Question about Canon imageRUNNER 4570 Copier
E532 in canon np 6560
On startup everything is fine except when it checks the sorter then i get the E532. had a bad staple, removed, but seems stapler won't reset.
  • andzulisv May 11, 2010
    when you removed thestaple you may not have pushed the silver plate with the green tab on it down into proper position
    President:
  • Canon Master
  • 990 Answers
Hello sir; That's not the staple problem, that's staple shift motor problem, replace it.
Posted on Oct 01, 2009
How do you change a staple cartridge in a canon imagerunner 2870?
first open upper front cover.
then pull handle on left corner of front side, the sorter unit will come out. see behind side of sorter unit u'll find a small green handle to detach the staples cartridge, replace the staples cartridge and insert unit into stapler. push back sorter unit an close the upper front door. end
Dec 20, 2010 | Canon imageRUNNER 2870 Copier
Code e532 what is it and can i fix it
Errors that start with a E5xx is usually a fault with the sorter or finisher accessory.
Check that the accessory is not jammed or incorrectly mounted.
Try disconnecting it to see if the copier works without it.
Apr 28, 2010 | Canon NP 6545 Copier
I have a Canon 1180 printer with sorter and stapler. The stapler puts dents in paper but does not staple. It has staples and there appears to be no jam. What up?
if you have cleared any jamed staples in the cartridge and it is still doing the same thing it may be a weak staple motor or a gear on the staple assembly may be slipping.
Apr 16, 2010 | Canon CLC 1180 Copier
HAS CODE E532 AND MESSAGE TO TURN OFF AND BACK ON
E532-1 Stapler guide bar motor E532-2 Stapler swing motor E540-3 Bin shift motor
Apr 01, 2010 | Canon NP 6545 Copier
The Staple Sorter feeder has stopped working. The copier works fine but it becomes jammed when it reaches the staple sorter. Remove the sorter and the pages come out.
if you have blower,air blown the whole sorter unit it could be there is a sensor that was dirty or contaminated by dust. hope this will help
Jul 08, 2009 | Canon NP 6035 Copier
Error code E522. How to fix this?
You have an issue with your staple finisher, probably need to inspect the stapler unit itself to make sure nothing is jammed in it and it moves freely. If you can't clear the error then most likely the unit is defective.
Hope this helps,
TankMurdock
Apr 24, 2009 | Canon NP 6551 Black and White Copier
I HAVE TROUBLE WITH MY CANON NP 6251 IT ONLY DIPLY THE CODE NUMBER E 532
A E532 code deals with the sorter. Are the bins moving at all, also try to unjam the stapler. Also have you tried to let the machine warm up with the sorter moved away from the copier? How about this have you tried to turn the copier OFF then disconnect the sorters plug from the back of the copier and turn it back ON with the sorter moved away from the copier. If it works you are all set. I believe your copier is a older model and for the 10 bin sorter that it comes with may not be worth repairing. If it is a 10 bin sorter, it was never a good design from Canon, they work or don't work.. Good Luck...
Sep 28, 2008 | Canon imageRUNNER C3200 Copier
Adding Staples Image Runner 330S
depednding on sorter im guessing its the small sorter with one tray the stapler is in the rear of the sorter green handle pull it out uses L 1 staples
Jul 24, 2008 | Canon ImageRUNNER 330s Copier
E531
Check your stapler. If you removed a jam from the sorter you may have accidentally moved the stapler so it is not sitting at a 45 degree angle when you open the front door of the sorter. There's a little lever you can push to swivel the stapler, however don't try to force it. You may have to pry up the plastic lock that is under the stapler with a small screwdriver. Sometimes the stapler assy has to partially removed (slid to the front) of the sorter to be able to see what you're doing.
May 14, 2008 | Canon NP 6551 Black and White Copier
Nothing is copying
E532 is a sorter problem. Have you replaced the staples recently? If so try to remove any jamed staples from the stable cartride and try to reinstall as shown on the inside of the soter front door. You can also try to turn the copier off and unplug the sorter and reattach it and turn on the power. See what happens, if that does not work and you don't really use the sorter, unplug it and detach it from the copier and make a exit tray and there you go. If you do use it call for service.
Feb 07, 2008 | Canon NP 6050 Copier
Canon imageRUNNER 4570 Copier Logo
137 people viewed this question
old marine
old marine
