We need assistance with locating a repair shop or service company for an Epson TM-U590 printer. Serial number: J9SG002996 Model: M128B We are currently utilizing this printer for printing truck scale weight tags. The printer has stopped working and we are not sure what the problem is. We contacted the Scale Company that we initially purchased the printer from and they are not very helpful and are requesting $90.00 an hour for service and repair (not including travel charges?) Please contact us directly if you have any further questions, 209-668-6899. Thank you for your prompt attention regarding this request. Sincerely, Janet Daniel JD Almond Farms, Inc. 209-668-6899
SOURCE: weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Posted on Aug 25, 2008
frcs68
  • 1605 Answers
SOURCE: Epson TM on Windows XP with serial
you need to use the printer cable that was design for the printer. if you don't have the cable anymore, then you have to take the commercial cable apart and reconfigure in accordance to page 43 of the manual call outs.
Besides the cable, the printer software is only good for Windows 2000. Windows XP will not work unless Epson provide you with the printer driver. (which I did not see on the website).
all in all if you must use this printer with Windows Xp. you need to create a file in Autoexec.bat to enable the printer and allow the USB to connect to the printer.
that is going take time to do. if you need help on that. please post the request here.
Thanks
Posted on Dec 03, 2008
SOURCE: tm-u295 firmware problem?
I can solve that problem but i need some help in the firmware of TM U220B. I just need the .bin files to downgrade to version 1.02
Posted on Feb 26, 2009
SOURCE: Conair weight watchers ww37gd scale
To set
1. Push the set button, you will get ------
2. Push the user
3. Push set again the user number will blink 3 times and show 0.0
4. Get on the scale- when it shows your weight push the set button. This is your start weight
5. Then it will automatically take 10% and show your goal.
6. Push the set button again this will set the goal
To Weigh
1. Push the user number that you set up the P-? number will blink 3 times and show 0.0
2. Get on the scale it will show in this order
a. your weight now
b. your weight since the last time you weighed
c. The total loss toward this goal
d. Total needed to reach your goal
Posted on Feb 27, 2009
ohms
  • 1879 Answers
SOURCE: tm-t88iv epson made prnter driver for win 2003 server r2 std
Epson POS driver will not install on a Win2K3 machine due to the InstallShield Wizard w/c checks if your running XP/2K or not.
Download the driver from EPSON POS site & extract the contents first on an XP machine.(Installing the driver will create a C:\Epson folder where ACTUAL driver is extracted).
Posted on Mar 06, 2009
Could you please assist me by identifying the ink code or serial number for Epson Tm-t88iv please? Urgent..
Felix, Are you sure this uses ink ?
It might be a thermal paper roll and will need thermal paper for it to print.
I think RPT3.125-STD is the thermal paper for this printer
inserted the correct side also.
Feb 21, 2017 | Epson Office Equipment & Supplies
I need a driver for the EPSON TM-U590/TM-U590P
https://download.epson-biz.com/?service=pos
Visit the above link for the drivers u need.
Hope this helps.
Vote for me if this solution was helpful to u.
Jun 17, 2011 | Epson TM U590P Matrix Printer
What is the baud rate of EPSON TM-U220D MODEL M188D?
hello, make sure there is paper in machine, turn machine off, hold the paper feed button, turn machine on, it will print the configuration of machine. adjust serial port setting on computer for baud rate. to change the baud rate on printer, you will need the user guide.
Sep 28, 2010 | Epson TM U220D Printer
Epson TM-U220 not working with window 7
download this driver APD-406aE i did it and it is working perfect with my windows 7 on a TM-U 220B
Jul 07, 2010 | Epson TM-U220 Matrix Printer
Epson TM-U220PD printer network card problem - recognition
Did you change the dip switches? I believe that for the serial printer to work with ethernet, you need to have switches 2 and 4 on bank 2 set to on.
Jul 13, 2009 | Epson TM-U220 Matrix Printer
Need drivers for epson tm u220 for vista
You can go to the following link, put in what type of printer, then model number, then pick the driver you need from the list
Jun 13, 2009 | Epson TM-T88III Thermal Printer
Printer prints garbage...
Hi
make sure it is configured to the right port and using the epson driver. go to printer and faxes and properties then ports. check of the correct printer driver is check. what type of cable are you using anyways? com for serial, LPT for parallel.
Hope this help
Jan 02, 2009 | Epson TM-U220 Matrix Printer
Can't install epson tm-t88iii serial
unistall the epson driver.
reboot your system.
connect and turn on the printer.
reinstall the driver, v3.02, selecting for create a serial port.
choose the right setting os serial interface.
after install, reboot your system.
it works to me.
Aug 19, 2008 | Epson TM-T88III Thermal Printer
jasbo
jasbo
