Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Cant get any power to my sensors the motor works fine the alingment is fine just no indicator light.
    President:
  • 3,197 Answers
If the light on both sensors is out you have either a bad sending sensor or the wiring to the sensors is bad. On the rear of the motor unit near where all those white wires go you will find a small LED. It may be sending a code to help you diagnose your problem. It will flash a number of times and then pause and then repeat.
Posted on Sep 30, 2009
Simpson encore 605
Yes its a top loader and cloths are distributed evenly at the moment. My problem is it will not agitate. Its like the brake is locked on. It spins fine but niether the drum or agitator move. the motor is trying but its cant over come the brake (i think). I have had the brake arm off but I am unsure if it needs alinging with the brake tang when putting it back together ?
Jan 05, 2014 | Washing Machines
Was driving 2002 ford ranger when engine died,lights work,no clicking from starter,could it be the clutch sensor?
The clutch sensor would not cause the dying problem. If you have dash lights that is not an indication that the battery is ok sine they require almost no voltage to turn on. Try your headlights with the key on and see if the dash light dim. This would indicate a battery/charging system problem. Also note if the battery light comes on when the key is turned on. If the other lights work but the battery light does not it indicates the alternator has a problem. If all the lights work fine check for power at the clutch switch which contacts the cluths pedal arm higher up the pedal. Should have power to and thru the switch when cranking.
Dec 11, 2013 | 2004 Ford Ranger
I have a Sportsart 1050l give's error 1?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
ERR1 Definition: The display board CPU didn't receive the optic sensor signal. • Explanation: After processing by the drive board, the optic sensor signal travels the 16-pin cable to the display board CPU, which determines motor speed. Components involved include the optic sensor, optic sensor wheel, 16-pin cable, drive board, display board, and connections.
ERR1 Condition: Press speed key; walk belt doesn't move; ERR1 appears. 1. Drive Board a) Inspect drive board components for signs of damage, like bulging, burnt or cracked spots. b) Inspect connections to the drive board, including the ribbon cable (at the display and drive boards), drive motor, incline motor, etc. loose connections are a common cause of ERR1. c) Check the drive board lED Turn on the unit. The should be lit. The EMG indicator should light up and then extinguish after the unit powers up. A lingering EMG light indicates drive circuit trouble, but it can also light up if drive board connections to motors and other components aren't secure. d) Test whether the drive board is sending power to the motor. Put the muttimeter to the DC setting. Disconnect the motor M+M- wires from the drive board. Place probes on the drive board M+ M- terminals. Put the treadmill safety key in place; turn on the power; walk on the treadmill so that the ClK lED lights (this preempts the display from detecting no optic sensor signaling and immediately giving you an ERR1 message, thus allowing you to get a power reading); press the speed up key. The meter should show some voltage. If there's no voltage, inspect the ribbon cable and display board. If they appear OK, suspect the drive board. e) Test drive board components for a short. See Components in the Basic Electronics. 2. Ribbon Cable a) Check the ribbon cable and its connections. Link a spare cable from the drive board to the display board, outside the unit. Test the unit. If it works with the spare cable, replace the original cable. b) Or, if you don't have a spare ribbon cable, test ribbon cable continuity. Wrap solder wire around each probe so you can insert probes into the ribbon cable connector, testing one wire at a time for continuity. 3. Display Board a) Press down on the display board ICs. If you have a working unit of the same kind, swap the display board onto this unit. Test. If all works well and no ERR message appears, replace the original display board. a) Reed Switch (Applies to models with magnetic safety keys only.) Put the safety key in place over the reed switch. Put the meter to the 200 Ohm setting. Place probes on both ends of the reed switch. Meter should show 0 Ohm. If the meter doesn't get a reading, replace the reed switch. 4. Treadmill Motor a) Rotate the motor. It should rotate smoothly. Grinding or sticking indicates wear. b) Check the motor brushes. Uneven wear indicates worn brushes. Minimum brush length: 1/2 inch. Turn the brushes around and reinsert them. Rotate the flywheel. If the motor grinds or sticks, put brushes back in their original position. c) Check motor resistance: Turn off unit. Disconnect the motor M+ M- cables from the drive board. Put multimeter setting to Ohms. Place probes into the motor wire M+ M- ends. Normal reading: 1 Ohm. Move the flywheel slightly and take another reading. Take a few readings, moving the flywheel slightly after each. Readings should be consistent. If the meter shows OL at any test point, replace the motor. 5. Transformer a) Put the meter to the AC setting. Place the meter probes on the transformer output wire connectors on the drive board. Turn on the unit. There should be output voltage. If not, replace the transformer. • 11XX/12XX brown-brown: 10.5VAC • 31 XXl32XXl61 XXl62XX white-white: 12.5 VAC • 6005 yellow-yellow: 11.0 VAC If ERR1 is not resolved, see ERR1 with walk belt movement. • • • • ERR1 Condition: Press speed key; walk belt moves; ERR1 appears. 