Question about Coleman Powermate Powermate 5000W Generator
No connection for a 5000 Watt Devilbiss gas generator.
I have a 5000 Watt Devilbiss gas generator. It's 10 years old. I would like to install a transfer switch in my home and there is an issue. There are four standard receptacles on the gen set - two 120 V / 20A and two 240 V / 20A. The plugs on the transfer switches that I see are L14-20 and L14-30. Since these are not readily compatible with the generator how do I hook up the transfer switch? Thanks.
  • 98 Answers
I'm specialized in generators...but your problem seems familure...
try getting an L14-20 female connector ...i wish i had more details but this is all i can advice.
Posted on Oct 27, 2009
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
I have a devilbiss generator mdel #gb5005 runs great but no power output any ideas
If the unit has been setting for a long time you would need to start with re-exciting the field.
If this does not resolve the problem the first check the winding for short to grounds, also check the resistance readings.
If these are all ok and within specs... then you will need to check the diode.
You can find a service manual at www.msservice.net
Oct 14, 2014 | DeVilbiss 7000 Watt Generator
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
Need a replacement on-off switch for a DeVilbiss GB5000-2 generator
My switch broke as well. Instead of trying to find one, I removed it, and mounted a heavy duty toggle switch on the front of the shroud, just below the original location. Connect the original wire to one side of the switch, and a wire connected to a good ground to the other side. Btw, the off position on the toggle switch is run, and the on is now off. This repair has served me for years.
Jul 20, 2012 | Briggs & Stratton Briggs and Stratton...
My neighbor gave me a 10 year old 5000 watt Coleman with a 10hp Briggs that was not running. It would run on starter fluid so I focused on a fuel problem. New fuel, fuel filter and oil. Dissassembled the...
That's interesting that you bypassed the fuel pump after noticing that the carburetor was below the tank, not needing a fuel pump to start the engine.
Maybe they put a fuel pump in to ensure that the float bowl valve is not the only thing preventing gas from overflowing into the carburetor when stored for a long period of time.
I would put the pump in if that's the way they originally designed the fuel supply for the engine, just to be safe.
Good luck on this repair.
Dec 31, 2010 | Briggs & Stratton Briggs and Stratton...
I have a powermate 5000 (about 10 years old). I have installed a Reliance Transfer switch. Should I ground the frame to a grounding rod when plugged in. I obtained the manual(on the powermate) and the...
In any power generator installation it is always advisable to have a ground/earth rod (minimum 3 ft/1 metre long) attached to the frame of the generator, especially when connecting ancilliaries such as yuor transfer switch. The Earth and Neutral pins of the output sockets on the generator should also be interconnected. They are usually linked at the factory on assembly.
Dec 22, 2010 | Coleman Powermate Subaru 5000W Portable...
Where can I purchase muffler for 5000 watt powermate generator?
YOU LOCAL LAWN MOWER SHOP. YOU WILL FIND THAT THE HOT DOG MUFFLERS ARE THE CHEAPEST.. THAT MOTOR SHOULD HAVE THREADS SO IT WILL SCREW RIGHT IN.. TA-DA FIXED FOR WELL UNDER 10 BUCKS.. COOL HUH//
DO ME A FLAVOR, IF'N I WAS OF ANY HELP LET ME KNOW OR VOTE
TRY TO BUY PRODUCTS MADE IN THE GOOD OLD USA ... Jay
Sep 12, 2010 | Coleman Powermate Powermate 5000W...
How to change oil and what kind to use on a es 5000 generator
you should have a drain plug at the side and bottom of the motor crank case its a small plug with a square head how old is your generator if new put 10w30 oil if old put sae30w if really bad add some lucas oil treatment also now a 9 h.p. should take less then 2 quarts
Mar 23, 2009 | Pramac Storm 5000 Watt Generator
Coleman Powermate Powermate 5000W Generator Logo
334 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
