Question about GPX PDL705
Get display : NO DISC or BAD DISC
When disc is inserted I get a display of either: NO DISC or BAD DISC . The DVD player is GPX Model D2816
    President:
  • 1,187 Answers
Probably the laser lens needs cleaning.
Purchase a laser lens cleaner disc at Radio Shack ($13). No chemicals are involved.
Read & follow the instructions. It cannot harm the player if not done right.
Posted on Sep 30, 2009
3 Suggested Answers
SOURCE: GPX d2816 problem
hey i know what it is ...i had the same problem and i took the top off and found the whole carriage for the disc inside has slotted holes and is adjustable.i simply moved it around until it worked then tightened it into place. hope that helps...... good luck badsdaddy
Posted on Aug 21, 2007
  • 4234 Answers
SOURCE: my gpx dvd player model
Either the lens is dirty or the optica are starting to fail. If you can gain acces to the optical assembly, try cleaning the lens carefully using a cotton swab and alcohol. If that fails to resolve the problem and you are able to read CDs but not DVDs, the optics are failing and need to be replaced.
Dan
Posted on Jan 05, 2009
E disc it doesn't rI have a gpx DVD player D200B and when I insert thecordnize it. Says
see the next remedies:God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours
Jul 21, 2012 | GPX Televison & Video
Gpx users guide
GPX has multiple models. LBrown18062@hotmail.com
D108S GPX D108S: User Guide D1307 GPX D1307: User Guide • Specifications D1816 GPX D1816: Specifications • User Guide D1816SIL GPX D1816SIL: User Guide • Specifications D200B GPX D200B: User Guide D2816 GPX D2816: Specifications D2817 GPX D2817: User Guide • Specifications P PC308B GPX PC308B: User Guide • Specifications
Feb 04, 2012 | NEC Televison & Video
What's the code for the gpx dvd model 2816 to the rca universal remote
Hello
Remote code for GPX dvd with RCA RCR 311B remote is 3368. OK.
Jun 28, 2011 | GPX D2816 DVD Player
Why does it read bad disk? i've tried two disks, that work perfectly on another DVD player. But reads as Bad disk on the GPX D2816
its the disk laser sensor is to sensetive that why it canot reads with an ordinary disk or a pirated disk or a disk that has a small scratch.
Nov 07, 2009 | GPX D2816 DVD Player
GPX MODEL D2816
I heve worked with so many DVD players including playstation2 a while back. Almost all the time this problem is caused by a bad laser diode assembly. You can order one for your particular model, but they are not easy to replace, even for an electronic guy like me. A mechanical talent is a must.
Jun 29, 2009 | GPX PDL705
My gpx dvd player model d2816 keeps saying bad disc even with new disc
Dan
Jan 05, 2009 | Televison & Video
GPX Portable D.V.D Player : No Disc/ DIsc Error
I check the motor. for sping its good. clean the liner eye it's good also check for bad hardness connection it,s with um meter. ok what can it be
Oct 12, 2008 | GPX PDL705
DVD player door won't open
took out the dvd player and inverted it and pushed the advance disk button . There was a disk stuck between the disk slots. The door opened and I removed the disk.
Sep 20, 2008 | GPX D2816 DVD Player
GPX d2816 problem
Aug 19, 2007 | GPX D1816 DVD Player
GPX PDL705 Logo
308 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
