Question about Oregon Scientific Electric PTO Clutch for Exmark and Warner
Pto wiring diagram for garden tractor
I have an older Ford LT12 garden tractor w/ a Mv18 58520 kohler engine. I have to have the PTO engaged in order for the engine to turn over. Once started I can turn PTO off
  • 69 Answers
SOURCE: THE PTO LEVER ON A 210 JOHN DEERE GARDEN TRACTOR
I believe there is an adjustment for this. Check
www.weekendfreedommachines.com for specific info. Look in the Restoration and Repair Forum.
Posted on May 06, 2009
  • 95 Answers
SOURCE: Craftsman 26hp Garden Tractor PTO not working
If you changed the belt make sure it did not interfere with the wire that runs from the pto clutch, sometimes that belt can rub on the wire and wear through it,also if you had the clutch off make sure you aligned the steel retainer bolt that sets in the alignment hole on the pto clutch,this keeps the clutch from spring when disengaged if you don't get that pin through the hole in clutch it can push on the clutch and bind it.Also it may be possible to plug that pto switch in backwards.Also if you jumped the fuse out it may now have burnt the switch or wiring somewhere.
Posted on Jul 30, 2009
  • 4 Answers
SOURCE: PTO switch shuts down tractor
if the pto bearing is locked up it will stop a motor dead this is a common problem. You will have to get a new clutch assemble. The other thing that it could be is the deck has a locked up spindle.
Posted on Aug 20, 2009
SOURCE: electric pto clutch will not engage garden tractor -cub cadet gt1
the electric clutch jhondeere won,t engage
Posted on Apr 30, 2010
  • 394 Answers
SOURCE: DTY 4000 tractor dies when engaging pto, new
This is just a suggestion. Try pulling the choke out about one third to one half and then engage the PTO. Sometimes the air idle adjust screw port gets a tiny speck of debris in it. If with the choke partially out and the PTO engages the just grab a screwdriver and turn the air idle mixture screw counter clockwise a hair.
Testimonial: "Hit on the head with such a simple solution"
Craftsman zero turn 26 hp kohler engine new pto electric clutch does not work
Sad to say it may have never been a bad pto clutch but probably safety switch problem. The running tractor wants you in the seat, brake off, levers over your lap and not backing up for the PTO to stay engaged . There is two push button switches on each lever that lay over your lap ,one on the parking brake,one under the seat. All of these switch wires meet at the PTO switch and all have to agree they are in the position they need to be in to allow electricity to come down the wire to the PTO Clutch.
Dec 22, 2016 | Craftsman Garden
My blade will not stay engaged to mow. how do I fix the problem?
When you say will not stay engaged you are saying that it comes on then cuts off ? If you turn on the PTO and it engages and the mower is not moving does the PTO stay engaged and for how long (if OK then need to check connections for PTO ) . If it is not engaging at all then we have to look at interlocks / safety switches . Give me some Details
Apr 18, 2016 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Ford 5000 pto
i believe the lever is on the left side that operates the pto. on some models it will have a plate stating its the pto, you'll have to start the tractor, and engage the clutch, then engage the pto, and release the clutch. Others you simply engage the pto once you've started the tractor
Jul 17, 2014 | Garden
I have a 2005 poulan pro 42in 24hp riding mower, blades wont engage when pto switch is pulled
You should have a two wire plug that comes up from underneath near the front where the machines engine crankshaft is. Normally the wires are one colored red the other black with the key in the run position engine (OFF) there should be battery voltage or close to it. Which can be measured with a voltmeter. With the PTO switch in the on position. If you have voltage you have a bad electric PTO if no voltage then you'll have to check voltage to and from the switch itself. Someone should be sitting in the seat to perform the test for on many machines the safety switches won't allow the PTO to be engaged unless someone is on the machine. A wiring diagram would help you trace the wiring to the switches and PTO much easier.
Jun 11, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Kohler CH640-3075 (one year old and in a Grasshopper 720K) will not turn over. Battery charged.
check fuses first. then check starter solenoid for proper power and then this will lead you to either a safety switch issue or a power issue...
turn key on, pull pto switch... does pto engage, then your problem is at or after the key switch
Oct 08, 2013 | Kohler Engines New 20 HP Kohler Engine...
Kohler engine troubleshooting
check condition of air filters. check float level and flow of fuel to carby.
May 27, 2013 | Garden
Engine shuts down when pedal is released, and when pto is ingaged
check your Reverse Gear engage switch and PTO (blades engaged switch), either a bad switch(es) or short in wiring indicating that you are in Reverse with the blades engaged. Is there an override function so that you can mow in reverse? Check that circuit vs. the PTO and reverse gear. good luck
Mar 17, 2010 | Garden
Engine dies when engaging PTO switch on a John Deere GT235. I have replaced the seat switch and the PTO switch.
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Feb 21, 2009 | Garden
Oregon Scientific Electric PTO Clutch for Exmark and Warner Logo
667 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
