Question about Astatic 636L Noise Canceling Microphone Microphone
How many watts is a tristar 120? - Astatic 636L Noise Canceling Microphone Microphone
  • 5,603 Answers
4 watts MAX output. The Max input to final stage is 5 Watts by FCC rules. With the efficiency, you should get between 3 and 4 Watts output.
Posted on Oct 02, 2009
    President:
  • 1,187 Answers
A Tristar CB radio cannot legally exceed 4 watts of transmitting power.
You can add anetnnas in order to increas the "gain" to have the equivalent of much more transmit power.
Microphones aren't measured in watts.
The "impedence" (amount of resistance) is the important measure.
Posted on Sep 30, 2009
I have steamvac 120 V 60 HZ 7.9 A im going to use in my country Argentina 220 V 50 HZ input i need a tranfo 220V 110 V and who many watts?????
220 volts at 7.39 amps = 1738 watts
120 volts at 7.9amps = 948 watts so any unit capable of 1000 watts at the 110 volts will do the trick
Jul 11, 2017 | Audio Players & Recorders
Tip
What size of inverter do I need?
The correct size of inverter is an easy calculation and important to ensure long life from the inverter and the life of the appliances getting there power from the inverter. To calculate you take the volts and multiply by the amps which equals the wattage. Every appliance has a tag which must state the volts and amps. Locate the tag to find the information. Here is an example.
Under Counter Refrigerator 1.3 amps (120 volts x 1.3 amps = 156 watts)
Microwave (120 volts x 10 amps = 1200 watts)
Alarm Clock Radio (120 volts x .03 amps = 3.6watts)
TV (120 volts x .6 amps = 72 watts)
You now add all the watts together, since the above list could likely be running at the same time. There is a combine wattage of 1431.6 watts. In this example you would need at least a 1500 watt inverter. However given some unknown variables personally I would get a 2500 watt inverter. Less stress on the inverter, will lengthen the life of the inverter. Had the total been 1,000 watts a 1,500 watt inverter would suffice.
You must also remember that your alternator on your vehicle must be able to keep up with the power demand of not only your vehicle needs but your inverter needs as well.
on Apr 23, 2010 | Electronics - Others
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
Does it matter if bulb #bp96-00224ep is 100 watts or 120 watts?
Lamp for Model# HLN617W is BP96-00224B or BP96-00224J 120 watts Look on Ebay < I got my Lamp for $85.00
Mats 1-800-628-1118 for lamps
Nov 16, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Dont know what the difference is between lamps
these are Panasonic arc lamps .. the numbers 100-120 indicates the intended voltage range of operation .. the /1.3 or /1.4 is the current in amps .. so the 1.4 is slightly higher current and likely a bit brighter .. thats 156 watts vs. 168 watts .. arc lamps are much more efficient than incandescent so 150 watts in an arc lamp is a lot more light than a 150 watt incandescent...
Sep 04, 2009 | Mitsubishi WD-65000 65" Rear Projection...
Wattage for Kirby Sentria G10D
The conversion of Amps to Watts is governed by the equation
Watts = Amps x Volts
For example 1 amp @ 110 volts = 110 watts
your case 7 amp @ 120 volts = 840 watts
unless you are running it at 230v but I don't think you can
I would look for one rated for Volt-Amps instead of watts
It's best to round up to be safe add 40 - 60 watts
Don
Apr 25, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I need wiring drigram for a tristar 120
here is info your looking for-for a 636l to a tristar 120 -is as follows-1-audio, 2-shield&blue,3-black,4-red,yellow not connected.
Feb 28, 2009 | Astatic 636L Noise Canceling Microphone...
I have a GE Profile ModelJVM187OSK04 Serial # DM902972B The bulbs went out, they are 120 volt 20 watt. Can I use a GE 120 25 watt bulb as I am having trouble finding a 20 watt??
You should be able to use the 25 watt bulb as long as they are compatible with the socket they mount in... Hope that helps...
Aug 16, 2008 | GE Microwave Ovens
Inquiries
Straight from the product's manual...
Amplifier section
Power Output-
[Stereo Mode]
125 watts per channel
[Dolby Pro Logic Mode]
Front
120 watts per channel
Rear (Surround)
60 watts per channel
Center
120 watts
Click HERE for the manual.
There you have it.
Cyryl
Nov 10, 2007 | Aiwa AV-X220
Astatic 636L Noise Canceling Microphone Microphone Logo
Top Astatic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Astatic Audio Player and Recorder Expert? Answer questions, earn points and help others
