Trying to remove the keyboard on a sony vaio vgn-fz145 laptop
  • 19,396 Answers
On link below there is disassembly procedure. The website is illustating repair for a different problem, but procedure to remove keyboard on steps 1 to 9 is the same. Just follow the steps, and reassembly in reverse order to replace the keyboard.
Follow procedure below up to step 9 , disassembly procedure is the same as on your Vaio Fz145.
Here the disassembly of a VGN-FZ220.
Posted on Sep 30, 2009
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
Cant fx b4tt0n 5nt0 n40ber
Then replace the Keyboard.
http://www.sparepartswarehouse.com/Sony,Vaio,VGN-AR150G,Laptop,Keyboards.aspx
http://www.laptoprepair101.com/laptop/2008/01/07/service-manuals-for-sony-vaio-laptops-notebooks/
In the above link where it states in bold letters -
Service manuals for Sony VAIO laptops and notebooks,
,left-click on - Get it here - to the right of VGN-AR.
This Service Manual is in PDF file format. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name, (VGN-AR), it may take up to 30 seconds, before the first page comes up.
Not your laptop, but perhaps this will give more guidance, in removing and replacing the Keyboard,
1) http://www.insidemylaptop.com/how-to-disassemble-asus-ux50v-laptop/
2) http://www.insidemylaptop.com/disassemble-asus-n53s-laptop-fix-dc-power-jack/
Just follow the steps up to removing the Keyboard. These are listed just to give you more info on replacing a Keyboard, not disassembling the entire laptop.
For additional questions please post in a Comment.
Regards,
joecoolvette
[ WOW, that Keyboard is expensive! Suggest you look around for a better deal. I just posted that example to give you info. Average price SHOULD be no more than $40 to $50. Ebay? ]
May 06, 2012 | Sony VAIO VGN-AR150G Notebook
How to insall keyboard on sony vaio fs 635b
Here is the link to your service manual, the keyboard removal procedure starts on page 7. It is in full color pictures and detailed.
http://tim.id.au/laptops/sony/vgn-fs.pdf
Dec 08, 2009 | Sony VAIO Notebook
Replace a VGN-FZ320E Keyboard
Remove the battery,remove two screws that secure the cabinet to the computer,release three dintents,rotate the cabinet cover towards the lcd.Once this is removed.Remove two screws that secure the keyboard to the system.Becareful as the keyboard is attached by a ribon cable to the system which you will have to release to completely remove from the system.
good luck
Oct 20, 2009 | Sony VAIO VGN-FZ320E/B Notebook
Replace wireless card on sony vaio vgn-n130g
usually there are screws coming upward from the bottom to remove the keyboard,then you have to remove the palmrest which the touchpad is integrated into.
Apr 07, 2008 | Sony VAIO VGN-N130G/W Notebook
66 people viewed this question
jasbo
jasbo
