Question about Apple iPod nano
Ipod and usb
I have a problem with my ipod, when i go to plug it into the usb that's plugged into the computer, the ipod doesn't connect. But then when my brother uses the same cord and same port of usb his ipod connects? And then when i plug my ipod threw the same cord to the wall charger it will work? I dont know what to do, please someone try and help me out !!! :(
  • 30 Answers
Try going to control panel add or remove programs and remove itunes. Then Go to itunes.com and re-download it. It worked for me. If that dosen't fix it is there a warranty and how old is your ipod?
Posted on Feb 06, 2010
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
I have a white apple ipod. Model a1136 (30gb) which i am having a problem connecting to the computer. When I try to connect it, it reads "One of the USB devices attached to this computer has...
Believe it or not, many people have resolved this issue just by unplugging (from the wall or the power supply, doesn't matter) the PC for 15-30 minutes. (This allows all the capacitors on the motherboard to fully discharge) If you have a laptop, unplug it and remove the battery.
If it only happens with the iPod and no other USB device, let the iPod drain down completely and plug it back in.
Other things to try: A new USB cable Uninstall ALL the USB ports from the PC via Device Manager and reboot.
Jun 29, 2011 | Computers & Internet
My son updated my 2g ipod touch on his (older?) computer. It is frozen now & won't go past a screen w/the itunes symbol & the usb plug. It will not restore. I have uninstalled & reinstalled...
  • This isn't an iTunes problem. While the iPod is displaying this logo, you need to plug it in to a computer that has iTunes open beforehand.
  • Try using another computer with iTunes installed, or another USB cable for the iPod. Try to restart by holding the sleep and home buttons for about 10 seconds.
  • If this still doesn't work, take the iPod to your local Apple store, where they can check for any hardware problems that may have occurred.
Jun 29, 2011 | Apple iPod touch
How do i connect my ipod touch to itunes?
Plug in your ipod to the computer, and iTunes should recognize the iPod. If this doesn't work, try a different cable or USB port.
Apr 24, 2011 | Apple iTunes
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
Everytime i plug in my ipod its not showing that it's connected
Okay, don't freak out. What we'll do is systematically check the different points where a problem could be hiding, correct it or eliminate it, and then you can return to your normal iPodding. This could be no big deal so let's check the small stuff first, then we'll test the software.
Before we go ahead and troubleshoot your problem, lets quickly run through this checklist, just to make sure it is not something obvious:
  • Check your connections (USB fully plugged in? iPod connected?).
  • Plug the iPod directly into the computer (don't use a USB hub).
  • Try a different USB port.
  • Use a different cable (ask a friend if you can borrow their USB cable).
  • Remove all the other USB connections (sometimes other USB devices can cause a conflict).
  • Try this:
    • Unplug your iPod
    • Close all programs that are currently running.
    • Plug in your iPod.
    • Open iTunes.
  • Try rebooting the computer
ipod_notmounting_troushoot.gif If any of these steps got your iPod to show up in iTunes, make note of what was causing the problem, then continue to enjoy your iPodding lifestyle.
Aug 10, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Ipod not recognized as a drive.i need help. it is an ipod touch 8 g 2nd gen
Plug your ipod into a USB 2.0 port and see if that helps.
or try a different port on your computer. make sure your not connecting the ipod
through a hub. Sometimes the hubs don't carry enough power to drive the ipod.
if this doesn;t help get back to me and I will help further.
Apr 20, 2009 | Apple iPod nano 3rd Generation
I cannot install music from my computor to my Ipod 4 nano
If you can't connect iPod nano to your computer , make sure;
  • you have installed the latest iTunes software from www.apple.com/ipod/start.
  • Try connecting to a different USB port on your computer. Note: A USB 2.0 port is recommended to connect iPod nano. USB 1.1 is significantly slower than USB 2.0. If you have a Windows PC that doesn’t have a USB 2.0 port, in some cases you can purchase and install a USB 2.0 card. For more information, go to www.apple.com/ipod.
  • iPod nano might need to be reset (see page 64).
  • If you’re connecting iPod nano to a portable or laptop computer using the iPod Dock Connector to USB 2.0 Cable, connect the computer to a power outlet before connecting iPod nano.
  • Make sure you have the required computer and software. See “If you want to double check the system requirements” on page 68.
  • Check the cable connections. Unplug the cable at both ends and make sure no foreign objects are in the USB ports. Then plug the cable back in securely. Make sure the connectors on the cables are oriented correctly. They can be inserted only one way.
  • Try restarting your computer.
Mar 11, 2009 | Apple iPod nano
IPod shuffle 1st gen. Not Recognized By PC
Try a different USB port first. Here are some other suggestions:
Connect iPod shuffle to a high-power USB port on your computer. iPod shuffle may
need to be recharged.
â Make sure you have installed the latest iTunes software from
â Try connecting to a different USB port on your computer. Make sure iPod shuffle is
firmly seated in the dock. Make sure the USB connector is oriented correctly. It can be
â iPod shuffle might need to be reset. Turn iPod shuffle off, wait five seconds, and then
turn it back on again.
â If there is no status light (or the status light is dimmed) and iPod shuffle doesn’t
appear in iTunes or the Finder, the battery may be completely discharged. Let
iPod shuffle charge for several minutes to see if it comes back to life.
â Make sure you have the required computer and software. See “If you want to doublecheck
the system requirements” on page 25.
â Try restarting your computer.
â If none of the previous suggestions solves the problem, you might need to restore
iPod software. See “Updating and Restoring iPod shuffle Software” on page 26.
â If restoring iPod shuffle doesn’t solve the problem, iPod shuffle may need to be
repaired. You can arrange for service on the iPod shuffle Service & Support website at
www.apple.com/support/ipodshuffle/service.
Jun 09, 2008 | Apple iPod shuffle MP3 Player
Ipod nano problems
Go to Start --> control Panel --> System --> Hardware --> Device Manager --> Universal Serial Bus Controllers - see if there is a yellow exclamation mark; if so, right click and select update driver
May 07, 2008 | Apple Ipod Nano Second Gen. Green (4 GB)...
Apple iPod nano Logo
50 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
