Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 60PP9202 60 in.
I have a convergence problem with my 60 inch Philips television set. The screen seems to be blue and i tried to chenge the multipoint convergence manually but it didnt seem to work in any way. also, the screen is all curved, nothing is aligned, and there seems to be "ghost" shadows everywhere on the screen. I need to know what part to buy. I dont know anything about this television. or any parts. So if you can help me, you will be highly appreciated. Thank You.
  • 1 more comment
  • Anonymous Dec 20, 2007
    my red convergence too low on the horizontal. Philips 60PP9202 60 in TV.
    please help.
    thanks,
    david
  • chris555 Dec 23, 2007
    convergence
  • jsherman Dec 23, 2007
    I have the same set and have a green convergence problem. Red and blue are fine, but green is like a sideways hourglass. I spent most of the day fiddling around with it today and was able to trace it to the Auto Convergence Module, part # 313501332323. I pulled the unit and desoldered both front and rear covers and it started working again! The problem still occurs occasionally, but if I cycle power it comes back fine. I also found that spraying the board with circuit cooler can bring it back. It's flaky, so I'm looking for a replacement but can't find one yet. If anyone knows where to get one, please contact me at jsherman@juno.com.
    Genius:
  • 1,030 Answers
Sound like your convergence amps are blown. also known as stk's
Posted on Dec 19, 2007
Philips 43pp92 blue will not converge
STK392-120 is convergence correction amplifier.. the problem is the convergence circuit... try to check the small Valuie electrolytic capacitors or High value resistors! maybe the said parts is in change Value... used a ohmmeter tester to find the chenge value parts!.
Nov 05, 2007 | Philips 43PP9202 43" Rear Projection...
I have a pHILLIPS 46 INCH PROJECTON tv. tHERE SEEMs to be a blue arc of light on the bottom third of the tv. When there is white on the screen it reflects in blue.
If the convergence is OK in this area of the screen, msot likely there is a problem with the coolant fluid in the blue tube. Somtimes the fluid starts breaking down and gets cloudy or a bubble has developed in the fluid. Look down through the blue lens from the back while the set is playing and see if you can see the problem. Could also be something on the lens itself. Clean it with ammonia free glass cleaner. Thanks for using fixya.
Dec 26, 2009 | Philips 60PP9200D Television
55 inch with blue ghost like glow on white or blue colors
Inside of your TV their is a fluid that keeps the tubes cool. Over the years this fluid will turn cloudy and cuase the screen to look dull, bright white, have halos, etc. You can get the fluid over the internet from various sources or your can get a complete kit including repair instructions from www.TvRepairKits.com.
May 08, 2009 | Philips 55PW9363 55" Rear Projection...
Philips 60 inch rear projection screen is wacky!!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 10, 2009 | Philips 60PP9202 60" Rear Projection...
I have a philips rear projection 60 inch model60pw936317f its got kind of a 3 d blue line on all the words
  • Screen looks 3D
Feb 28, 2009 | Philips 60PW9363 60" Rear Projection...
Convergence will not line up after replacing ic & resistors
Did you replace the resistors when you replaced the convgence chips? If one of them was bad you would still have the problem.
Here are some of the most common symptoms and example photos.
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 03, 2009 | Philips 51PW9303 51" Rear Projection...
PHILIPS MODEL # 46PP93 0217 40 INCH.
It may be the fluid in the CRT or the convergence chips are bad.
  • Screen looks 3D
2c07611.pngSolution
Sep 22, 2008 | Philips 51PP9100D 51 in. Television
55 hdtv philips having issues with blue and red lines around everything ......
change the convergence ICs also check the resistors right next to the ICs as 1 or 2 of them may be open as well.
Mar 28, 2008 | Philips 55PP9352 55" Projection Television
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
121 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
