I have a Lexmark X4850 that I am running wirelessly and using Lexmark 41a and 42a cartridges. I recently had these cartridges refilled by a reputable remanufacturer in town and now when I send anything to print from the computer, my documents only print in black & white. If I make a copy on the printer the color works fines. We have also placed these cartridges in another printer and all color prints fine. (So we no it is not bad cartridges.) But for some reason with my printer, I cannot get any color when I send a print command directly from the computer. Can you help me with this?
  • tommy445 Sep 30, 2009
    Actually, me remanufacturer does give a guarantee on the cartridges that he refills. It is clearly not an issue with the cartridge, if i have no problem when I am making a copy on the same machine but get no color on the same machine when sending a print from the computer. I understand all of the aspects of using refilled cartridges and the electronic aspect, but this is clearly not a cartridge problem.
    Can you provide any help with this issue. I have identified that this is not a cartridge issue. Do you have any suggestions?
    Thanks
  • 555 Answers
Sounds like the configuration on the printer is set as "Black & white only)". Go to printer properties, click the tab "Color" and check if "Only back cartridge" is selected.
For more step details:
Click START
Click CONTROL PANEL
Double click PRINTER AND FAXES icon
Right click to the printer icon and choose PROPERTIES
Check if there is a TAB named as "COLOR" and choose Color printing. If there is not such tab, click "Device settings" tab and select COLOR & BLACK cartridges.
(If no color tab nor "device settings" have such setting, click each tab to determine where the color cartridge can be enabled.
Hope it helps, good luck !
Posted on Sep 30, 2009
  • Jose Pino Sep 30, 2009
    That is correct, this is not a cartridge issue, It's a configuration issue (at printer properties in your computer).
  • 615 Answers
When you refill the ink cartridges no one gives you a warrantee or guarantee of any type…as this involve lots of small sensors and the ink is not big deal, but it’s the sensors that count, and if you keep exchanging the ink with other machines that is not good idea as every time you pull it out and in again it may damage the wiring in the cartridges if it did not get inserted fully in place and in some occasions the wires gets bind or cut, etc. So if you are going to use this service more do not change the ink between units and keep them in one machine.
Now to fix this issue you may need to run and self cleaning or alignment to get some of the dry ink out from the jets. Addition to that clean the back of the ink cartridges with a soft cloth and the inside housing them do the self cleaning using the software.
If you need help with anyone then please let me know and I will help with it. Please do not forget to rate my service so we can improve on it with your help. God bless
Lexmark X6570 printer cartridge black or colour not recognised error 005, they are correct cartridges, contacts are clean, will not print test page, used diagnostic tool and quote: incorrect cartridges,...
The Lexmark X6570 printer uses these cartridges: - #41, #41A, #42, #42A, #43XL, #44XL
Follow the steps below to fix the problem: 1. Remove the print cartridge that is indicated and close the cartridge carrier lid. 2. Close the scanner unit. 3. Disconnect the power cord from the electrical outlet. Wait a few seconds. 4. Reconnect the power cord to the electrical outlet. 5. If the power button is not lit, press it to activate. 6. Reinsert the print cartridge and close the cartridge carrier lid. 7. Close the scanner unit. 8. If the error reappears, then it could be a faulty cartridge. Replace the print cartridge with a new one, close the cartridge carrier lid, and close the scanner unit.
Jul 28, 2011 | Lexmark X6570 InkJet Printer
What cartrige do I use in the lexmark 7600
Black cartridge 42A
Black cartridge2 42
High yield black cartridge2 44XL
Color cartridge 41A
Color cartridge2 41
High yield color cartridge2 43XL
Photo cartridge 40
Oct 21, 2010 | Computers & Internet
My Lexmark 4800 version x4850 says there's a cartridge missing!
This can be one out of two things. Either a faulty cartridge, or the cartridge holder. If you still have the old cartridge, insert that one. If now it only displays 'Cartridge Empty', it means that the printer can see the cartridge, and it's your new cartridge that is faulty. If it's still showing Cartridge Missing, it's most likely your printer that is faulty. In either case, you should contact Lexmark Technical Support and they'll provide you with a solution.
You can also try cleaning the contacts in your cartridge Holder with a dry cloth.
Mar 28, 2010 | Lexmark Wireless X4850 All-In-One Inkjet...
Refill ink for Lexmark X4850
I have a couple questions for you.
1. Is your cartidge 42 or 42A? The 42 cartridge will not work if you refill it. I learned that the hard way after paying to have it refilled and I got it home and it would not print. If you are using the 42A refillable cartridge, your ink levels will not reset. I called lexmark to ask them after not bieng able to find any answers online. He said that because I am using the 42A, it will print but will not register the level. The only downside is I have to keep an eye out for fading so that I do not ruin the printer heads.
I hoped this helped.
Oct 11, 2009 | Lexmark All-in-One Printer with PictBridge
Lexmark x4850. swapped oem with non-oem black cartridge. will not print black now. message says warranty does not support non-lexmark and prints blank pages.
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Oct 01, 2009 | Lexmark Office Equipment & Supplies
Using a refilled ink cartridge on a Lexmark x4850
Yes, most Lexmark cartridges as well as many other manufactures use something called 'Smart' Chips in the bottom of the ink cartridge. Usually unplugging your (about 10 seconds) printer resets the memory in the printer. Hope this helps!
Mar 20, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
Lexmark x4850 ink levels won't reset with new cartridge
Hi...
Silly question, but I have done this myself. Have you removed the tape from the bottom of the cartridge?
Jan 25, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
My lexmark x4850 keeps telling me that there is not a color cartridge installed after i put a new photo cartridge in.
Did you replace the color cartridge with a Lexmark product or is it a off brand new cartridge or did you refill the cartridge yourself?
Aug 09, 2008 | Lexmark Office Equipment & Supplies
I just refilled the cartrige, but it says the ink is low, My printer brand is Lexmark2400.
You may have a non refillable cartridge.
Lexmark has an interesting development with their inkjet cartridges which they began some years ago with toner cartridges. A court decision required Lexmark to allow their cartridges to be refilled. However, Lexmark would naturally prefer that you only buy from Lexmark. Thus, Lexmark has developed the following system:
  • Lexmark offers for sale two different versions of the same cartridge:
  • The regular version (#23, #24, #28, #29, #41, #42) is not refillable. It is the "Return Program" or "Prebate" cartridge. Supposedly, when you buy this cartridge you agree to return the empty cartridge to Lexmark. In return, Lexmark gives you roughly $5 off the retail list price of the cartridge.
  • The "A" version (#23A, #24A, #28A, #29A, #41A, #42A) can easily be refilled. However, the price of the cartridge is roughly $5 higher than the regular version, so most people unknowingly buy the regular version.
Jun 23, 2008 | Office Equipment & Supplies
Computers & Internet Logo
David Payne
David Payne
