Question about Garden
Gas lines fell apart and I have new ones for a ryobi 790r trimer but do not know what line goes where there are 3 hoses could some one show me or tell how to fix this trimmer??? warren9@hotmail.com
    President:
  • 1,776 Answers
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Posted on Sep 30, 2009
I have a Ryobi 790R "E Z" and need to know how to
It is not too hard. Just make sure to cut the new fuel filter line long enough so that you can get ahold of it inside the fuel tank to install the filter. The fuel return line only has to go into the tank 1/2" or more to do it's job, so lenth is not a problem unless you wish to install one of the little nylon connectors on it's end so it doesn't pull OUT of the tank. That is optional.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so
Jul 19, 2011 | Ryobi Garden
I need to know how the fuel lines are hooked up in my ryobi gas trimmer. All of the fuel lines rotted out. I took them out and I need to know the correct connection sequences (what goes where).
line runs from little filter in tank to carb.
line from carb. to primer bulb
line from primre bulb back to gas tank.
lines are 2 sizes
need to cut at angle end of lines in tank so you can get them thru holes
and grab with needle nose plyers and pull them thru.
make sure you put the little filter on end before you pull line thru and leave
enough so filter can move around the whole tank.
second line in tank is smaller and need to cut and pull it thru hole in tank to primer bulb
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Existing gas line fell aport. Have new hose but need gas line routing for Ryobi leaf blower.
http://outdoordistributors.com/pdf/Ryobi/RYOBI-700r-serials-304051232-thru-.pdf
HERE IS THE PARTS BREAKDOWN OF A RYOBI/MTD/RYAN ENGINE.....THE BEST THING I CAN DO WITH OUT PHISICALLY SHOWING YOU. HOPE THIS HELPS AND GOOD LUCK
Nov 23, 2009 | Ryobi Garden
Fuel line on Homelight
the filter in the gas tank that line goes to carb
and the one that line goes to bulb
Jul 18, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Mcculloch gas chain saw / 3200 changed fuel hoses due to rot
The line from carb goes to bulb inlet, the bulb outlet goes to tank. Line with filter goes to carb inlet.
Mar 21, 2009 | McCulloch 26cc Gas Blower Mcb3208
Ryobi 700r gas trimmer, replace old fuel lines
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
To leemineres, if hoses are on right and unit still stalls after starting initially you probably need to disassemble carb and clean out using spray carb cleaner. May be sticky needle valve, or partially plugged port or jet.Could also be hole in diaphragm. Gasket and diaphragm kit would be good to add when you take apart, even if diaphragm does not have a hole.
Jan 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replacing the 3 fuel lines
check my postings 3 days ago it give a good run down
Dec 20, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
459 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
