Question about QSC PLX3602
Hi, my plx 3602 keeps rebooting agter 10 seconds.
Hi, my plx 3602 wont turn on properly. It starts up as normal then after the lights have all flashed it reboots itself?Could anyone help? Si
2 Suggested Answers
  • 5603 Answers
SOURCE: Have a blown capacitor in a QSC PLX 3602. It's
I need a board marking number as there may be several caps near the on/off switch.
Example:
C117 .47mfd 250VAC (use 600VDC)
C126 .1mfd 250VAC (use 600VDC)
C132,133,136,137,140,141, All 2200mfd 200VDC (These are large canned units)
Note if one of the latter ones, better check the full wave rectifier bridge for a bad diode as well.
I have the schematic but not an assembly drawing so description of near switch doesn't tell me enough.
Posted on Oct 30, 2010
Behringer B112D wont power up until 10 minutes after switching on
This will be a power supply problem. Take it in to your repair shop for service.
May 07, 2016 | Behringer Eurolive B112D Powered PA...
Blinking standby light no power
When you turn the amp on, does all the tubes light up? please add more info to help you out.
Oct 07, 2013 | Bugera 333XL Infinium 120 w 3 Channel...
Just purchased a used Alvarez FF60WR. The Electrical part works, but the on board tuner does not. It lights up when you turn it on, but the pitch indicator lights do not flash, and neither do the arrows,...
my on board tuner used to do that. I just tried to tune the guitar normally and it usually worked after a couple of seconds. The tuner needs sound to work - it won't work without you playing any notes :)
Aug 30, 2013 | Ibanez Ael20e AcousticElectric Guitar with...
Amp 5050 rmx stay in clip mode
Disconnect speakers. With NO input, if clip light remains on, take in for repair as there is an internal failure. If reducing the gain and loudness keeps the clip off, then you are probably driving the amp too hard. This is common problem when the user "thinks" they need it louder but the amp speaker combination will not deliver louder. At this point, both the amp and the speakers are at risk of permanent damage requiring repair.
Sep 22, 2011 | Qsc Plx-2502 450w Per-Ch. 8 Ohms Amplifr...
My DD7 delay wont turn on. The red indicator light will flash for a few seconds then it fades away and does nothing.
If on battery, battery is depleted. If on adapter, connection is probably bad. Often power jack is broken or has bad soldering.
Jun 02, 2011 | Roland Boss DD-7 Pedal Delay/Reverb
I have the Roland Boss Rc-20xl Loop Station, and I'm running off of batteries I have been since I got the pedal. In the middle of recording a phrase the pedal shut off and started resetting itself...
Hello!
I am not positive on this but I would try to clear all of the loops. Try holding the right pedal for about 5 seconds.
If that does not work, hold the right pedal for about seconds while you turn off the unit. Release the right pedal then turn the unit back on.
Hope that helps!
May 11, 2011 | Roland Boss RC20XL Phrase Recorder Pedal
Hi my name is Mike and I have a problem with my mini spot. It was working fine for about 2 weeks. Now right when i start, instead of it going through its intitial 10 second or so boot up (with the red led...
hey Mike, I just got 2 brand new minspot rgbws and they worked for 3 days and now tonight the same thing!
they power up and goto a white light and dont move. no display on led panel either...
did you find a fix?
Apr 11, 2011 | Chauvet Minspot Rgbw Min Spot Led Mini...
When I turn on my BOSS RC-20XL Loop Station the reverse, tap tempo, write, exit and one shot phase start to blink rapidly and I cannot get them back to normal. Therefore, I am unable to use my loop...
Hi. I had the same problem and fixed it by clearing all the phrases. An explanation of how to do this is below (written by someone else, not me) But, expect your guide beat to now sound like a fuzz instead of a drum. This really sucks and there is apparantly no fix for the guide sound except to send it back to Boss. Good luck.
1. Start by selecting Phrase 1.
(if the 'REVERSE' or 'AUTO START' are lit press them off.)
2. Select 'INST & MIC' by pressing 'MODE'
3. Hold down 'EXIT' and 'AUTO START' together - at the same time, this should light up the green LED for 'LOOP PHASE'
4. Hold down 'WRITE' and 'EXIT' together
then hold 'WRITE' on its own
then 'WRITE' and 'EXIT' together again...as if you were clearing a phrase.
they should light up in red and flash, if not try a combo of section 4.
5. Repeat on all Phrases 1 - 11.
Mar 24, 2011 | Roland BOSS RC-20XL Loop Station Phrase...
Have a blown capacitor in a QSC PLX 3602. It's the large black capacitor near the on/off switch. Can't read the letters and numbers. What is this capacitor? Thank you.
Example:
Oct 29, 2010 | QSC PLX3602
QSC PLX3602 Logo
56 people viewed this question
Top QSC Music Experts
Vito Vacirca Jr.
Are you a QSC Music Expert? Answer questions, earn points and help others
