Question about Garden
Hi, MyMacallister presure washer i've only used 4 times, Has develutped a leak from the lower right hand side back. I bought it from B&Q, and when i took it back, and told then i had moved house, and could not find the receipt, they did'nt want to know. the machine cost me £80 and i feel so let down. What do i do ?. My telephone number is 07517884024, Please help. Jon
    Problem Solver:
  • 5 Answers
Jon i'm sorry their treating you that way I will try to help..First go back to where you bought the pressure washer and first speak with a sales person and explain that you only used the machine x times and that you feel it has not lived up to what you were tould.(wait until asked for the receipt befor saying anything) Just tell them when asked the receipt is at home,no lie there it is at your home right! Then if he/she cannot help then ask to speak with the manager.If that does not do it ask to speak to the corperate manager. Busness do not like there product being spoken about in a bad lite for the whole world to hear in there store... As they say the squeaky wheel gets the greese..hope that helps..
Posted on Oct 19, 2009
6 VE 1 oil leak top right timing belt cover
6ve1 engines are non interference and therefore will not bend valves and is why it uses a rubber timing belt.. leaks from top right hand side are likely the head gaskets on that side or the cam sprocket into the head seal has failed .. no biggie
Jul 17, 2013 | Cars & Trucks
I dont know how to adjust the time in nike led watches
My Nike LED watch has 4 buttons on it--two on each side. The two buttons on the left light up the screen, but don't do anything of note. The two pushers on the right side do all the work.
To adjust the time on your watch, push the top right button to illuminate the time. Then, while the time is displayed, push the lower right button. You need to give it a good push--a bit longer than just to light up the time. The hour digit should start flashing. Use the top right button to advance the hour to where you'd like it to be, then push the lower right button to switch to setting the minutes. Pushing he lower right button again will advance you through the opportunity to adjust the month, date, and year. When you've cycled all the way through and can see the time again, push on the top right hand button to restart the timekeeping function, and you should be good to go.
Jun 14, 2011 | Watches
The washing machine has come up with an f01 error a couple times this week...just bought the machines in October 2010? What does this mean & how can i correct it
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Hi, sounds like you need a service manual.
F01 error code. The technician manual is located under the lower front panel. There are three possible reasons for F01:
1) EEPROM ERROOR. Unplug a washer for two minutes. Try running it again. (Did not work for me).
2) MAIN RELAYS ERROR. The tech manual suggests replacing CCU. The following is what I did and it fixed the problem, however. Unplug the washer. Remove the top cover by removing the three screws on the back. The CCU unit is in the right bottom corner if standing in front of the washer - it has a lot of wiring. Plug in the unit. While listening to the CCU start any washing cycle. After pressing START you should hear the relay to click. If it clicks twice, within a less than a second, it has a problem. Unplug the washer. Without disconnecting any wires remove the CCU cage from the washer wall. Stand now on the right hand side of the washer in such way that the CCU cage is under your left hand. Pull the right upper corner of the CCU plastic cage (it has a tab) away from you, slide the cage to the right by about an inch, and pull the entire cage away from you. Now knock on the back side of the cage 4-5 times with a bit of force (watch "Armageddon" movie for more instructions on it). Install the CCU cage back. Plug in the unit. Try some washing cycle again. If it did not help, repeat the procedure. If it did not work again, see the following.
3) PUMP DRIVE ERROR. The tech manual suggests replacing CCU.
Dec 13, 2010 | Washing Machines
The water won't drain from washer lgwm0642w
Hi dear.Machine's pump filter is located lower left hand side.Please open the lid,pull out the drain plug & remove the water inside the tub.Turn the filter anticlock wise to take it out.Please check for any obstacle,if ther is any please clean it.Please keep in mind,your washer have 2 pumps.On left hand side for drain & right hand side for recirculation.Make sure both one works.Also check the drain hose for kink.If that's not worked,you may need to change the pump.Call service department.I hope that helps.Thanks.
