Question about Lucent PARTNER18 Corded Phone
HOW DO I SET THE CLOCK TO THE CORRECT TIME? - Lucent PARTNER18 Corded Phone
    President:
  • Lucent Master
  • 860 Answers
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programmingHOW DO I SET THE CLOCK TO THE CORRECT TIME? - 2.gif
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
press feature "00" to logout
Posted on Sep 30, 2009
How to set the time
press and hold clock set, press hours button to correct hour and then minutes button to correct time. Then release the hours set button.
Or
press and release clock set, hours and minutes will flash, press hours button to correct hour and then minutes button to correct time. Then release the hours set button.
Instructions are sometimes specific to make and model.
Jul 08, 2016 | Audio Players & Recorders
Timex number t235 clock radio, how do I set the time
easiest way to set clock time. Remove AA battery's if installed.
Unplug Clock from AC. Wait a few seconds. Then replug clock into AC power. Clock will now flash 12:00. Press hours button until correct time is set PM has led on AM has Led off. Set minutes to correct minutes. Then press alarm reset / power/mode button. Wait a few seconds and display will show correct time. Now you can put the AA batteries back in.
Apr 30, 2014 | Timex T065s Solar Powered- Radio...
How do set the time and date on machine
Press and hold CLOCK until the message window displays C, and the default day is announced.
To change the day setting, press MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
Press CLOCK. The current hour setting is announced. The correct day setting is saved.
To change the hour setting, press MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
To change the minute setting, press MEMO/REPEAT or ANNC/SKIP until the correct minute is announced.
Press CLOCK. The current year setting is announced. The correct minute setting is saved.
To change the year setting, press MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
Press CLOCK. The new day, time and year are saved. The correct year setting is saved.
To check the clock, press CLOCK.
The above is from page 5 of the manual at
http://att.vtp-media.com/ecp/documents/product_Product/223/UserManual/944/1739_manual.pt2_i6.pdf
Jun 21, 2011 | AT&T ATT1739 Digital Answering Machine
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 | Watches
I have a clock that will not get correct time. I have no way yo set it . Model #44100 Equity.
All Equity Insta-Set clocks automatically set the correct time and date when you turn on the power. Occasionally, the automatic time-setting feature malfunctions and you must reset the time yourself. Manually changing the time to the correct time on an Equity Insta-Set clock requires the push of only a few buttons to get the clock back on track:
1. Press and hold the "Alarm Set" button for five to seven seconds, the year will begin to blink when the clock is ready for adjustment.
2. Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock
3. Set the month, day, hour and minute. Press the "Alarm Set" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
4. Press the "Alarm Set" button after setting the date and time to store the information into your clock's memory.
Best regards,
gylacz
Mar 18, 2011 | Audio Players & Recorders
Oregon Scientific Model 323a--Atomic clock...the atomic clock keeps setting itself to one hour behind what time it actually is in my time zone...I mannually re-set the clock to the correct time...but when...
Make sure that the clock is set for the correct time zone and that the DST (Daylight Saving Time) function is ON. Also, although not mentioned in the manuals, these clocks will typically jump and hour ahead or behind when the batteries get weak. Replace your batteries if they are more than a year old.
Bill B
Mar 21, 2010 | Oregon Scientific RM323A Travel Alarm...
7:15 p.m., 10/6/09-I don't know how to set up the time & date on the machine. I need clear, step-by-step instructions. Help! AT&T digital answering machine model 1738. THANK YOU!! Barbara S.
To set the clock. You must set the clock once so that the system announces the correct day and time with your messages. After this, if you subscribe to Caller ID, the system will automatically reset the clock each time new call information is received.
Press PLAY/STOP to exit at any time while
setting the clock.
1 Press and hold CLOCK until the Message Window displays C, and the default day is announced.
2 To change the day setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
3 Press and release CLOCK. The current hour setting is announced.
4 To change the hour setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
5 Press and release CLOCK. The current minutes setting is announced.
6 To change the minutes setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct minutes setting is announced.
7 Press and release CLOCK. The current year is announced.
8 To change the year setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
9 Press and release CLOCK. The new day, time, and year are announced.
To check the clock, press and release CLOCK.
If you need futher instructions for your answering machine you can download a copy from:
http://phone.manualsonline.com/manuals/mfg/att/1738.html
Please rate this solution. Thanks..
Oct 07, 2009 | AT&T Lands Phones
Model 1739 answering machine
Set the clock
You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced.
2. To change the day setting, press
3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
4. To change the hour setting, press
5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
6. To change the minute setting, press
MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
8. To change the year setting, press
MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
Jan 08, 2009 | AT&T 1717 Digital Answering Machine
Time not correct
press mode button once.
Then press set until the time zone is on the correct setting
then press mode again
Dec 22, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Setting the clock
Setting the Clock for Systems with the
Set Button
Press SET. Within five seconds, press and hold the right
SEEK arrow until the correct minute appears on the
display. Press and hold the left SEEK arrow until the
correct hour appears on the display.
Setting the Clock for Systems with HR
and MN Buttons
Press and hold HR until the correct hour appears on the
display. Press and hold MN until the correct minute
appears on the display. To display the clock with the
ignition off, press RECALL or HR/MN and the time
will be displayed for a few seconds. There is an initial
two-second delay before the clock goes into the
time-set mode
Nov 13, 2008 | 2002 Chevrolet Silverado 2500HD
Lucent PARTNER18 Corded Phone Logo
212 people viewed this question
Top Lucent Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
tfelton3
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
