Question about Tippmann A 5 Standard Paintball Gun
What is the maximum velocity for the US army alpha
I just got the US ARMY alpha black basic gun but it doesn't shoot very far, what is the maximum velocity for the US army alpha black basic? How do we set it to the maximum?
    Problem Solver:
  • 7 Answers
280 or 300 depending on league and field, but adjust the velocity with an allen wrench on the back of the gun usually right above the handle
Posted on Apr 05, 2010
  • 85 Answers
You do not want to set it to the max, goto a local field who has a chronograph and have it set to 300 fps. Anything over 300 fps will cause injury and can crack/damage the protective gear! Also if playing at a field you WILL get removed for using a hot gun!
Posted on Oct 03, 2009
When i hook the air tank up air comes out the barrle
**** the gun before you attach the tank.
If it's still leaking it cold be bad "O" rings on the bolt.
Check all your "O" rings
Feb 24, 2011 | Paintball Tippmann U.S Army Alpha Tactical...
I have a semi auto alpha black. When im firing on semi auto sometime the gun switches quickly to fully auto and releases lots of CO2 without really shooting any paintballs
Does this only happen when you're low on air? Also, make sure you're using a good paintball oil for lubrication and make sure the marker is clean. It's possible for an o-ring to leak, or once it gets cold to leak, so make sure you use the proper o-ring for the proper location (lots of them look alike so keep them labeled and bagged separately).
Play hard, play safe, play with honor!
8^)
Aug 19, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
My alpha black paintball gun is shooting 1 to 5 then stopping.
Sounds like it needs to be oiled. A couple of drops in the small hole where your bottle screws on.
Replace bottle and dry fire to see if you got it. Cleaning is just as important. Internals need to be cleaned
and lubed often. I know it's late but hope it helps someone.
Jun 11, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
Paintball gun problem
First off, make sure it's clean, and lubed with a quality oil made for paintball.
If you're sure the o-rings are good (as in relatively new) it's pretty hard to tell just from looking as it doesn't take a lot of damage to leak air.
Try a different tank, just to be sure. Make sure it's full.
**** it. If that stops it there's a clue.
If it's had some use it's possible to have a bad/weak spring and the valve isn't closing entirely. Make sure your velocity is less then 300fps.
Check out your local airsmith or field and they should be able to get you squared away if none of that helps.
8^)
Apr 30, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
Took it apart and don't know how to reassemble
How To reassemble an Army alpha black paintball gun.
Apr 23, 2010 | Tippmann 98 Custom Act Paintball Gun
Need manual for Predator Board
Try this
http://www.alternativepb.com/manuals/tagdm4board.pdf
May 09, 2009 | Paintball Tippmann U.S Army Alpha Tactical...
Tippmann A 5 Standard Paintball Gun Logo
246 people viewed this question
Top Tippmann Sport & Outdoor - Others Experts
spank61
Vickie Miller
Vickie Miller
Level 1 Expert
Are you a Tippmann Sport and Outdoor - Other Expert? Answer questions, earn points and help others
