Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
All my heater does is click. I can't smell any
All my heater does is click. I can't smell any gas passing,
  • 990 Answers
Could be a bad ignitor or if it is a new heater the gas supply could be undersized. ether way for almost all heater repairs you should get a qulifyed repairman. It is a box full of fire next to your house.
Posted on Oct 03, 2009
Flame will no light. Replaced the ignightor module
Sounds like the gas valve isnt opening. are you able to smell if you are getting gas into the system. when it goes to light just try and smell gas coming threw the flue. if no gas try and check with a multi meter if the gas valve is getting power to it. also it might make a click noise when the solenoid in the gas valve energizes. also check that there is indeed gas going into the gas valve. it could also have some gunk blocking the gas from entering the gas valve there is a screen that can block with stuff that might be restricting the gas from passing through.
Jun 01, 2014 | Hayward H Series Pool & Spa Heater 400k...
The hot tub Hester will not light up pilot but does turn on and bow cold air
Glenn,
Many things could be wrong. First off, the exhaust fan turns always goes on when you turn on(up) the thermostat. It does that to suck out any residual gas in the combustion chamber. After about 10 seconds you should hear a click which is the gas valve opening to let the gas into the chamber. You should also hear a series of clicks for about 10 sec, which is the electronic ignition firing. If you hear the clicking of the ignition, but do not smell gas from the exhaust, then the gas feed is being blocked. If you don\'t hear the ignition clicking then the computer board is detecting a fault condition by one of its sensors: over-temp, water flow, exhaust fan . These are all in series and if one doesn\'t pass then the ignition won\'t fire.
Jun 08, 2013 | Pool & Spa
Mastertemp 400 NG heater - unused gas smell when firing
Ask the gas company for the conversion kit part part number they used.
Jul 11, 2017 | Pentair Mastertemp Heater
Hello. When our Rinnai direct vent wall heater lights on it smells of gas. I do not recall smelling this before. It is a sweet smell not a sulfur smell. The filter is clean.
If it's a sweet smell. it's not gas. Gas smells like rotten eggs. There may be something inside the heater that's causing this odor. Remove the cover of the heater and look for some foreign that shouldn't be there. Perhaps, a dead mouse.
Feb 16, 2011 | Rinnai Heating & Cooling
Smells like anti freeze and smokes alot when given gas and also smokes when idleing under the airfilter on the passenger side of an 1990 supra yo
If there is white smoke coming out of that location, chances are that you have a heater core leak. Hot radiator fluid passes through 2 smaller radiator tubes to the heater core. Air from the fan is passed over the heat exchanger, and hot air blows out. White smoke = steam. You can block off the heater core tubes until you can get it replaced.
Nov 23, 2010 | Toyota Supra Cars & Trucks
When it shuts off you smell gas. some times after it shuts off a small flame still burns.
The gas valve is "Passing Gas" basically it's not completely closing after a call for heat . You require a new gas valve and will need a Licensed technician to replace it
Oct 27, 2009 | Heating & Cooling
Heater problem
i concur, when flame is not sensed gas valve closes
Jun 13, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Heater will not heat
If you dont smell any gas make sure that all gas valves between the heater and the main gas meter are open, and the gas valve in the heater is in the on position. Try cleaning out the nozzles that the gas comes out of. Sometimes they can build up with cobwebs.
Apr 08, 2009 | Jandy Laars Hi - E2 350,000 Btu Heater
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
127 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
