Question about Panasonic KX-P2023 24-Pin Impact Printer
Panasonic kxp2023 printer not printing
Printer driver installed on computer. Printer set as primary printer, when go to print a doc the doc doesn't even show up in the que list.
5 Suggested Answers
SOURCE: Panasonic DP 1520P - wont print
Hi, I have solved my problem posted 5/2/08. Download the gdi driver from Panasonic website as I did above.
Install printer via Control panel, "Add printer" and browse to locate driver. If you do it automatic through the USB it will not work. Mine WORKS now!! Do check that the paper size is A4 also.
All the best...
Posted on Nov 12, 2008
  • 224 Answers
SOURCE: Panasonic DP3030-Will not print from a computer
are you using post script? that error message appears when the firmware does not recognise the emulation. i would say you would need a firmware update on the device
Posted on Mar 31, 2010
  • 4737 Answers
SOURCE: I have a Computer running
I hope you do know that there are two windows 7 drivers for the printer, one is GDI and another is PDL. Would you mind letting me know which one you've installed?
If GDI isn't working, then PDL should work.
One more issue, if you've already install the previous windows versions' drivers for the printer, then that will cause problem in the system registry which means, you'll be unable to print using the printer. This is a very common. In this case, you'll need to uninstall all drivers or softwares related to the printer, run a registry cleaner and reinstall the fresh GDI or PDL driver for the printer.
You can download a registry cleaner from here (click here). Open the link, click the purple "Download Now" button, wait for about 20 seconds (watch the countdown timer and wait until it resets) and then click the purple "Download File Now" link, save it and install it (simple installation, just proceed forward in the manner "next", "yes" or "ok" and "finish"). After it's installed, open the program and click "Run cleaner", if you are asked with a confirmation message, click "Yes" or "Ok", wait for few seconds and click "Registry" when the cleaning is done. The "Registry" is on the left pane with blue icon, now on the middle column, click "Scan for issues" wait for another few seconds [or may be minutes] as the scanning progress runs and click "Fix selected issues" then, "No" and again "Fix all selected issues" and "close". ((Run the program after all the other programs are closed, otherwise it'll not be able to scan everything or fix all issues)) After it's done, close the program and restart your computer. Once it's restarted, again open the Ccleaner (the one you're gonna download from the above link) program and run the registry again.
When you are done, install the printer and try printing again. It should work now.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Sep 03, 2010
  • 1110 Answers
SOURCE: printer showing error message ...."printing
This means that your machine has received a print job that is teling it to print on paper that is loaded or supposed to be loaded in the bypass feed tray. You will either need to delete the print job using the operation panel or simple load some letter size paper in the bypass tray over on the right side of the machine.
Good Luck and Thank You for using Fixya.
Posted on Dec 18, 2010
  • 254 Answers
SOURCE: while i was printing my
try to check in your printer properties, advanced settings, check on PRINT DIRECTLY TO THE PRINTER.
Posted on Mar 05, 2011
0 characters
1 Points
My printer is already connected to the computer but doesn't print.
Click Start go to Printer & Faxes:
- Check that your printer name is there or not.(if not, your printer is connected to computer but the driver is not installed. Find the driver disk and install driver)
- Check that you set it as default.
- Make sure Printer is online( if not, it shows "offline" word under the printer name)
Try these if still not printing:
- Restart your computer.
- Turn off your printer completely, unplug power suppy, wait for 15 seconds and turn on again.
Hope this will help. Thanks for reading
Jul 19, 2011 | Printers & Copiers
My printer scans, copy but won't print from computer?
Did you set this printer as the default printer? To do this go to Start - Printer and Faxes, right click on HP printer, select Set As Default Printer. If you are not see your HP Deskject F340 there, that mean your printer driver is not installed. Please install your printer driver.
If you already set it as the default and it is still not printing. Restart your computer to try solve problem.
You said that printer scans so the connection between your computer and printer is fine. Problem is your computer doesn't take the printer as it's printer device yet.
Jul 19, 2011 | HP Deskjet F340 All-In-One Printer
I just bought canon mp492 all in one , trying to print word doc from memory card, but its not working
Memory cards are only for image files. to print a word document, you need to use your computer.
Jul 03, 2011 | Canon Printers & Copiers
I have an old HP 111 Laser Jet printer. Moved it to a new location and it is now giving me a first page with some numbers on it before printing a doc. How do I eliminate the wasted first page before...
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 27, 2010 | HP PSC 1510 All-In-One InkJet Printer
Biz hub 250 Pdf printing problem
Hi I am former Konica Tech Support for 26 years. I do some network problem. Y may need to upgrade the copier memory. or this just simple setting. on the printing side I can assure you no problem. there is a setting on the operation panel choosing if you prepared pdf when ever you to e-mail, scan to box or scan to SMB. You can delete the old print driver and the control panel delete your even the printer Icon at the printer and fax folder. Re install the printer and the printer driver. And make sure send a test print. If so happened that you don't have the print driver you can go to Konica web site and download the print driver. There are many kind of print driver. postscript driver and etc. I hope this info will help you and if not you may contact me again.
Aug 20, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
My Canon MP160 doesn't print emails to the bottom of the email. When it does print a word doc, it prints multiple copies and I have to manually cancel the printing. Now it is printing in gibberish. help
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
May 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Wingdings prints on Brother HL2170W
When printing using Terminal Server, the print driver needs to be installed on the server itself. If you have a printer that doesn't have the driver installed on the server, it will either not print at all or it will use the "fallback driver", which is something set by the person who administers the server. Thus, it may be trying to use an HP driver to print to a Brother printer, which won't work. Ask the administrator to install the Brother driver on the server and it should work at that point.
Feb 26, 2009 | Brother HL 5250DN Laser Printer
HP Photosmart 7660 will not print Word doc.
Instead of clicking the printer icon, select File > Print and verify the correct printer is selected.
Feb 10, 2009 | HP PhotoSmart 7660 InkJet Printer
Print size
Need to know what OS you are using - are you printing PCL or postscript. How are the computers connecting to the printer network or direct connection?
Nov 28, 2007 | OKI B4350 Laser Printer
Printers & Copiers Logo
57 people viewed this question
Top Panasonic Printers & Copiers Experts
Mohan Sriraman
Mohan Sriraman
Are you a Panasonic Printer and Copier Expert? Answer questions, earn points and help others
