Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Problem for Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
How much salt should you use in a refill of a
By antony_wills on Sep 30, 2009
how much salt should you use in a refill of a dishwasher in a hard water area
Solution #1
posted on Oct 15, 2009
Not Rated)
SpideRaY
Rank: Guru
Rating: 88%, 113 votes
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Water hardness is measured in either European °E (clarks) or in the German °dH ( Deutsche Härte) you will find this on all Bosch Dishwashers here is the comparisons for the two.
If your water is Very Extremley hard then you will need to program your Bosch dishwasher using the Code
H:06 to give you maximum protection here is a comparison table for the codes and the Clark and Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Deutsche Härte with the standard Bosch codes.
I suggest that you use Calgon Dishwasher ( Sodium Carbonate formula Na2CO3.) tablets in the dishwasher every week this is a brand-named water softner that is essential to be used in areas of hard water which causes calcification and catastrophic failure. Use both the salt and the Calgon to suit your hardness.
If you live in a soft water area then set code H:01 as the extra is not required and only use Calgon tablets once a week use normal salt or tablet for the other washes.
Hope this helps
Comments:
Oct 15, 2009
- HERE IS THE POST AGAIN WITH OUT THE EXTRA CODES SORRY ONCE AGAIN....
H:06 to give you maximum protection here is a comparison table for the codes and the Clark Deutsche Härte with the standard Bosch codes.
I suggest that you use Calgon Dishwasher ( Sodium Carbonate formula Na2 CO3.) tablets in the dishwasher every week this is a brand-named water softner that is essential to be used in areas of hard water which causes calcification and catastrophic failure. Use both the salt and the Calgon to suit your hardness.
Hope this helps
Oct 15, 2009
- If you live in the UK then here is a map showing water hardness you can why most Dishwashers fail in the South where the hard water is normally found this is the reason if you don't use Calgon products less are also sold in Scotland, Ireland and Wales
Was this helpful?
Yes
No
Popular Solutions for Bosch 24 in. SGS43C12 Classixx
Questions and Unsolved Problems for Bosch 24 in. SGS43C12 Classixx
Do you recommend Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher?
Answer
Answer
The dishwasher will not empty, the filter is clear , There is a salt compartment on the bottom of... (More)
Answer
dishes have some food and residue on them after cycle is complete. I have used a dishwasher cleaning... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
