Question about ViewSonic VA712B 17" Flat Panel LCD Monitor
Viewsonic VA712b issuses
The problem is that when I turn my computer on the moniter will start up, but it has pixelated blocks over the screen in a grid pattern. If it makes it to show my desktop the screen will flash from black to desktop a few times before going blank with the message:
"No Signal Analog"
Then sometimes it will flash back to the desktop after showing that message then back to a blank screen with "No Signal Analog" a couple of times before going blank again.
However, when the computer showed some messages about how it may have been turned off wrong or was shut down to protect my files there were no pixelated blocks over the entire screen. Not until I selected to start windows normally did they reappear.
I've tried using a DVI cable, the same thing happens but it will say "No Signal Digital" and I've tried it on my brother's hand-me-down computer where it works just fine.
In all cases, expect trying it on the other computer, the light on the moniter turned orange.
  • wyvern0013 Dec 19, 2007
    Ok, i left the monitor on since i had last messed with it to type out the problem above. Here i am sitting in front of the monitor like 2 or so hours later and it comes back from a blank screen. It has pixelated bars going horizontally across the screen.
    Here's a screen shot. Hopefully this link works.
  • 383 Answers
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Posted on Dec 20, 2007
What is the procedure for disassembling the VA712B monitor?
mercoman, Do not use any sharp cutting instruments. See disassembly VIDEOS on YOUTUBE of typical PARTING of rear cover from front bezel. Start at bottom edge looking for place to insert dull flat-blade screwdriver. Use caution. 12fixlouie
Mar 04, 2010 | ViewSonic VA712B 17" Flat Panel LCD...
Have just hooked up my Viewsonic VA720 moniter as the main moniter to a new laptop that I have. The laptop is an ACER Travelmate 6293 running windows XP. When I come to start up my computer each morning...
You most likely have a capacitor that has changed value. When a capacitor goes bad it will work after it heats up. Sometimes a bad cap will have a bulging top or show signs of leakage. Sometimes can only be checked with a meter.
Oct 04, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Green/blue/purple vertical bars on my viewsonic va712b
you're video card is failing, try the secondary port if you have one, artifacting such as different colors, shapes and lines are VGA related, you need a new VGA card and for more info contact
Jun 18, 2009 | ViewSonic VA712B 17" Flat Panel LCD...
Problm with viewsonic va712b
sounds like the operating mode is at a frequency or refresh rate that is outside the viewsonic operating specifications when in normal mode. possible solution: in safe mode access control panel, system, devices (hardware) and look for display. do a right click and uninstall. repeat right click and "scan for hardware changes". That might reset the monitor operating modes but it also gives you a chance to reinstall drivers. If this does not work, try other monitor crt/lcd to see what happens.
May 29, 2009 | ViewSonic VA721 17" LCD Monitor
Viewsonic VA712b lost Power Supply need voltage & current
davsmith00, Did you look on rear of VA712B where the power plug enters the power JACK connector? Maybe it will only tell you who is positive and who is negative (gnd) some monitors state what is the required V & I for them on the rear labels somewhere. This will teach you not to lose your supply. Did the dog hide it under the bed? Good luck finding a replacement. There are sources on web that specialize in drop-in replacement IN-LINE switch-mode-power-supply Bricks. You can also try and and to see if they have something. I'm louie12fix on fixya or lmistyrel@ Bye for now.
May 05, 2009 | ViewSonic VA712B 17" Flat Panel LCD...
It may also be a problem with your video card, I've already seen a problem likewise, try to remove and replug your VGA card and try again, if you can try to plug another screen on your PC and to plug your screen on another PC, then you'll be sure
Nov 05, 2008 | ViewSonic VA712B 17" Flat Panel LCD...
I have a VeiwSonic Monitor model VA712b that went blank.
sell it.. the product and sevice from viewsonic in my opinon sucks nothing but problems tv less then a year old want to ship it back and forth to fix it piece of s**t
Feb 26, 2008 | ViewSonic VA712B 17" Flat Panel LCD...
Open Questions:
ViewSonic VA712B 17" Flat Panel LCD Monitor Logo
381 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
