Question about The Singing Machine DVD/CDG Karaoke System with Single Cassette Deck Shelf System
The cd portion does not work . Need to know where to take it get it fixed
    President:
  • 1,187 Answers
What doesn't work about the CD?
If it takes a CD, but doesn't play it, then the laser lens may need cleaning. Radio Shack has a CD laser lens cleaner disc for $13.
Get it and read & follow directions. It won't harm the player if it is not done correctly, so it is safe. No chemicals are needed.
Posted on Sep 30, 2009
Used isuzu radio/cd/cassette will not work in my vehichle, does it need a code?
If it works @ all it doesn't need a code - it's a bad CD player.
td
Nov 05, 2012 | 1998 Isuzu Rodeo
DVD does not work
Hi, could you let me know , the dvd drive , doesnot work at all or is it playing cds but not dvds .
Is there any error reported, when you try playing them
Thanks
Proton
Aug 11, 2008 | Televison & Video
My ps3 will not read blu ray or games does everything else fine
The PS3 laser is a 3 part laser (cd, dvd, blu-ray) the blu-ray portion of the laser has gone out. You'll need to swap the blu-ray laser out in order to fix the problem.
There are 100 different guides on the net / youtube. Just make sure you find the right one for your system.
Let me know if you need more details.
May 18, 2010 | Sony Playstation 3 (PS3) Console
I put in a cd and receive and E-00 error code. Is
Hi pcrouthamel, you may have a solution to this, but again you may not.
I have an '04 Ody and also had the E-00 error code when trying to play a CD. There are many suggestions as to what it may be and speculations as to how to fix it. The vehicle manual indicates it's a 'focus' issue.
Here is what I did based on internet research and recommendations and what occured:
1) checked both fuse #9 and #11 (pulled cleaned contacts and re-inserted) -- no fix
2) changed the battery in the Ody (is was due anyway) to address the possible low voltage issue -- no fix
3) inserted a CD, and before it was enter all the way, pulled it back out -- no fix
4) same as 3, but after pulling the CD out, gave the upper portion of the CD player a few firm bangs (literally - crazy I know) -- no fix
5) pulled the dash off (way easier than you may think) and removed the radio; pulled the top plate off to see if there were any obstructions within the unit such as coins or other material; shook it to ensure there weren't things I couldn't see; used a Q-Tip and worked it over the lense to clean it; tried another CD - no fix
6) in addition to 5, just as I inserted the CD for a second time, and while it was fully loading, I gave the heat conductor plate on the back of the radio several firm hits with the heel of my palm -- it worked!!
Apparently, there is more to the 'focus' issue than the vehicle manual leads you to ascertain. Like many DVD and CD players, the laser runs on a carriage. Sometimes this carriage can become misaligned; perhaps from hitting a pot hole too hard. My movement of the carriage while the CD was loading, had put it back in alignment. Now my CD player works.
Hope this helps.
Dec 05, 2009 | 2003 Honda Odyssey
My cd-rom drive keeps on opnening and closing?can you help me? i remove the IDE cable but it still opens and close...TNX
Dude CD ROM's are designed to close all by themselves in case if there is anything stuck in between,just unplug the CD Rom,and u might find a small hole,kindly punch in it using a pin so that the front portion of cd rom will open and clean up the entire drive using a soft brush(b careful about lens present inside)and fix it back and check out whether it works out
Nov 10, 2009 | LG CED 8120B CD-RW Burner
Top refrigeration portion smells like something is burning, warm temperature on top portion, bottom freezer appears to be working, unplugging and switching circuit breaker does not resolve problem, smell...
I need to let you know that your refrigerator may fall under a consumer alert. It is possible that the lights are remaining on while the doors are shut and can result in property damage. The issue is the light melt the plastic and damage the refrigerator, food and possibly smoke damage. If this is not the case please let me know and I will assist you if there is something other that this causing the problem. Thanks Sea Breeze
Oct 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Can't re-install my printer
remove everything (printer wise) through the device manager. reboot with the printer attached. see if windows will install it without the CD. (What version are you using)
If windows asks for the CD and will not go on without it ... insert the CD and see what happens
Let me know what happens
a
Sep 22, 2009 | HP Office Equipment & Supplies
CD will not play in 2000 Toyota Echo AM/FM/CD/Cassette stereo
just replace the CD unit it with a new one...many of the new ones also play mp3 cd,s.....thats a plus
Jun 27, 2009 | Car Audio & Video
CD OPTION NOT WORK
you may need to check the belt or gears that open the tray i have had a simular problem with a few concoles and cd plaers my self
if u can not acces the tray ejection mechanisum u may need to take it to an electrical repair shop
Oct 02, 2008 | JVC MX-D302T Shelf System
Just up and quit
To get the cd's out, remove the screws on the side and rear that hold the top portion on (might have to take side panels all the way off to access screws under the top edge...). Lift lid and Ta-Da!! CD's.
Sep 11, 2007 | RCA RS2640 CD Shelf System
The Singing Machine DVD/CDG Karaoke System with Single Cassette Deck Shelf System Logo
194 people viewed this question
Top The Singing Machine Audio Players & Recorders Experts
 Grubhead
Grubhead
phil
Tom Chichester
Are you a The Singing Machine Audio Player and Recorder Expert? Answer questions, earn points and help others
