Question about Motorola Mobility RAZR V3
Can you please tell me about the flap switch somewhere placed. i dnot know about it.i changed the casing and its light is not turning on when i flip it.. thnkx.. reply:
How do I fix a wall light switch that turns off when you flip the switch up, and turns on when you flip it down.
If it is a single pole switch (only 2 screws on the switch) then all you need to do is remove the switchplate, remove the switch from the switchbox (no need to disconnect any wires), turn the switch proper side up and reinstall the switch back into the switchbox. Reinstall the switchplate and you are all set.
The story changes if you have a 3-way switch...which means you have two switches controlling the same outlet. In this case you would be chasing your tail if you don't like that one switch is up and the other down...because as soon as you flip one from the down position to the up position, you are changing what happens with the other switch.
Jun 07, 2015 | Dryers
Do you have a wiring diagram to wire a security motion detection light between 2 3-way switches so switches can be turned: (on-Motion)/(on- Completely) from 2 different locations?
Here is a page of diagrams: http://www.do-it-yourself-help.com/3_way_switch_wiring.html
You have to use a 3 way switch on both sides. You should be able to get a motion light that has an always on feature. To activate the feature then you need to turn the light on off on fast and then it stays on. Ceck with home depot or someplace like that for lights with that feature. IF not then you are going to need to run another circuit.
Feb 20, 2014 | Electrical Supplies
Lenovo 3000 H Q41 8789 model Desktop Power Switch problem
Most 110 - 220 volt switches are accessible on the outside. Check the back, near the power cord. It might be a small red toggle that you flip with a flat screwdriver.
Plus many power supply's are self adjusting with no need to flip. It will be indicated.
Oct 04, 2012 | Computers & Internet
Wher to plug speakers
Good day,
I have not been able to find a clear diagram of your Acer model but there appears to be a door flap at the bottom front of the case which flips open. I believe you will find the speaker socket behind this flap, as well as the USB sockets. The speaker socket is light green. There is also a green speaker socket at the rear of the case at the top.
Best wishes,
Graemevm
Jan 06, 2012 | Acer Aspire X3400 PC Desktop
I HAVE CHANGED BROKEN FLAP 2 MONTHS AGO BUT THE FUNCTION OF OPERATE SYSTEM AFTER CLOSE THE FLAP CANT WORK PROPERLY, SO PLEASE TELL ME WHAT CAN I DO?
Was the flap changed by a techician ?
I have played with my 1200 and thus
know the flap hinge area has two special aspects :
(a) embedded-into-hinge-on-one-side, a spring loaded mechanism, for the firm open-close action.
(b) a small circular magnet embedded within the hinge framework (this magnet working from the right location should be essential to trigger the answer-when-flip-open or disconnect-when-flip-is-closed systems).
So your problem could be due to one or both of these things not being (re)installed correctly.
Good Luck.
fixya[at]technife[dot]com
Nov 05, 2010 | Motorola Mobility A1200
Batteries won't maintain electrical connection
hi jensen,
in that case u'll have to change the body of the camera.
i can tell u a trick: place a piece of an aluminum foil (kitchen foil) between the contacts and the batteries. this will ensure a good connection.
try it and please rate this solution.
good luck!
Feb 13, 2009 | Vivitar ViviCam 3715 Digital Camera
How to load the paper
There are two places you can load the paper.
There is a small pull out tray underneath the flap where the paper prints out in front. Lift the flap then pull out the tray using the handle cutout at the very bottom of the printer.
There is a back feed location as well, if it's not up already, flip up the back feed flap. There are two finger holds on either side of it on the back of the top of the machine. flip it up and put the paper in there.
It is important to select which to print from as well. On the left side of the button console there is an indicator light on the drawn picture of the printer. Make sure the indicator light is on the place where you have your desired paper. If not push the "feed switch" button next to it.
Dec 14, 2008 | Canon PIXMA MP600 all-In-One InkJet...
95 dodge ram 1500 does not go into 4 wheel drive,heater flap flips back and fourth at acceleration and cruise co ntrol does not work.I know its probably a vacum leak,but, is there a common place that the...
For the 4 wheel drive system, the comon place is under the vechile near the transfer case. You'll see two tubes coming from the engine compartment running along passanger side frame rail. They then follow the cross member to the transfer case. Right there where they run off the cross member into transfer case is where they normally come off. Sometimes just slipping them on cures it. Other times, you may need to find a way to connect them better. I'ld tell you how I use to do it but it's a real jerry rigged job.
As for the heater and crusie, I have no clue.
Sep 12, 2008 | Dodge Pickup Cars & Trucks
Dualit 889 espresso coffee maker problem
To pull a shot
1) Turn machine on (innermost right switch)
2) Red light goes on (power on)
3) Yellow light goes on (thermablock heater)
4) Wait for yellow light to go off
5) Detach handle (pull to left)
6) Clean handle, remove crema sieve, clean with soap & water
7) Put crema sieve in handle (you should have a choice of two)
8) Put espresso ground coffee in with brown handle
9) Tamp coffee down FIRMLY with handle
10) Place handle back into machine (push to right)
11) Ensure flip switch on leftmost side is at top position
12) Flip down rightmost switch to infuse coffee into handle
13) Wait 18 - 24 seconds
14) Flip up rightmost switch to turn off infusion
15) Put milk into container (about 200ml in a 600ml container)
16) Flip down rightmost switch to bottom position = steam
17) Keeping tip about 5mm from top of milk, foam to ~400ml
18) Place sugar in coffee, if desired
19) Pour milk in coffee
LATTE
YUM
May 06, 2008 | Dualit Espresso 889 Espresso & Coffee...
Bissel Proheat 7901 Diverter Knob and Flap problem--Helpppp!
Manual here in case you missed the link; http://www.bissell.com/images/UserGuides/7920.pdf Waiting on your photo as discussed. :)
Mar 14, 2007 | Bissell 1699 ProHeat Clear View Upright...
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
