Question about Gateway FPD2275W LCD Monitor
22-inch Wide screen X2Gen LCD Monitor
I have a 22" wide screen X2Gen LCD monitor. The monitor suddenly wnt blank (black) with nothing to display. The power is on and blinks between green and orange but no display. How do I fix it? It is only 8 months old.
Thanks
e-mail:
smanuel@accentCare.com
sonny-bob@cox.net
  • 2 more comments
  • dhaff Apr 08, 2008
    turn power on the word ACER flashes then screen goes blank.
  • hajami32 May 01, 2008
    I have the same problem with my X2gen monitor. how do I resolve it?
  • Anonymous Aug 20, 2008
    X2gen will not display and power button flashes between green and yellow, with a little sound click each time.
  • agent_009_87 May 11, 2010
    I had a problem that sounds a lot like this. I would turn it on and it would flicker then go off, but the power light would stay green and if you put a flashlight to the monitor you could see the image was there. This suggests that it is the backlight or the backlight inverter. On mine it was the backlight inverter. The backlight inverter is the chip that has a plastic shield over it. I removed the two 220uF25V capacitors and one 47uF35V capacitor and replaced them with two new 220uF35V capacitors and one new 47uF35V capacitor. It works just fine now. Be sure you get the polarity right when soldering in the new capacitors. It is marked by a shaded in half of the outline on the board and a line on the new capacitor. This was on x2gen 19inch wide screen though so check the specs of the capacitors on yours first. They all together cost around $5 at Radioshack.
I had the same thing happen. The power adapter needs to be replaced.
Posted on Aug 23, 2008
  • 383 Answers
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Posted on Dec 20, 2007
17" Sony SDM-S74 goes blank after 1 hour
Here is my possibility.
Sorry to be the bearer of bad news but the fact is you have a very old monitor. My research tells me that it is almost 10 years old.
The obvious problem and the one most likely is that the power board inside the monitor is going. It is common in LCD monitors of this age. Do yourself a favor and junk it and replace is with a new larger better monitor. They are so much better these days and so much much cheaper.
You can get a 22 inch wide screen monitor on Walmart.com right now for $104.00 and pick it up at your local Walmart with free shipping. Not advocating Walmart necessarily just pointing out. Recycle your old monitor responsibly and pick up a new one. No matter how cheap it is it will be better than what you have now and your current monitor is not worth a technicians time.
If you don't have the money for a new one go to your local thrift shop and get a working 17 inch for $20. Good luck.
Walmart V7 22 LED Widescreen Monitor Black
Nov 02, 2010 | Sony DELUXEPRO SDM-X73/B (Black) 17" LCD...
Screen goes black but power light stays on
Hello. I had the same problem with my X2gen 19" (model MW19R)monitor. In my case, the monitor would turn off after 20 seconds or so but the blue power light would stay on as well. I had to replace a high voltage capacitor located in the backlight power supply board. There are 4 blue capacitors on the board which are identical and they are marked as 27J 3KV. Fortunately, I only had to replace one of these capacitors ( it was turning a yellowish brownish color ). Hope this helps.
May 30, 2009 | X2Gen MG19VT 19" LCD Monitor
There are 2 inches of black space on both sides of my screen.
There should be a way to go into the screen settings on the set (either from the remote or on the bottom of the screen). From that menu you can adjust the size of the screen, stretch it, align it, etc.
May 04, 2009 | Emprex LM2201 22" LCD Monitor
Black screen. Power light binking from dim to bright
I have exact same problem but mine happened to 2 of my x2gen monitors at the same time,really strange.
One was purchased 01/07 and the second 04/07
Took my PC in, no problems
Took one of the x2gen in,was told monitor is bad
How could both monitors go bad at the same time???????
Mar 20, 2009 | X2Gen MW22U Monitor
Acer 2410 display having 3inches wide black vertical line at the right end
Hi...there,
The problems.. your panel are damaged. Don't bother to replaced...will cost you a lots of $$$.... It's time for retired...
Oct 14, 2008 | Acer Refurbished 11 3 STN LCD DISPLAY **...
19 inch wide Tftlcd monitor FV926w comes on then goes black
There is power problem in your monitor maybe in the high voltage section. maybe there is capacitor that leaky that cannot hold the power. Need to bring this to the expert technician to fix it
Apr 15, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen 19 inch LCD Monitor problem
Its the problem of the main display board. Not the SMPS. There will be another board inside. You have to replace the board or If some body may fix if you have spare parts of the board.
Apr 11, 2008 | X2Gen MG19MY 19" LCD Monitor
There is a 4 inch wide back vertical strup down the diplay screen
It is probably be a faulty LCD crystal, or a bad internal connection where the electronics meet the LCD. I would think it could happen if the monitor is jarred or dropped, I guess it could occur also if the monitor was brought in from the cold weather and condensation occurred inside?
Unless you have access to a trained LCD technician, your only option is return the monitor for exchange or repair, or buy a new one.
Apr 03, 2008 | Westinghouse LCM-19v1 Monitor
Philips game trouble
When your game first loads. Enter the games settings and adjust the screen resoultion to match your wide screen monitor. If you can't get that far than hook up that other monitor. Load the game & enter it's screen settings (display) & adjust the resoultion. Your new monitor is wide screen. Your game needs to match the wide screen as well.
Good Luck!
Mike
Mar 29, 2008 | Computers & Internet
Gateway FPD2275W LCD Monitor Logo
540 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
