Video
Distorted picture.
Is the menu text clear on the screen, when it's focused correctly. Or is that also distorted.
If the menu text is OK then the picture signal is dodgy. could be due to a bad earth lead on the video cable.
Is it distorted on all signal inputs
Oct 30, 2009 | Panasonic PT-LB20U Multimedia Projector
Distorted picture when looking through view finder or lcd screen
the video playback is sampled off the video out and independently processed sorta like a TV signal to project on the lcd screen.
horizontal lines means you lost sync circuit and needs troubleshooting. Hopefully maybe a bad connection with a ribbon cable for the ICs and components are hard to change and jammed tight. I would order a video board.
May 14, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Logo
76 people viewed this question
Top Sagem Televison & Video Experts
Andy Fraser
Andy Fraser
electracon
ka4iup
ka4iup
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
