Question about Hotpoint Dishwashers
DRAIN HAS STOPPED UP,HAS USED DRAIN-O BUT IT DIDN'T WORK
My triton t80si no water comming out of it, what could be the reason, light every thing is on,?
Posted on Sep 30, 2009
Ice buildup by evaporator fan down into drain in back of unit. I melted ice using steam and heat, but it has happened 4 times.
Your defrost id not working, you didn;t leave a model so that is all I can tell you now
Mar 26, 2016 | Refrigerators
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Water won't dispense
Which pump did you replace? Are there a few?
May 13, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
My whirlpool washer, model # WTW5100vqo stopped working between the drain cycle and the spin cycle. It didn't groan or make any strange noise, but simply stopped. I checked the electric cord and the...
SORRT TO SAY...BUT, YOU WILL MOST LIKELY NEED TO CHECK OR REPLACE YOUR BELT! THEY CAN SLIP OFF AND NEED TO BE RE-TIGHTENED, AND THEY DO WEAR OUT, WHICH WOULD NEED TO BE REPLACED!
HOPE THIS HELPS!
Sep 07, 2011 | Whirlpool Kitchen Ranges
Hi, I just purchased this used. It was working fine for one day, but now it won't turn on. Can u help? Haier CPN12XH9 12000 BTU Portable Air
If the water collection tank is full, it will not turn ON. Since you said the unit worked fine for one day and now it won't turn ON, more than likely, that's the problem. After draining the tank, the unit should reset itself and turn ON like it should.
The drain plug is on the rear of the unit, just above floor level. You can either drain it into a low sided pan or bowl that's capable of holding up yo a quart of water. O r roll the unit to a floor drain or outside to drain it. If you choose to drain it into a pan, turn the unit OFF & unplug it, before draining it.
I hope this helped you and thanks for choosing FixYa
Jul 25, 2011 | Haier CPN12XH9 Portable Air Conditioner
I have 2 Samsung AW0700/XAA air conditioners that leak water all over floor. We've tried tipping them to get water out but didn't work. How do we stop leak?
inside the unit on the left side of the evaporator coil there should be a channel that allows the water to drain to the outside of the unit and cool the condenser coil use compressed air to clean this channel (a.k.a. keyboard cleaner) were safty glasses and make sure unit is unplugged then check drain to make sure it is clear before running the unit.
Jul 22, 2011 | Samsung AW1893L Air Conditioner
Dishwasher is not draining or completing its cycle. It had a series of beeps and then just stopped working (didn't take any notice of the beeps at first) Now ll the lights come on and when you push a...
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a dish-washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Jul 14, 2011 | Dishwashers
Maytag neptune MAH5500BWW front loader didn't drain after a wash cycle. first time wife put it on spin for a few minutes and it drained, no problem. A week later that didn't work, code...
Yes you need a new control board. The fact that the motor and impeller was damaged and loosened. You should try taking your Washer in for maintenance check or call the repair man.
Jun 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
I replaced the drain motor since when using the manual function test it didn't drain and the pump was silent. After I changed the pump but before I put the dishwasher back in the cabinet I tested the...
Make sure the wire harness is secured properly to the pump . Also just make sure the drain line is clear. If this is not the problem most likely the control board needs to be replaced.
May 05, 2011 | Maytag MDB9600A Jetclean II Built-in...
Dishwashers Logo
111 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
