Question about Kitchen Appliances - Others
Can i take power from another light switch in the same box to power a new light with a switch? how would i do that?
  • 87 Answers
Yes, you can do that, if you do not exceed over-current protection. you will have to tie into it before the wire goes into the exsiting switch. hope this helps
Posted on Oct 02, 2009
2002 f-350 headlights not working. new mfs, new headlight switch, no power to fuses
Did you check fuse # F2.7 in the central junction box ? This fuse powers the main light switch an the MFS an the headlamp fuses ! Does your truck have auto lights ?
Jun 22, 2015 | 2002 Ford F-350 Super Duty
I have a 3 gang box in my kitchen on switch is a double switch for the kitchen , one is for the outside flood light and the other is to the garage lights. I need to replace the garage light switch beacuse...
Your switch has 2 wires, and 2 brass screws, and new switch will have same.
Connect either wire to new switch.
Connect bare ground wire to green screw.
Turn power off, remove screws that hold switch into box, pull out switch, take photo of wiring, install new switch.
If wires are pushed into back of switch, then use small screwdriver and push into slot to release wire.
http://waterheatertimer.org/How-to-wire-switches.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 05, 2011 | Cooper Industries Cooper Wiring 2158V 3...
Break lights not working. getting no power at fuse box. new fuse and bulbs.any idea? toyota corolla ae95 4wd 1991 model
check for power from the brake light switch, the switch feeds power through the box and then to the lights, it may be broken
Sep 21, 2011 | Toyota Corolla Cars & Trucks
Bathroom switch controls light & fan. Trying to change out switch into a gfi switch/receptile. Box contains 2 wires ( total 2 white and 2 black, plus ground). what do i do
First you have to identify cables.
You have 2 cables that enter box. Each cable has black and white wires.
One cable probably comes from breaker box, and one cable probably goes to Load (which means your fan-light)
Separate wires for testing. Turn power ON.
Test each wire to bare ground wire. Tester lights up on Hot wire. This wire will connect to brass 'Line' screw on back of new GFCI device.
Hot is identified. Test Hot to all other wires except bare ground. Tester lights up on Neutral wire. Neutral connects to silver screw that sits across from Line screw on new GFCI device.
Other two wires inside box go to Load.
These wires connect to the two wires that stick out on back of new GFCI device.
Ground wires are connected together and connect to green screw on new device.
Apr 21, 2011 | Cooper Wiring Devices ACE AC-DC...
I have power in 14/2 and 14/2 out to light. how do I wire the switch. I tried putting whites together and blacks to switch but it doesn't work.
Your breaker is not tripped.
Your light bulb is working.
You have a working on-off switch that has two brass screws and a green ground screw.
That is a single pole switch. Black wires go on either brass-colored screw, and whites are twisted together.
If switch has 3 screws and ground screw, connect black wires to dark-screw and one of the brass screws.
First you should test your wires.
You have 2 cables.
Both cables have black, white, and bare copper ground wires.
One cable goes to light.
Other cable comes from breaker box.
Cable from breaker box has black-hot wire and white-neutral wire.
Turn on power and test black wire to white, and then test black wire to ground.
Tester should light up with both tests.
If tester does not light up, then breaker is suspect, or there is a short in nearby box.
Track back the short towards breaker, going one box at a time, each time testing black to white and black to ground.
Next, inside the switch box, remove the switch and connect both cables without the switch.
Black to black
White to white
Turn on power, does light turn on.
If light turns on, your switch is suspect. Connect new switch. One black wire to each brass screw, and then tie white wires togethr.
If light does not turn on, your light is suspect. Open light fixture and test black to white and black to ground again.
If light tests with power, then check your bulb
If light has no power, then wire between switch box and light is suspect.
Dec 06, 2010 | Electrical Supplies
How do i replace a pull cord with light switch
Ok so, L (line) N (Neutral) and E (Earth ground), and no idea what this rose is. I suppose you mean Junction Box when you say JB. You can use the original junction box for the wall switch connector, but the Black and white wires coming from the switch must be disconnected from power to be used, if power is already present in your light's original junction box (which is usually the case when using a pull switch light). Then you connect the white and black wires to your wall switch and use them to break the circuit at the light itself by wiring it between the light and the power lead.
Mar 24, 2010 | Plumbing
Power comes from light to switch.want to wire in another switch (same box) to operate another separate light
OK .. for this to work, you would need to confirm that the power cable is also in this wall box. So in that wall box you need the existing power cable, the existing light cable, and a new light cable. All the cables being 2 wire with ground. Then just jumper the black power wire top the new switch, and connect the new light , black wire to the switch, the whites will all be together ..
If there is only one cable in this wall box , then the power is run to some other box and you need a neutral for the new light. That may mean rewiring the power tyop get it to the wall box, or rewing the new light to get power from it.
Please Vote !!
Mar 22, 2010 | Cooper Wiring Devices ACE6001V-K "ACE"...
Need to move a light switch into a new room, I had a big den that I closed off part of to make another bedroom. the problem is the light switch for the light is now in the hallway.
this cannot be easily answered, if the power supply is in the fixture simply run a new wire to the new switch. if the power is in the switch run a wire from the same switchbox to the new location and wirenut the wires on the switch to your new wire. remove the switch to the new location and ummy off your old switchbox.in either case the latter should be the easiest and safest way to go. always be sure to turn the power off at the panel box. and remember electrical work isnt like your typical trades bad things can happen when very quickly if you dont know what you are doing.
Dec 29, 2009 | Electric Door Light Switch
I want to install a GFI outlet in a bathroom that only has a outlet in the light fixture? How do I run a wire from the switch which has 2 switches, one for the fan and one for the light above the med...
Make sure you turn off the power at the power panel.
If you are lucky you will find the following in the electrical box behind the light:
  1. A black wire that brings power from the fuse/breaker panel--connected directly to one or two other (black) wires (not to the light).
  2. A white wire from the panel--connected to one or more white wires including one to the light.
  3. A black or white (maybe taped black) wire that comes from the switch and is connected to the light.
  4. A green or bare wire connected to the box and maybe also to the light.
If this is the case then you can run a new cable to a new electrical box in the wall for the GFI. Connect the new black wire to the Line In terminal/black wire of the GFI outlet and to the group of black wires in (1) above. Connect the new white wire to the Neutral terminal/white wire of the GFI outlet and to the group of white wires in (2) above. Connect the new green/bare wire to the Ground terminal/green wire of the GFI outlet and to the original box or ground wire. If there is a Load/Feed through wire on the GFI outlet, tape the end of it and do not use.
If the black and white wires described in (1) and (2) above do not appear in the electrical box at the light then they are probably in the switch box and there will be only one black wire and one white wire that connect to the light on the wall. In that case you will need to run a new cable from the switch box to the new outlet. You will not be able to wire the new outlet from the existing electrical box at the light unless you do it through the switch and it will not be on unless the switch is on.
Aug 28, 2009 | 3M GFI Software GFI MailEssentials For...
Kia optima low beams
First verify that the switch is energizing the relay in both positions by turning the low beams on and then pulling up the relay--does it click? If not, replace the switch. If yes, next check for power on the red wire as it comes out of the column. Switch on, no power--replace the switch. If power, check for power at the head-low fuse in the engine compartment fuse box. No power--find break in wire. If power, check for power on the yellow/red wire as it comes out of the fuse box. No power--repair fuse box. Power--check for power at lamps--same wire. No power--repair yellow/red wire.
Aug 16, 2017 | 2005 Kia Optima
Kitchen Appliances - Others Logo
70 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
