Question about Avaya 700340193 Corded Phone
No sound coming through the handset, but phone works otherwise
No sound coming through the handset, but phone works on speaker - tried new handset and cord still didn't resolve the problem.
  • Anonymous Mar 20, 2014
    tried a different handset still does not work
The port might be bad that the curly cord pulgs into.
Posted on Oct 01, 2009
Looks like this may have already been solved, but for the benefit of anyone else resarching this problem, check the widget that holds the handset in place when the phone is wall mounted. I just encountered this problem, and it turned out that widget was installed upside down, and was preventing the hook switch from disengaging completely.
Posted on Feb 09, 2012
I only have sound on my phone through earphone jack
Is it a Panasonic handset? Most cordless phones with have a small peizo electric speaker. Which looks like a small cylinder with two wires attached. Try opening the handset to check if the wires are soldered properly. If they are fine, I am afraid the speaker is dead and needs to be replaced. Not something that you can do unless you have the right tools. Just dump it and buy a replacement handset. New models allow handsets to be added.
Web Design SEO Agency quality websites at freelance prices
Oct 05, 2016 | Cell Phones
KX-TGA660 handsets - 3 of 5 wouldn't ring (no sound)
sounds like who ever installed your service was an amateur, all points should be gone over by a senior tech, piece by piece!!
Nov 14, 2013 | Panasonic Lands Phones
BlackBerry bold 9700,its speaker phone not working,ringtones and music not heard,but if i put it near ear from back of the phone then music is heard.Please solve as this is my new phone
Your phone is set on handset mode.While playing music,press the blackberry button and select the activate speakerphone option on the list.This would work for you.
Mar 26, 2011 | RIM BlackBerry Bold 9700 Smartphone
Avaya 18D phone only speaker works not the handset. Order a replacement phone and the new phone does the same. We swapped locations snd the problem goes with the phone. Handset placed on a known working...
Avaya Partner 18D Button phone:
Two possible solutions,
First, could have a bad handset cord.
Second, I have come across a bad handset connection ports on the Euro style phones. The handset cord and the port just don't mesh well or the port itself is bad.
Feb 09, 2010 | Avaya Partner 18 Eurostyle 18D telephone
Pan KX-TG3032CS: Handset has dialtone on Speaker, not on Talk. Handset works OK otherwise.
Made phone call on Speaker; worked OK.
(Had to phone the library anyway; good test.)
Took handset apart, determined normal ear speaker was OK.
Disconnected Speaker - never used it anyway.
Switched ear speaker wires to Speaker connection. Soldered connection.
Phone now works fine; just press Speaker rather than Talk.
No parts, no cost, & a working phone. And if there's a problem I can simply reconnect the Speaker & use it that way.
Sep 10, 2009 | Panasonic Lands Phones
Uniden TRU888 5.8 Digital Phone Display no longer lights up
I purchased this model phone as a refurb item and also had display blanking out issues. Mine related to a problem with the battery, which new batteries fixed. Try swapping the batteries between handsets and see if the fault moves to the other handset, which will prove if it is a battery problem. Otherwise, it would seem to be an internal fault in that handset. Try and arrange repair/replacement from the seller.
Jun 21, 2009 | Uniden TRU8888 Corded Phone
No sound comes through the ear piece on handset.
The first troubleshooting question is do you have the in-call volume turned down? If not, then it's a physical problem.
Razrs are notorious for various speaker problems. If you're adventurous, you can open it and see if a wire has slipped or shorted out. Please note that this will void your warranty! Otherwise, I would just recommend taking it to your cellular provider and asking them to replace it. Many providers will replace handsets for free if there's no physical or water damage to it.
In the meantime, try using the mini-USB headset that Motorola ships with the phone or picking up a third-party one, or use a Bluetooth headset.
May 26, 2009 | Motorola Mobility RAZR V3i Cellular Phone
DECT 225 - Ring tone etc. no longer works on 1 phone
Use your screw driver, open the handset, maybe the speaker wire is broken. Or use multimeter to check the dc resistance of speaker. Generally ,it is 8ohm or 4 ohm.
Oct 18, 2008 | Philips DECT 2252S Cordless Phone
Avaya 700340193 Corded Phone Logo
206 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Cabanaboyz
Cabanaboyz
Level 1 Expert
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
