Question about Arrow Fastener Co. Hd Staple Gun - T50
Seems like staple is stuck. ataples are not shooting ot
Electric tacker shoots, staples do not eject
jl open up the slide ,there is a spring end that pushes the staples into the head ,that sticks in the rail a small screwdriver will release it,it will get stuck again but now you know the prob.
Jan 07, 2013 | Duo Fast Duofast Carpet Pro Electric...
Not shooting the staples
Sounds as if you have got some staples stuck in the shoot.there is no safety lock.
Aug 17, 2012 | Tools & Hardware - Others
Stanley light duty staple gun loads and shoots but staples not coming out. nothing jammed as far as I can see. Should I open it up and have a look at the interior? Thank you Denise
It sounds to me like you must have a staple that has seperated and probablygot stuck in staple feed shute' I wouold carefuflly remove side plate and see if there is a staple in there crooked or if their is is small metal chip left over from manufacture.I hope this helps you.THANK.
Apr 07, 2011 | Stanley TR40 Light Duty Tacker
Arrow staple gun will not shoot it seems it is locked into place
You likely have i staple jamed in it see if you can get something that fits into the end where the staples come out and pull the bent staples out this is common even on bigger models
Nov 23, 2010 | Arrow T50P ARROW STAPLE GUN
My gun will not shoot staples after loaded I thin there is a part missing
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Hope it helps!
May 02, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
How to use a heavy duty staple gun .I have the right staple, but it doesn't seem to shoot out.
If they are correct and the gun is OK be sure you are holding it firmly to what you are stapling.
Mar 13, 2010 | Stanley Tools Staple/Brad Nail Gun
Has staples loaded but does not shoot staple. I pulled out the follower and cannot tell if there is a jam, but looking at the "output" of the stapler seems to have a staple...
I think you just answered your own question. I have had one single staple stuck at the "output" where the staple shoot out and it drove me insane for a few until I slowed my roll, took a deep breath and said, I have got to be smarter than a piece of metal here, and took a calm slow looksy. Sure enough, it was one loan staple causing a backup of the rest. I have also had issues with overloading staples which eventually makes the spring pushup rod become less forceful as it pushes the staples up for firing. Not an issue until you get towards the last dozen staples or so, which can also lead to the last staple not quite getting that millimeter push ahead, to shoot out correctly. These staple guns are like babies. Have to treat them nice and pamper them and heaven forbid you ever drop that stapler cause if dropped more than likely it will never quite be the same again. Telecom Tech 16 years.
Jun 17, 2009 | Arrow T25 Staple Gun
Stapler constantly shoots out staples even when there is nothing to staple.
There is a contact switch / lever on the staplers that engages the stapler when it is pressed. It must be stuck. locate the lever and see if that's the case, and release it if you can. just my 2 cents, because I'm a copier/fax tech -not a stapler expert :)
May 04, 2009 | Office Equipment & Supplies
Arrow Fastener Co. Hd Staple Gun - T50 Logo
23 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