Feb 10, 2010 | LG WM0642H Front Load
Leaking
Hi. Mike here. Two "most likely" causes. (1) You simply have a leak at the lower right "cleanout trap". Remove the little white plastic "pull-out" assy. Check the black seal that looks like a little "tire". Is anything caught in it, or wrapped around it, or has it become deformed? Also, check that white plastic (2") washer, in front of it, is not warped (due to overtightening). Unscrew the "knob" (handle) part, all the way out, and separate all 4 parts. Clean knob, washer, tire (seal), and trap assy. Slip washer, then tire, onto knob's threaded "shaft". Flat side of washer goes against knob. Screw knob, washer and tire into trap assy, but only one or two turns. Then, slip entire assy back into machine's recess - and turn Clockwise to tighten. Only tighten hand tight (and I don't mean Macho tight!)
(2) If that doesn't fix, you may very well be using WAY too much detergent. These machines use only 2 or 3 (Max!) Tablespoons of HE liquid detergent. I've seen cases where folks were using 1/2 cup of liquid (or powder) and even more. That causes so much foaming that there have been overflows, from the lower right corner, even though nothing was wrong with the machine. To remedy, run a load empty, with NO detergent.
Good luck, and God bless.
Mar 06, 2009 | Malber WD1000 Front Load Washer/Dryer
Error Code F01
Hi there, After about year and half Whirlpool duet sport gave F01 error code. The technician manual is located under the lower front panel. There are three possible reasons for F0: 1) EEPROM ERROOR. Unplug a washer for two minutes. Try running it again. (Did not work for me). 2) MAIN RELAYS ERROR. The tech manual suggests replacing CCU. The following is what I did and it fixed the problem, however. Unplug the washer. Remove the top cover by removing the three screws on the back. The CCU unit is in the right bottom corner if standing in front of the washer – it has a lot of wiring. Plug in the unit. While listening to the CCU start any washing cycle. After pressing START you should hear the relay to click. If it clicks twice, within a less than a second, it has a problem. Unplug the washer. Without disconnecting any wires remove the CCU cage from the washer wall. Stand now on the right hand side of the washer in such way that the CCU cage is under your left hand. Pull the right upper corner of the CCU plastic cage (it has a tab) away from you, slide the cage to the right by about an inch, and pull the entire cage away from you. Now knock on the back side of the cage 4-5 times with a bit of force (watch “Armageddon” movie for more instructions on it). Install the CCU cage back. Plug in the unit. Try some washing cycle again. If it did not help, repeat the procedure. If it did not work again, see the following. 3) PUMP DRIVE ERROR. The tech manual suggests replacing CCU.
Aug 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer
I will need the model number off the unit on a regular Duet there is no F-01 codethere is a F10 some models (ie. Sears units) have diffrent codes so if you post the model number i can see where the problem lies also if you need to open the door there is an Emgcy. door release it is located behind the lower panel you will need to remove the 3 #10 torks screws the panel will come off reach up below the door latch assby you will see a tear drop plastic tab pull on it and it will release the door
Apr 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code F01 on my whirlpool front loader? any help is appreciated
Hi, After about year and half Whirlpool duet sport gave F01 error code. The technician manual is located under the lower front panel. There are three possible reasons for F0: 1) EEPROM ERROOR. Unplug a washer for two minutes. Try running it again. (Did not work for me). 2) MAIN RELAYS ERROR. The tech manual suggests replacing CCU. The following is what I did and it fixed the problem, however. Unplug the washer. Remove the top cover by removing the three screws on the back. The CCU unit is in the right bottom corner if standing in front of the washer – it has a lot of wiring. Plug in the unit. While listening to the CCU start any washing cycle. After pressing START you should hear the relay to click. If it clicks twice, within a less than a second, it has a problem. Unplug the washer. Without disconnecting any wires remove the CCU cage from the washer wall. Stand now on the right hand side of the washer in such way that the CCU cage is under your left hand. Pull the right upper corner of the CCU plastic cage (it has a tab) away from you, slide the cage to the right by about an inch, and pull the entire cage away from you. Now knock on the back side of the cage 4-5 times with a bit of force (watch “Armageddon” movie for more instructions on it). Install the CCU cage back. Plug in the unit. Try some washing cycle again. If it did not help, repeat the procedure. If it did not work again, see the following. 3) PUMP DRIVE ERROR. The tech manual suggests replacing CCU. thanks
Apr 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error Code F-01
Mar 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Lg washer wm227wh
  May be a broken off balance sensor.  This would go along with everything else that was damaged.  It senses off balanced load and slows machine.
Oct 23, 2007 | Washing Machines
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
