Question about Denon DHT-FS3 Speaker System
Soundbar flashes ERR-00 continuously, switching off/on again no help; left unplugged for a few days, still error message. Woofer disconnect, plug/unplug... any other things to try? early on when new the mid/right channels worked intermittently but righted themselves - 2 months later this error has occurred. Any software/hardware fixes without returning it, anyone? JLW
SOURCE: Water spillage - display not working
You have fried some of the circuitry take it to a service dealer and have what ever is fried up replaced...
Posted on Apr 02, 2007
SOURCE: Intermittent audio output
It's quite possible one of the relays is failing that is part of the switch between audio output choices.  Do you notice any output difference between a certain output (i.e. dvd, tape etc)or is that point arbitrary?
Posted on Jan 08, 2008
tech48
  • 624 Answers
SOURCE: Denon AVR-3802 Front Left and Centre channel not working right
I work at an authorized Denon service center and have repaired lots of Denon receivers including this model. So bare with me, and trust that I really do know what I am talking about.
The first thing you need to do is find out if those two speakers may be at fault. You can do it very easy by disconnecting them and connect two of the known good speakers into the channels that the bad sound is coming from and then connect the suspected bad speakers in where those good speakers were connected to.
If the same speakers still sound bad, you know that you have a couple of bad speakers. I think that it is likely that the speakers are OK, but it is a good idea to make sure.
If the sound from the suspected bad channels is now still bad with the two good speakers, you have an internal amplifier problem or you have a problem on the digital board.
For your sake, I hope it is the amplifier that is giving you this problem, if it is, that can be fixed by a good audio technician.
If the problem is the digital board, you may be in for some real headaches. Not that many audio techs are very good at troubleshooting a digital board, its not their fault, it is just a very difficult job.
In either case, it will need to be looked at by a qualified technician.
I hesitate to tell you this, but the problem sounds like a digital board problem. In some rare cases, a technician with excellent soldering skills can reflow a couple if the memory IC's on the digital board and restore proper operation. If the technician is top notch and isolates the problem to a specific IC on the digital board, they can replace that IC and you are good to go.
But in most cases, the technician will not even bother trying to troubleshoot the digital board because it can take hours of troubleshooting, and just order the board if it is available. Most of them are available from Denon, but they are very expensive. Normally the part alone is $200 to $300 and I have seen many times where it takes months to get it.
You can also send it directly to Denon's factory service center and that will get your unit back much quicker. They have direct access to the boards, where-as the authorized service center must order it thru one of the Denon parts distributors and they do not always have them in stock. so you end up waiting for a long time.
If you need to send it to the Denon factory service, let me know and I will email you a return authorization form, this must be faxed or emialed to Denon with the proper information and then they will fax or email it back to you with the RA number which must be written on the outside of the box before shipping it to them.
I hope that this information wasn't to overwhelming, but if you found it helpful a good rating would really be appreciated. It helps to keep the experts on FixYa motivated and willing to answer the questions people have even it the answer is not very good news.
I received an "inappropriate" rating from somebody who just wasn't happy with the truth, and most people never even bother to rate our answers. But that's another whole subject.
let me know if you need more help.
Posted on Jun 22, 2008
marsrover
  • 682 Answers
SOURCE: DENON PMA520 Amp. Suspect left channel
you have malefunction in your left output stage-but can i ask you did you forget to press left speaker button in your amp (if you have one in your amp).
Posted on Jul 27, 2008
SOURCE: left channel not working
Thanks, yesterday i tried changing the speakers from right to left, the problem still remained on the speaker getting connected to the right channel. Later i pulled out the speaker wires from the reciver's end for the right channel, cut them and pulled out new strings from the insulation, twisted them and inserted, the speaker is working fine, though not 100% but close to left channel. I guess the problem was old strings in the wire which had got over twisted and were not parallel to each other.
regards
Swamy
Posted on Oct 01, 2008
How to fix error code 0.00
Hello friend, thanks for your post!
