Question about Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl
Clogged Sink, Disposal On Takes Water Down, Off, Spurts Back Up
I have a single sink with an attached garbage disposal. It has been clogged for 2 days now though I don't think the problem is the garbage disposal since it runs when I turn it on. Also, when I turn it on, it sucks all the standing water down the drain but as soon as I turn it off, all that water just spurts back up. The sink eventually drains after a few hours.
I have checked the garbage disposal (by hand, power off) for any thing stuck down there (nothing), have hit the reset button, have done the baking soda + vinegar + boiling water method I've seen mentioned on so many sites. I've also plunged it lots of time after sealing off its vent to force that plunging pressure in the right place.
Some sites have suggested removing the S-Trap and checking of obstructions, buy my trap is not removable. Instead of slip nuts connecting it to the other pipes, it's looks like some sort of black sealant was used. My last thought now is to use some sort of liquid drain cleaner - is that advisable?
P.S. I don't know the exact model of garbage disposal but selected one at random because I had to in order to submit this question, though it doesn't seem like the GB is the problem here.
  • makeitspicy Nov 29, 2009
    In the end, we had to call the plumber who had to snake the pipes.
I have had a similar problem with a clogged sink and a functioning garbage disposal. I tried the liquid drain cleaner and had no success. Instead, my father-in-law used a plunger on the sink side. He had the clog undone in about 1 minute. Sink has worked fine ever since.
Posted on Jan 03, 2010
  • 82 Answers
NEVER us a liquid drain cleaner on a kitchen sink. Sounds like fourniershva knows what he/she is talking about other than that. Any plumber knows you do not use a drain cleaner where you WASH FOOD. Would you want to eat the drain cleaner? Nope. You have a clog in the line and it has to be snaked.
Posted on Nov 27, 2009
  • 308 Answers
I agree it definitly is not your garbage disposal. You could try to use a liquid drain cleaner, but in my experience those do not work all that well, especially on the type of problem that you are having. If in fact you can not take apart your P-trap, (it shouldn't be a S trap), you should look for some type of a clean out cover under the sink or in the basement (if you have one). If there is another fixture down line, or for that matter up line, are you having problems there? It is possible that you have a clogged pipe under the sink. Unfortunatly if you can not disassemble, you (or a hired prof) will have to cut under the sink to find the problem. Hope this helps
Posted on Sep 30, 2009
Sink erator
First, unplug the power cord to the "Sink aerator" disposal from under the sink storage area. Next, remove the black rubber strainer from the upper sink area leading down into the disposal. (It simply pulls upward to remove) This will allow you to put your hand down into the disposal area to physically clean out the disposal deposits by hand. Pull out whatever is plugging the disposal and throw the debris in the trash, not back into the disposal. Once everything is removed from inside the disposal, flush it out completely with water from the faucet until it drains freely. Reassemble the black rubber strainer and plug in the disposal once clean. Be sure not to put potatoe peelings and other non-disposable items which can't be ground up easily in the garbage disposal. Keep in mind, just because it says garbage disposal, it doesn't mean all "garbage." Also, always use plenty of water when using the disposal and allow the water to run for a minute or so afterwards to finish washing down the debris in the sink "P" trap drain out through the outer sewer line.
Jul 07, 2014 | Home
Our new kenmore garbage disposal shoots the water up rather than sucking it down
Check the drain is not clogged.
Does sink opening have splash guard?
Check that plumbing is vented as required by code:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#slow
Gene h
Mar 23, 2014 | Kenmore 3/4 hp Food Waste Disposer
When dishwasher is emptying it is backing into sink
there is probably nothing wrong with Dishwasher itself.
Your Sink drain is stopped up or your Garbage disposal is clogged.
usually, dishwasher drain is connected to the Garbage Disposal, but if the dishwasher empties the water into the Garbage disposal, if its clogged then water will come out of the sink. Same if sink is clogged between sink and sewer.
If you fill up your sink and then water drains away, then you know your sink itself is not the problem. If its only the Garbage disposal side that does not drain, its the garbage disposal that is clogged.
Dec 22, 2013 | Dishwashers
When my dish washer discharge water instead of the water going out the drain it come out the overflow valve.
The dishwasher usually drains into disposal, or directly into tailpiece, and water drains down to the p-trap.
Trap may be clogged or stopped up.
Clean out drain line, tighten connection where dishwasher attaches.
Clean out bottom of disposal under cutter blade.
Copy following link for clogged disposal, and drain line tips.
Oct 18, 2012 | Kohler K-692-7 Clairette Kitchen Sink...
The hose detached from the garbage disposal. I re-attached it and now the water can't pump out of the bottom of the dishwasher
You have a clogged drain, remove the sink trap and use a plumber's snake to unstop the clog. Reattach the trap under the sink and disposal should drain. The pressure from the dishwasher pump more than likely caused the drain to slip loose, it's a drain, and it should not have any backpressure.
Jul 08, 2012 | Whirlpool Dishwashers
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Feb 10, 2012 | Asko 1385 Dishwasher
Garbage disposal sink will not drain, every thing sounds like its working
Sounds like the disposal drain is clogged.
Under the sink, put bucket under plumbing, take a photo of parts, remove 2 nuts on p-trap and trap falls loose.
Run water and disposal and see if disposal drains correctly.
If disposal is still clogged, remove tailpiece on side of disposal to access the disposal cutter chamber. The tailpiece is sealed against the disposal with rubber washer. Make sure washer is clean when putting tailpiece back.
If necessary, use coat hanger to reach into disposal.
Clean out trap and reassemble tubular drain using photos to help assist where each part goes.
I use white teflon joint compound on each joint and washer when reassembling tubular joints to make sure they seal first time.
Oct 07, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Here is an interesting problem. We have a Badger 5 1/2 Hp Garbage disposal hooked up on left side of double sink. The Disposer runs, spins, but will NOT drain.. at all. Left sink with the insinkerator will...
If this connects into a tee between the sinks, usually if the tee is in the middle of sinks, then often there is a divider in the tee to keep water from backing up the other drain. Remove the tee and inspect to be sure it isn't cloggged. Also put a bucket under the outlet. Try running it this way, if you get good flow you know the disposal is working
Aug 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How do you clean out a clogged drain hose from the garbage disposal to the dishwasher?
You may have to pull the dishwasher out and remove the clamp on the hose from the pump. run a snake or a coat hanger or anything else that you be long, flexible but stiff enough to move through the drain. You might be able to go from the disposal side back to the drain. This would be easier if you can. If you run water down the disposal side does it back up into the sink? If it does, then the clog is down below the disposal and not the dishwasher side.
Apr 08, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl Logo
794 people viewed this question
Top Buck Home Experts
Donni Steen
Gene Haynes
handygirl911
handygirl911
Are you a Buck Home Expert? Answer questions, earn points and help others
