Question about Homelite Consumer Products Backpack Blower/Vac, Carb
Gas is pooring out of the exhust - Homelite Consumer Products Backpack Blower/Vac, Carb
  • 437 Answers
Needle valve in the carburetor is not stopping the flow of gas. It may need to be rebuilt. You also may have flooded the unit trying to start it.
I would have a shop do a compression test on the engine; it needs to be at least 100 psi to run.
Posted on Sep 30, 2009
  • amathonn Mar 20, 2011
    You sure you don't just have a disconnected tube from fuel tank?
Hi, my golf mk1 1.6 1995 model makes a tapping sound when i drive it but it stops when i idle
Sounds like to me a small exhust leak either
a exhust manafold gasket or exhust flange
gasket or cracked exhust manifold.
Anything else would be enteral meaning
valves need to be set, bad lifter, bad rod bearing,
bad oil pump, or timing chain tensioner,
BUT I would be willing to put my money
on an exhust leak or timing chain tensioner
it's one of the 2
Jun 29, 2014 | 2000 Volkswagen Beetle
Gas eaking from exhust manifold where it mou
tighten the bolts if the exhaust fumes still come out replace the gaskets if its gassolien your seeing there is a recall for the fuel rail
Feb 14, 2014 | 2001 Chrysler Town & Country
Gas keak at exhust manifold
remove the manifold from the engine and have it machined flat at an engineering shop . Fit new manifold gasket and tension the studs correctly in the correct order . Check the stud tensions as the innermost studs are tighter than the end studs .
Exhust fumes coming in car on 2003 mustang
i think is the catalitic converter it stok .thake off and cleane it whit a solution for that. and change the oxigen sensor maiby it durty .and give me some news thank mike 66
Mar 04, 2013 | Cars & Trucks
Acceleration
have you checked the cataletic converter? it would keep the exhust from leaving the engine and would loose acceleration
Sep 20, 2012 | 2000 GMC Sonoma Extended Cab
I have Gas in my oil sump and sprays mixture out exhust when trying to start mower
what has happened is the rubber seal on the needle and seat has dried out and fuel is leaking passed then the carb overfills and then the gas flows into the cylinder and crankcase
Sep 03, 2012 | Craftsman Garden
My Yamaha 2400 is not running smooth and it lopes. It has about 40 hours on it. I cleaned the filter Air and put a little additive to boost gas. Also changed spark plug which was dark at the probe. I do...
40hrs? I'd look at the exhust.There is a screen that fits INSIDE your exhust.A small flat tipped screw driver should pry it out easy.In chainsaws they're used for spark arresters,the same on these I think.Quick wirebrush and your exhust should be able to flow and not back up.
I've had my 2400 7 yrs now here in Alaska,out in the woods where I live.I need a Boost Control Unit,teach me for not using a ground wire,I burned a pin out in my unit.$800 part for a $1,300 generator.I really really like mine so I'll buy another and keep looking for a used one online.
Dec 15, 2010 | Yamaha EF2400iS Portable Generator
Rattling noise when starting and idling
It could be lose ehuset system parts or catalic conveter problem but itsan 86 thats 25 years old but i have an 85 ford ranger and it still runs great look for things that are lose or moveing around exhust system
Nov 01, 2010 | 1986 Ford F 250
My weed wacker is leaking gas out of this little hole beneith the exhust and ii leaks badley
Fuel line coming out the tank has compressed and is letting fuel leak out
Jun 11, 2010 | Troy Bilt Tb70ss Gas Trimmer
Leaf blower runs then sputters and smoke poors out of exhust then runs and repeats cycle like it is burning oil.
Sounds like its not getting enough air, check the air breather filter. Stephen.
Oct 07, 2009 | Garden
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
111 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
