Question about Yahoo Messenger
How to erase yahoo massager 10 cause i like yahoo to put it back to yahoo massager 9.0
  • 101 Answers
Just go in add and remove in control panel and remove yahoo 10 and download yahoo 9 k
Posted on Oct 29, 2009
I have a interactive health massage chair model ems-9-s. when you turn the power switch on the back rollers run for 10 seconds or so and it stops. The power light is on in the controller but nothing will...
Hope it is still under warranty. Need new board and possibly more. My parents bought a similar chair and it failed with many issues to fix. Tech replaced all the electronics. Good luck.
Nov 27, 2013 | Interactive Health Ijoy 130 Human Touch...
Ok i can recive a massage but when try to add them it wont i have tried putting on anothere date and takeing old massinger 10 off replaceing with 11 i wonder if it is yahoo itself
What are you trying to add them to? Do you mean to save them in the archive? If you look under preferences and then messages you can configure part of it there. Then go under ARCHIVE and you can choose to save or not save the messages in an archive for viewing later.
Jul 25, 2011 | Yahoo Messenger
The recorder dosent errs why
Hello you can erase the recorded messages one by one or all massages in folder at time
Note once a recording has been erased, you cannot retrieve it.
Erasing messages one by one
1 Press ERASE while playing back the massage you want to erase or press ERASE for more than 1 second during stop mode.
A beep will sound and the message number and "ERASE" will flash while the first and last 5 seconds of message is played back 10 times
2 Press ERASE while the message is being played back.
The message is erase and the remaining messages will be renumbered. (For example, if you erase Message 3. When erasing is completed, the unit will stop at beginning of the following message.)
Erasing all messages in a folder
1 Press FOLDER to select the folder you want to erase.
2 While pressing STOP, press ERASE for more than 1 second.
"ALL ERASE" will flash for 10 seconds
While the display is flashing, press ERASE.
Nov 16, 2010 | Sony ICD-B7 Digital Voice Recorder
Print unable 50
The carrier that goes back & forth has a timing strip ( a plastic strp about 1/4" wide and goes the legth of the machine) If you open the top cover. put your hand in the hole fill twards the front of the machine and the top cover. now the carrier has a U shaped sensore that this strip goes through. 9 times out of 10 the stip has gottin bummped out of position. now you need to put that strip back in the sensore. hard to do with covers on. if look close at the top cover not that hard to take off.
good luck
Jan 07, 2009 | Brother Fax-1360 Plain Paper Inkjet Fax
My yahoo Im stops working
Use info below to delete present version completely then if you want to try 9 again and are using Vista go here for help.
http://www.ymessengerblog.com/blog/2008/10/27/installing-90-on-windows-vista/
Messenger 9 for Vista users and XP users with 9, Mess 9 has many unsolved problems and missing features that messenger 8.1 or 8.0 has. Plus now the updated Windows Firewall will not let Messenger download correctly.And is causing 9 users to have problems now.. The only option that might help is going to the control panel and turning off the firewall to download and install then turning it back on.Then click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save.
.If the fire wall still causes problems,then revert back to 8.1 or 8.0 these and all versions of messenger can be found here; http://www.freecreed.com/ymsgr-archive.html
You need to remove version 9,or present version, 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.Make sure Automatic is checked! then continue to uninstall..Or use control panel ,Vista-program features or XP-add/remove this is the 2nd best way. If you just delete the Yahoo file to remove messenger,you will also lose the shared file that contains things needed on other Yahoo sites. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
The latest update for Flash Player to #10 Is causing things to not load,Can not log in,or Messenger just crashes upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here. http://www.adobe.com/support/flashplayer/downloads.html
Here is the best help/fix it sites I have found so far for Messenger,chat,and Yahoo in general. http://www.helpbytes.co.uk/ This one for Vista http://www.vista4beginners.com/tips-and-tricks
many problems solved using this link http://www.freecreed.com/
Dec 11, 2008 | Yahoo Messenger
I need to get my contacts back
Your contacts list is stored online, you can change versions and contacts transfer.Not sure what you mean by disconnected ( from what? yahoo,messenger,) Do this,
Dec 10, 2008 | Yahoo Messenger
Yahoo Messenger 9 Vista Installation Problems
Dec 09, 2008 | Yahoo Messenger
My yahoo messenger application is not responding
http://help.yahoo.com/l/us/yahoo/messeng...
Media player 9 on ipaq 2215
A hard reset will get it back for you, but you will lose your data. So either backup first, then restore it. Or sync to PC and back if it's just OUTLOOK data.
Sep 11, 2005 | HP iPAQ H2215 Pocket PC
Yahoo Messenger Logo
60 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