1. Tachometer Wheel Make sure the tachometer wheel: a) Rotates in the middle of the optic sensor. b) Is clean and free of cobwebs and dust. c) Doesn't have broken or bent teeth. d) Is fastened securely on the motor bracket If the wheel has visible damage, replace it. 2. Optic Sensor Make sure that the optic sensor signal is getting to the drive board. a) With power on, turn the drive motor. The CLK indicator (an lED on the drive board) should light. This means that the optic sensor signal is reaching the drive board. If the ClK indicator doesn't light, replace the optic sensor. b) Push the treadmill belt while pushing speed up key. If ERR1 doesn't appear until you stop pushing the belt, and the display speed values increase, then the optic sensor is good. (On units without a ClK indicator, check optic sensor output voltage: (a) put probes on optic sensor output (b) turn the motor (c) if voltage doesn't vary, replace the optic sensor.) 3. Ribbon Cable a) Check the ribbon cable and its connections. Link a spare cable from the drive board to the display board, outside the unit. Test the unit. If it works with the spare cable, replace the original cable. b) Or, if you don't have a spare ribbon cable, test ribbon cable continuity. Wrap solder wire around each probe so you can insert probes into the ribbon cable connector, testing one wire at a time for continuity. 4. Drive Board Check whether drive board components are burnt or cracked. Check component connections. A drive board power component short usually results in a huge burst of power, making the walk belt speed dangerously, before ERR1 appears. If the walk belt moves before ERR1 appears, but not very, very fast, suspect the optic sensor. 5. Treadmill Motor a) Rotate the motor. It should rotate smoothly. Grinding or sticking indicates wear. b) Check motor resistance. Turn off unit. Disconnect the motor M+ M- cables from the drive board. Put multimeter setting to Ohms. Place probes into the motor cable M+ M- ends. Normal reading: 1-2 Ohm. If there's no reading (OL), replace the motor. c) Check the motor brushes. Uneven wear indicates worn brushes. Minimum brush length: 1/2 inch. Turn brushes around and reinsert them; rotate the flywheel by hand. If it rotates worse than before, put brushes back in their original position. d) High amp draw can indicate a bad motor. Other factors would be a worn walk belt and deck. Run unit power through a current meter. Tum on the unit. Normal amp draw at 3 MPH with no load on the walk belt is 1/2 to 1 Amp. 6. Display Board ICs Make sure that IC contacts on the display board are good. Press firmly on the ICs. Make sure you have the latest CPU version. If ERR1 is not resolved, see ERR1 no walk belt movement.
Treadmill Parts for SportsArt Belts Motor Brushes SPORTSMITH net
Sep 15, 2013 | Exercise & Fitness
Holden jackaroo manuals
Did you pull the fuses and look at them? If you just stuck a probe in there you will get power even if the fuse is bad.
May 07, 2017 | Cars & Trucks
Need to know wat oil i use, coz the oil light is on
The oil light is not an indicator that the oil level is low, its is an indicator that your oil pressure is low.
A dirty oil filter will make your engine loose oil pressure.
Of course no oil in the motor will also cause no oil pressure.
If you have the correct oil level and a new oil filter, and your oil light is still on.
Check that your oil pressure switch/sensor is working.(your oil light wire will go to the switch/sensor).
If your oil level is fine and the oil filter is clean and the oil light switch/sensor is good and the oil light still comes on, that is a sign that your oil pump isn't working correctly, and would have to be taken apart to see why.
Check the simple and less expensive stuff first, hopefully it will be one of those
Dec 09, 2010 | kawasaki GPX 250 R Motorcycles
Battery indicator light came last night. Car died...
you have a faulty alternater there is a speed sensor in the alternator that is linked to the power steering if the alternater isnt charging the steering wont work either replace the alternater and all should be ok
May 21, 2010 | 2003 Mini Cooper
Schwinn S1000 illuminates both green & red light, but no power
I am having the same problem. By all indications it looks like the motor controller is the problem. Everything else works OK. I am pulling the controller tomorrow and replacing. If that doesn't work I am junking it.
May 12, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
Door won't go down using control
Make sure to clean off the lens so there's nothing blocking signal and make sure that theres no obstructions in the way of the photo cells before and during cycle. make sure that you have power going to them by having the Amber or red light displayed at all times and make sure that the green light is present for alignment. If it works for a couple of cycles and then goes back to being non active, make sure that the tracks or the surface that sensors are mounted to are not moving as door is in operation therefore they will move out of alignment during or after a cycle and will not allowed to operate! Make sure that none of the wires going to the cells are punctured through by any Staples! sometimes it could happen and when you move the cell around it could relocate from the staple and go back to norm, then after cycle it could short out from vibration which will send wire back to hitting stable! If none of these are helpful and you want a quick fix go down to your local home improvement store and buy a set of photo cell/safety cells and wire them up as diagram displays which is very simple and easy.
Mar 17, 2017 | Sears Craftsman LiftMaster Chamberlain...
Vibration under seats frount seats 2006 ford escape
sounds like an engine mount loose or out of alingment check motor mounts
Aug 01, 2008 | 2006 Ford Escape
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
52 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
