Question about Canon PIXMA iP5000 InkJet Photo Printer
Operators Error - won't respond to anything
When I turn on my printer it flashes one green light and then 5 orange. When I attempt to print a window pops up that says "Operator error.
Press printer's RESUME button.
If this doesn't clear the error, cancel printing and turn the printer off and then back on."
I do this and nothing happens. I have tried to unistall and reinstall the printer. I have tried different USB ports and it will not print ANYTHING. It won't do a test page, maintenance, NOTHING. It is online and everything is connected properly. I have done all the troubleshooting, and nothing has worked. ANY HELP????
  • 1 more comment
  • Scopie Jan 04, 2008
  • Anonymous Mar 04, 2008
    i have the same problem. flashes 5 times orange then once green and i have no clue how to fix it :(
  • Anonymous Jun 15, 2008
    Well hello all,
    I also have the same problem and although I tried to install and reinstall the printer head I have the same error message and same 5 orange flashes blinking at me! Should I try to look for a new printer head....did not print that much since the printer was new (about 2 years ago)
    Thanks for your help
    Tom
Something VERY similar happened to me, and simply unplugging it then turning it back on fixed it. I guess you have nothing to lose trying, right?
Posted on Jul 21, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 9 Answers
From the e-user's guide:
Five flashes: Print Head not installed / Print Head not installed correctly / Print Head is defective Install the Print Head. If the Print Head is already installed, remove the Print Head and check the electrical contacts for foreign matter, then reinstall.
After reinstalling the Print Head, you may need to realign it.
If this error still remains, the Print Head may be damaged. Contact a Canon service representative.
The simple fix with the above instructions is to make sure the contacts are clean. Dust from indoor carpeting, fireplaces, and cat/dog dander/dirt over the months can wreak havoc with contacts in gadgets not completely sealed, such as printers. Use an appropriate cleaner if they are very dirty (something made for electronic devices).
Posted on Aug 10, 2008
I think it's the "print head is not installed" code.
If you are certain it is, open the the cover and make sure the gray lever is pushed down. This sets the head against the pins in the carriage.
You also might try and take out and put back in the print head, making certain all the cartridges are installed correctly. (click into place) and try it again.
Posted on Mar 10, 2008
I have the same problem and im clueless as how to fix it :(
Posted on Mar 04, 2008
Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck....
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.For printer
Mar 22, 2011 | Canon BubbleJet i560 InkJet Printer
Canon Color Bubble Jet Printer i550 wiil not print - (greenlight then orange light blinks 8x - then green light) When attempting to print receive "Printer not responding" - "Paper thickness lever...
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Office Equipment & Supplies
Flashing orange light 5 times followed by green
I am also having this problem, would love someone to give us a solution before I through it out the window.....
May 10, 2010 | Canon BubbleJet i560 InkJet Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    My canon i 560 does not respond at all. when i turn it on the light flashes 5 times orange and once green. and it repeats this
    Generally speaking the Orange light flashes 5 times to indicate a print head error.
    Did you recently remove and install the printhead? It may just need to be reseated. The printer may also need a service repair.
    Don
    Dec 12, 2009 | Canon BubbleJet i560 InkJet Printer
    Operator Error Canon i850 printer
    Start with the printer OFF
    1. Hold down RESUME and then hold down POWER
    2. Release RESUME
    3. Press RESUME twice, then release POWER
    4. Let green light blink until printer is done futzing
    Select function with RESUME press POWER to execute:
    presses - light color - function
    Number of presses - light color - function
    0 presses - green - Test print (or exit service mode on i960)
    1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
    2 presses - green - EEPROM initialize
    3 presses - orange - Reset waste ink counter
    Dec 09, 2008 | Canon BubbleJet i560 InkJet Printer
    Canon i550 printer stoipped printing
    My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
    Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
    Canon i560
    may be ink level is too low,check it first,make sure delete the all pending documents
    regrads
    prasanna
    Mar 07, 2008 | Canon BubbleJet i560 InkJet Printer
    Canon PIXMA iP5000 InkJet Photo Printer Logo
    865 people viewed this question
    old marine
    old marine