Based off the information you provided your Electrolux washer is displaying "0.00". Typically any error code that is labeled "00" means no error code stored, which means it's a false error code. I would recommend performing a reset on your washer due erase any false error codes. You can do that by disconnecting the power from your appliance, by either unplugging it or flipping the household circuit breaker, for ten minutes.
If this step does not help resolve the problem please provide me with the new error code or if your display continues to show "0.00" I would suggest seeking assistance from a professional to come out and properly diagnosis your washer. I hope this information is helpful. -Matt
Oct 02, 2014 | Electrolux Washing Machines
Err message with Nikon D70
Is there anything else than the ERR? Hold on I will have to look it up, just a moment.
Oct 07, 2008 | Nikon D70s Digital Camera
8D 00 00
When I switch-on "Mammoth" tape drive, the following error appears on the mammoth display " ERR: 8D 00 00". What is the problem and how to resolve ?
Thanks in advance.
Feb 11, 2013 | Tandberg Data Exabyte Exatape Mammoth 8mm...
Schematic for vizio vbs210ws
According to the user manual, the fourthj LED flashing (Error D) means that a thermal (heat) shutdown happened. If Error D, Thermal shutdown, is indicated, turn off the Sound Bar and verify the ventilation slots in the Sound Bar are clear, the Sound Bar has proper ventilation and is not being operated in an environment
that is too hot. If these conditions exist, reduce the volume level for the particular source content being played. My bar did this and I left it disconnected from the Ac power a full day , and it powered up the next day.
Aug 30, 2012 | Vizio VSB210WS Soundbar
Display screen flashes "CHK" repeatedly
Hello.
From FixYa Support: The "ERR" message reportedly means a memory error.
Please NOTE: This solution will wipe out the memory.
Press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again.
Hope this helps.
Apr 03, 2010 | Olympus VN-3100PC Digital Voice Recorder
Err 12 and Err 16
Dear FixYA
Was advised to send to Scales to another company to be fixed. Therefore no longer need your assistance.
Thank you
Julia
Jan 22, 2009 | Seca 354 Digital Baby Scale Pediatric...
Receiver standby/on switch is flashing and cannot turn receiver back on
Try checking your speaker cables as one of them may be touching the case of the amp,or touching another cable,this can cause a short and cause the error message.The amp is protecting itself .
hope this helps.
CABLE GUY.
Jun 30, 2008 | Pioneer VSX-917V-K Receiver
Cuisinart programmable espresso maker em-200C
Currently, both my manual and steam button are flashing. No idea why. Any help?
Feb 27, 2008 | Cuisinart Programmable Espresso Maker
ATF6700FS - Affinity? 3.5 Cu. Ft. I.E.C. Capacity Washer Won't Start
ERR=An error has been detected
PAU=Cycle has been intrupted
58=High current on motor phase
To clear latest stored error code:
• Turn the Program Knob to the start position, Spin Only.
• Press Start/Pause to start the cycle and save it.
• Press Cancel to stop the cycle and turn off the LEDs.
• Press Cancel again to turn on the LEDs.
• Within 5 seconds, press and hold the Option and Start/Pause buttons until LEDs start sequentially chasing, then release buttons.
• Turn the program knob clockwise 7 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Start/Pause buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation.
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Start/Pause buttons
together for a few seconds until wash cycle LEDs appear.
Feb 25, 2008 | Washing Machines
LOC message
This sounds like a faulty micro switch on the door catch. Try pressing inwards on the door glass at the catch area whilst you press start and hold it oressed for a few seconds until it either starts or displays the error again, if the error shows it may require a new switch, the switch can be tested by bypassing it and joining the two wires together that plug onto the switch. The switch can be accesses by removing the dor seal from the outer most edge.
Jan 26, 2008 | Washing Machines
Denon DHT-FS3 Speaker System Logo
88 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
