Question about Dell E173FP 17" LCD Flat Panel Monitor
Black screen monitor starts for an instant and fades to black screen
  • Dell Master
  • 5,568 Answers
If it fades linearly, it is probably the high voltage inverter for the backlight fluorescent lamp. Generally, the lamp dies over time with some flickering of it first.
That inverter is normally on a small, separate board and once the unit is open, it is easy to locate and replace.
Posted on Sep 30, 2009
ON THE high voltage inverter BOARD THERE IS A 1000MFD 16V CAPACITOR WITH HI-TEMP RATING 105DEG.C. REPLACE, SHOULD SOLVE PROBLEM.
Posted on Feb 07, 2010
My screen hs power self help feature check it is in safe mode do not know how to get it out
Posted on Feb 04, 2010
My Hp notebook screen is black,sometimes it fades in and out black to grey then to black.how can i fix it
Connect your laptop to an external monitor and switch to monitor. If the external monitor shows the desktop, then the complaint is in the lcd/led display unit means the screen. Replace the screen. If the external monitor also shows the complaint, then it is normally due the mch(media controller hub) . It comes as separate card unit in some models and onboard for some other models.Only an experienced technician can solve that issue. In some rare cases it is due to a corrupted BIOS. Reply if this helped you.
Sep 15, 2014 | HP G70-467cl Notebook Pc Lcd Back Cover -...
Laptop lcd
Replace the LCD, it's faulty.
Apr 02, 2012 | Dell Studio 15 Laptop
PB Minos GP2W screen has coloured lines fades white then black
Most likely it's graphic card problem, but also may be monitor itself. First, check the signal by connecting to TV (if yours has a PC input), then replace card if that shows the same.
Aug 29, 2017 | Computers & Internet
Screen goes on at startup and instantly fades to black.
You could possibly have your bulbs dying because it only takes one bulb thats bad to do this. 19 " bulbs usually cost around 12-13 dollars a piece, most likely there will be 4-6 bulbs in there. The other choice you have is the inverter board caps and or fuse is bad, the fuse is usually a surface mount 3 amp resistor. Hope this helps
Mar 11, 2010 | Gateway FPD1975W 19" LCD Monitor
Screen fading to black
Get your monitor repaired by a professional technician. Its due to the picture tube getting bad. these are initial stages, so maybe it can be repaired. Later you'll only have the option to buy one...
Jan 09, 2010 | Computers & Internet
Hp dv9000 switches on to show coloured lines on screen.
Hello
My first guess is that the screen circuitry has gone bad - although fixable. Use an external monitor to verify this. If the external monitor is fine then the screen circuitry is bad, if the external screen shows the same problem then the video chip or associated circuitry has gone bad. My company fixes these all the time.
Jul 28, 2009 | HP L1702 17" LCD Monitor
I have black spots on my monitor screen that seem to multiplying.
The black dot will just grow until the rest of the screen fades.
It is pixels dieing in the monitor
Jul 22, 2009 | Computers & Internet
I have an acer p241w and half the screen is faded almost to black right side barely visible eventually turns all black. I turn monitor off and right side comes back on but left side is faded to almost...
HELLO I CAN HELP WITH YOUR ACER THE PROPLEM YOU GOT IS THAT CONDENTSATION HAS GOTTEN IN TO YOUR PC OR LAPTOP AND HAS GOT ONE OF THE CERCITS WET TRY THIS PUT YOUR PC OR LAPTOP IN TO YOUR AIRING COBORD FOR 24 HOURS AND THAT SHOULD RESOLVE YOUR SCREEN PROPLEM
Jul 14, 2009 | Acer Computers & Internet
MY SCREEN KEEP popping to black?it annoys me?
so is your screen like fading to black and back to bright when u do something? If it fading in and out try adjusting the monitor settings on the monitor itself. Whats happening is your monitor is trying to save energy so it dims. The setting is Luminance on most monitors
And by the way u cant reach a video capacity cause the memory dumps the info when it needs space to process more video.
May 23, 2009 | Intel Motherboard
TP50G90-screen will fade to black and then instantly power back on every 8 seconds
power board problem needs a shop fix or new transformer without a test you cant tell.....
Aug 08, 2007 | Toshiba TP50G90 50" Rear Projection...
Dell E173FP 17" LCD Flat Panel Monitor Logo
449 people viewed this question
Alun Cox
