Question about Zojirushi NS-JCC18 Neuro Fuzzy 10-Cup Rice Cooker
The cooker doesn't work. Message "E02" is displayed on the display panel. What could cause this breakdown?
  • 1 more comment
  • mario31656 Sep 30, 2009
    Thank you 88Smokey. I'll hope and wait for further assistance before sending it to the service center.
    Thanks for your input. I can concentrate on the power circuit troubleshooting.
    President:
  • 1,462 Answers
If you get E02, there is problem with the power circuit of your rice cooker, You should take it immediately to Zojirushi center to service it..
THe power surge is the cause for this issue..
Please leave me comment, if you need further assistance
RNJ VINODKUMAR
Posted on Sep 30, 2009
  • 708 Answers
The manual says you have to contact customer service or the store where you purchased and gives no other information
sorry
What does it mean when there is the letter P in the display panel where the time is counting down?
In an electric pressure cooker, it could mean that the device is under pressure and be careful. It is pressurized with steam and you can be severely scalded if you don't follow the proceduires and release the pressure before opening. Consult the manual that came with it or seek it out on-line.
Feb 28, 2016 | Kitchen Appliances - Others
Would the cooker display panel glass "Just break" when cooking?
The glass is toughened glass and sometimes the heat treat is not even. When this happens, heat stresses can cause it to shatter or if the mounting is pinching on one side.
What is the make and model and I will see if there are any parts available?
Aug 18, 2015 | Ovens
What causes my 1998 Jaguar XK8 not to start when initially cranked and the Fail Safe message is displayed?
Is the check engine light displayed? If it is, that's where you start, by retrieving the fault code(s). If not, then you could have a security system fault, fuel system breakdown, etc. All codes, regardless of the systems affected, will cause the vehicle computer to immediately default to a failsafe mode, till the problem has been fixed, and this drastically affects driveability, causing no-start issues, idle problems, etc.
Mar 03, 2015 | 1998 Jaguar XK8
Error code 1 and 3 on my Precor 9.21s treadmill?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Precor Error Code 03 E03 EEPROM Test Error
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
Hello, I have a Sanyo ECJ 18F Micom Rice Cooker, and today when it was cooking vegetablaes rice the display desappear, only appears half a seven, I unplugg and now on the display doesn´t appear...
Hello I had a similar problem with that same cooker, there is a power IC with readings AC05E that controls the screen and the power of the rice cooker. Get a replacement of that ic and you are good to go.
Oct 15, 2010 | Sanyo Kitchen Appliances - Others
After about 5 minutes into a wash cycle, the error "E02" is displayed and the wash cycle stops. What does this error message mean? It isn't in the book that came with the washer.
I just had this problem. My water supply (hot ) had been turned off since my husband used it to fill our hot tub. Other causes were-supply hose kinked,strainers in supply hose clogged, water pressure too low. Hope this solves your problem!
Jan 09, 2010 | Bosch Nexxt 300 Series WFMC2201UC
My Wolfgang Puck pressure cooker shows 'E4' in the display.
There doesn't seem to be any legit way of fixing this. I tinkered with the pressure sensors and valves, kicked the pressure cooker a few times, still the E4 error presented itself.
I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this.
The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook.
Pics of process:
http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
May 10, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Zojirushi NS-JCC18 Neuro Fuzzy 10-Cup Rice Cooker Logo
95 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
