Question about Honda Karcher G2400HH-R Pressure Washer
No pressure,but some times have hi pressure, but just for a few seconds. The person before me had the machine without been used for long time now has this problem. only had pressure for 2 times than nothing again help me please. Thank's Astro
    Problem Solver:
  • 5 Answers
First if you have a filter where the water is coming into machine and if you have not already cleaned the filter clean it,but i'm sure you have already thought of that after that the pump may have a problem, most of the time it is cheaper to buy anouther machine than to fix it...sorry
Posted on Oct 19, 2009
Power washer its spraying but no pressure
Sounds like a problem with the compressor. Can you hear it kick in or turn on when you turn the power washer on? Try turning it on and off a few times to see if you can hear it kick in? If the compressor is not turning on then there will be no pressure and the water will just basically flow through the system. Repairing a compressor is not something I can do via email without seeing the machine in person. I would suggest taking it to a repair tech for further evaluation.
Aug 17, 2011 | Garden
Hi There, the coffee machine did not exact any coffee, not sure whether it is to do with the pressure, the milk froth is still working
There are a few things that can cause this. If it brews without the portafilter in, then your coffee is too fine or you have a blockage in your basket if it has a ring in the bottom. You can clean the basket by using espresso machine cleaner like Cafiza or JoeGlo. Automatic dishwashing detergent works in a pinch also. ¼ teaspoon in the basket then brew like normal but stop after 3-5 seconds and let set for 1 minute. Repeat this for about 5 - 10 brews then rinse the basket and run 2 - 3 long shots of just water through the basket (brew) to thoroughly rinse the basket.
If it doesn't brew with out the portafilter in, then you have a blockage in your brew head. There is a screw that holds in the dispersion screen. Above that is a larger screw that holds in a check valve. If you can get the check valve out see if water will run through. If not your blockage is in this tube. Run a heavy wire up this tube for about 4 inches. Twist the wire as you go. Test to see if you can get water through. If so, reassemble and do a descale through both the wand and brew head. Use a strong descale the first time and then do a second. Descale 2 to 3 times a year to prevent this.
Sep 21, 2010 | Solis Crema SL-90 Espresso Machine
Hi! I have a Zanussi IZ12 washing machine. After I turn it on, the door will not open and start/pause button just flashes. (I can select program and press start/pause, it just beeps, but the machine do...
I've had the same problem. I removed the top lit and found some pressure transmitter and a pressure switch. I suspect that the pressure transmitter is use for measuring the waterlevel in the machine. I think the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few times on the transmitter. After doing this the machine washes without a problem since then.
Hope it helps for you.
Jul 14, 2010 | Zanussi IZ12 Front Load Washer
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
Apr 04, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Solis SL 90 occasional pressure loss, only a few drips of coffee before it switches itself off. Cleaning sometimes helps or not using for a bit.
HI
There are a few things that can cause this. If it brews without the portafilter in, then your coffees is too fine or you have a blockage in your basket if it has a ring in the bottom. You can clean the basket by using espresso machine cleaner like Cafiza or JoeGlo. Automatic dishwashing detergent works in a pinch also. 1/4 teaspoon in the basket then brew like normal but stop after 3-5 seconds and let set for 1 minute. Repeat this for about 5 - 10 brews then rinse the basket and run 2 - 3 long shots of just water through the basket (brew) to thourghly rinse the basket.
If it doesn't brew with out the portafilter in, then you have a blockage in your brew head. There is a screw that holds in the dispersion screen. Above that is a larger screw that holds in a check valve. if you can get the check valve out see if water will run through. If not your blockage is in this tube. run a heavy wire up this tube for about 4 inches. Twist the wire as you go. Test to see if you can get water through. If so reassemble and do a descale through both the wand and brew head. Use a strong descale the first time and then do a second. Descale 2 to 3 time a year to prevent this.
Nov 12, 2009 | Solis Crema SL-90 Espresso Machine
My proform 520 runs at high speeds & speeds up on its own
This seems to be an issue with Signal Generator.If you have a problem with the signal generator, your speed will be erratic with either a person on the machine or without a person on the machine. You may even get a speed error code from the unit.
The procedure to check the same is :-
http://www.treadmilldoctor.com/Signal-Generator-Test
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 12, 2009 | Exercise & Fitness
Cooks essentials pressure cookr not going on the high setting...
If the unit is not together and locked the high pressure setting will not work! make sure its locked and put together before you set it!
if this still does not work you may have a faulty switch!
Jan 24, 2009 | Cook's Essentials Cooks Essentials Arome...
Karcher Pressure washer
Hi
don't know if this will help, but when I use mine, to start the pressure up I have to turn the nozzle to fine spray then turn it to the power spray and it works every time, shouldn't have to do this but I got it for nothing.
May 29, 2008 | Washing Machines
Honda Karcher G2400HH-R Pressure Washer Logo
609 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
