Question about JVC RX-660V
Need new AC/DC power for MIXPAD 4
As with the original poster, I also have a Samson MIXPAD 4 that acts similarly when powered up. The power indicator light flicks on then off when I power up the unit.
I also need a replacement for the AC/DC power supply. It has a 5 pin DIN in the following layout: Pin 1 +15v, Pin 2 GND, Pin 3 GND, Pin 4 -15V, Pin 5 +32 V.
Does anyone know of a replacement AC/DC power supply?
Thanks
4 Suggested Answers
  • 3 Answers
SOURCE: Stopped working
I had a similar problem with a jvc 8040. when I replaced the fuse it became very obvious that the b1560 output on the center channel was blown (smoke and sparks, always a dead giveaway). I haven't fixed the center channel yet but simply unplugged the center channel board and removed it from the unit. Now everything works fine except of course the center channel. Pre outs still operate just fine so a slave amp could be used for center channel power, or you could just go and buy a marantz amp; I did and then I realized that I was lucky that the old jvc quit.
Posted on Jan 30, 2008
rizla
  • 1463 Answers
SOURCE: Need adaptor for Samson mixpad 9
hi will these have em in stock .?
riz.
Posted on Apr 05, 2008
VOTIT
  • 2071 Answers
SOURCE: won't power up
Yes this is a power supply problem,you better replaced the regulator IC there or replaced the whole board,so it will works normal again..
hope this may help you;
DON'T FORGET TO RATE:
Posted on Sep 04, 2008
Red flashing power light
I am sure the original poster will have probably replaced the unit by now but I just had a similar problem with my Epson Perfection 2480 Photo scanner so I think it is still worth posting the solution in case other people hit this problem in the future.
All I had to do was put the switch underneath the scanner to the "unlocked" position and then reboot the unit.
Hey presto it burst back into life.
It's annoying to see that the manual seems to suggest that the red light means the unit is "dead" !
Feb 24, 2014 | Epson Perfection Office Equipment &...
Laptop not starting, no lights except small blinking orange light in cd drive drawer
It sounds like the power socket on the laptop is faulty and needs replacing or resoldering. To check this, power up the latop with the power adapter, wriggle the plug in the power socket and check if the battery charge indicator flicks on and off indicating charging and not charging. If it indicator flicks on and off then you have a faulty power socket.
This can be repaired but required the laptop to be completely dismantled to access the power connector.
Oct 30, 2012 | Medion Computers & Internet
Hum from Samson XM610 Powered mixer
hi, my samson xm610 have a problem even i tern off the voluem of each chanel still have a sounds be fore is not just like that.. can you help me
Aug 27, 2012 | Samson Xm610 Powered Mixer
When I turn on the amp the indicator lights comw on and seem ok for 3 or 4 secs and then there is a click and the amp lights go out even though power is still showing as on.
Sounds like the amp is going into a protective mode.
Make sure your outputs aren't shorted.
If you're into electronics, look for bulging electrolytic capacitors or blown transistors.
Something is tripping the safety in the unit!
Mar 01, 2011 | Samson Xm910 8Channel Powered Mixer...
Samson MDR8 blowing internal power supply fuses. Is there a wiring schematic of the power supply board available
Here is a troubleshooting hint:
Put an incandescent lamp in series with the hot side of the power cord. This acts as a resetable fuse while troubleshooting so you don't blow fuses.
Schematics are hard to come by, but power supplies are easy to trace the circuitry.
Check filter caps and the diodes and THEN look for hot (temp) IC's and transistors.
Mar 17, 2010 | Samson Music
riz.
Apr 05, 2008 | Audio Players & Recorders
445 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
