Question about Hoover U5507900 Elite Rewind Bagless Upright Vacuum
Loud noise coming from motor on hoover elite rewind vacuum
I am having a similar problem with my hoover elite rewind making a loud motor sound and smell. I have replaced the belt twice and cleaned the brushes of hair and checked all hoses. I do have the same suction so everything appears free from jams. Replacing the belt is not the solution, any suggestions before I tear into the motor?
SOURCE: Hoover Deluxe Elite Rewind does not pick up
Check the hose and take the bottom plate of the vacuum off to check for obstructions that you can't see right away. Use a wire coathanger (unwound) to push any clog through. I also have dogs and this vacuum. It does get clogged with fur occaisionally.
Posted on May 24, 2009
reddevil6
  • 1673 Answers
SOURCE: hoover eite rewind vacuum has blocked airflow, how do i fix?
Is there suction at the end of the hose, if not then the blockage is in the hose, unhook the hose and dig out the debris, if hose isn't blocked, then clean out the filters, if they get clogged, then air can;t flow thru them and you won't have suction. If you have suction at the end of the hose, then it is clogged down in the nozzle asm. there is an inlet by the brush roll and it comes up to where the hose plugs into. Clean the clog out.
Posted on Jan 15, 2008
SOURCE: Really loud noise.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40860&thid=810370
Really loud noise.
Posted by Theresa626 on July 20, 2008
The belt inside my Hoover broke and so we replaced it. But when we did, it now makes an extremely loud noise when turned on. We think it’s the roller to the vacuum because it doesn't make a noise when the roller is not in there. The roller sounds like its hitting something. However, we have pushed and pulled and done everything and all seems to be right. Everything is clicked in and the belt is on correctly and we've followed the manual. How can I fix this problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that it is a bad brushroll and could need new bearings or a complete new brushroll depending on if id is metal word or plastic. Some brushrolls are rebuildable and some are not, you can check your owner’s manual to see if it is or is not; or it could be the start of a broken fan blade or bearing in the motor section. But that is the only thing that I can think of that might be wrong. Feel free to contact your local vacuum cleaner dealer in your area or you can also contact the Hoover website or cust serv phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 21, 2008
  • 120 Answers
SOURCE: NO SUCTION COMING FROM BOTTOM OF VACUUM
even though the belt isnt broken you should replace it also make sure the height is raised up on the nozzle. try dropping a marble through the hose to double check there is nothing stuck ( the attachment hose and the small hose that runs to the floor )
Posted on Sep 18, 2008
  • 294 Answers
SOURCE: carpet setting not working
there is a belt in the nozzle that is driven by a small motor in turn will drive the roller when set to carpet. did you completely dis-assemble the nozzle? ie, to remove the roller and clean the endcaps? this would also show the belt. The gear on the motor wears very easily and could also be worn. I would change the nozzle or get a new Flair. new nozzles cost about $25-$30.
Posted on Jan 17, 2009
How do i repair a hoover elite rewind broken belt?
You can't repair the belt. It must be replaced. A new belt must be stretched to almost twice their original length to be installed. They will lose elasticity and should be replaced at least twice per year for proper cleaning of carpets.
Apr 27, 2014 | Hoover Vacuums
Samsung vcu366 making loud noise but picks up
what does the really loud noise sound like? Is it a loud, whining sound? if so, the motor may be getting ready to go out. Also check that the belt isn't stuck-though you would smell burning rubber if that were the case.
Mar 08, 2014 | Samsung Vacuums
Hi, I just replaced my belt for my Hoover Upright Futura with replacement belt 38528040. Now it is making a very loud noise with a lot of vibration. What would be the cause? Could it be the new belt? It...
It is not likely to be a belt problem. I would remove the belt and brush assembly, turn the vacuum on, and see if it is still loud. If it is, the motor fan is broken and will need replacement. If it sounds normal, the problem is in the brush assembly. Examine the ends of the brush for damage or play in the bearings. The brush may need replacement ( part # 48414081 )
Jul 26, 2011 | Hoover U5227-930 Elite Upright Vacuum
Hoover H3030-006 240 V Motor making a loud sound and burning smell
If you have little to no suction, that sound is happening because you most likely have a clog some were in the vacuum.
smell is probably your motor over working itself do to the clog.
also double check your belts on your brushes that they are moving with the motor. smell and sound could come from the brushes being jammed which would cause the belt to freeze and heat up and could burn the belt and or your motor.
if it is still running though your not in the red yetm so triple check that the machine is cleared off all clogs and jams in the belts and brushes.
Jul 02, 2011 | Hoover H3030 FloorMate SpinScrub 500...
Vacuum shaking badly right up to handle and very loud noise
Could be a broker motor retainer. There should be two motor retainers in this model, when one is borken, it causes the unit to
shake and vibrate.
May 13, 2010 | Hoover U5507900 Elite Rewind Bagless...
My HooverDeluxe Elite Rewind became extra loud
If the belt is really worn it can cause that. I wold try changing the belt if you haven't recently. Here are the belts you need:
Hoover Elite Rewind Belts
Nov 14, 2009 | Hoover U6630-900 WindTunnel Bagless...
My vac is really loud now is that the belt??
Sounds like the brush roller is worn and making noise, take the complete vac to the repair shop for service. I've seen this cause damage to the front nozzle housing as well.
Oct 13, 2009 | Hoover Elite Rewind Bagless Upright Vacuum...
My hoover elite rewind is making a louder noise and I can smell something burning when I use it. I have replaced the belt but this did not help.
the smell is either the motor or the belt, if motor hope it is under warranty, if belt make sure brush roll spins freely and replace belt, if brush roll not spin freely replace it first
Aug 27, 2009 | Hoover U5507900 Elite Rewind Bagless...
Sep 07, 2008 | Hoover U5507900 Elite Rewind Bagless...
Hoover U5507900 Elite  Rewind  Bagless Upright Vacuum Logo
674 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
