How does the tension bracket attach - Washing Machines
  • whalebone99 Sep 30, 2009
    Thanks, just what you said.It was easy!
    Brigadier General:
  • 3,513 Answers
Hi
Make sure you have the power plug unplugged.
Now, from the front side facing you, insert a screwdriver between the lid and front panel. You will find there are two pop-in holders; each one is approximately 3 inches from each side. Pop the lid. (don't for get the remove the lent trap and the two screws under it.)
Lift the lid all the way up so it is out of the way. Now, very gently lower the whole dryer onto its back side. (The lid will stand on its own.)
Then, on the inside of the front panel you will find two screws holding the front panel on. Remove these screws. Now the front panel can be removed. Use caution when you remove the front panel, as the drum will now be loose and will tip downwards. You can remove the drum if you'd like to have complete access to the motor and clean out the insides. (Un Connect the two wires to the door sensor)
Locate the broken belt and remove it.
Locate the belt tension bracket. (It has a plastic roller attached.) If it is out of position, note the holes in bottom in front of the motor. With the plastic roller facing the drum, insert the belt tension bracket.
Place new belt around the drum, and try to locate it in same place that the old belt ran. Make sure you place the groove side down on the drum.
Once the belt is in place, insert it underneath the plastic roller and lift up on the belt tension bracket until you can loop the end around the motor spindle.
Now replace the front panel, making sure you align the door opening properly on to the drum front. Replace the two screws holding the front panel to the cabinet.
Now lift the machine back upright, and secure the lid back to front panel.
Replug in and you have finished the job.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
Trying to replace my belt tensioner assembly....I have the whole plate just dont kno if im to tear whole side off with pwr steering as well....1988 Chevrolet Cavalier 2.0 4 cyl..Please guide me thru
Not real easy to do. The whole front bracket comes off. It is large and many things attach to it. everything in the front of the engine will be removed - the tensioner is either attached to this plate or is part of the plate / bracket assembly ( cant remember). power steering lines should stay connected - sometimes you may have to disconnect one. not too bad of a job, very doable. should take about an hour.
May 15, 2016 | Chevrolet Cars & Trucks
Mtd manual
MTD uses several different configurations. Electric PTO's are tensioned all the time by an idler pulley on a spring loaded bracket. Manual PTO's with an engagement lever have a movable bracket attached to the lever via a cable that will tension the belt when the lever is engaged. Another configuration is the deck engages when the deck is lowered with the deck height lever and disengaged when the deck is raised. In this case the belt is tensioned by a large spring from the rear deck support bracket to a mount on the transaxle and tension is released by a rod that pull the deck forward when it is raised.
Sep 01, 2014 | Garden
Sears Craftsman snow thrower cable tension bracket broke.
just buy a bracket and a new bushing... easier that way.
also you can remover old bushing by soaking it in white vinegar ...
Oct 02, 2017 | Garden
Shu43 cycle runs normally but at the end it continues to fill - and then drain. continues to do that till inlet water is turned off.
underneath are 2 L-brackets with the springs attached. Pull those out (with the door closed) and tension will be released. Shorten the strings attached to the springs and reinsert the L-brackets.
Oct 31, 2013 | Bosch 24 in. SHU43 Built-in Dishwasher
How can I replace the serpentine belt on my Toyota Corolla 2006??
You will need a 19 mm wrench to fit the nut on the bracket that the idler (tensioner) pulley is attached to. Pull the wrench clockwise to release tension just enough to change the belt then slowly let tension on the belt.The 19 mm nut is just above the bolt that holds the idler pulley bracket on to the motor .
Jan 21, 2010 | Lisle Serpentine Belt Tool
Adjusting door spring tension on a Bosch dishwasher
Nov 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Need a diagram of the adjustment or tension bolts for installation of alternator on 1995 Ford Aerostar-4L, Front 2 wheel Drive
This is from the workshop manual, direct quote.
Generator, Aerostar
Removal
1. Disconnect battery ground cable (14301).
2. Remove snow/ice shield.
3. Remove engine air cleaner intake tube (9A624).
4. Disconnect generator wiring at the voltage regulator (VR) (10316).
5. Remove attaching nut and wire from generator (GEN) (10346) output terminal.
6. Remove wiring connector bracket.
7. Loosen the drive belt tensioner (6B209) and remove the drive belt (8620).
8. Remove generator brace (10B315) and bolt attaching generator to drive belt tensioner bracket.
9. Remove generator from the generator mounting bracket (10153).
Installation
1. Position generator on the generator mounting bracket.
2. Install the attaching bolts and tighten to 40-54 Nm (30-40 lb-ft).
3. Install the drive belt over generator pulley (10344).
4. Adjust the drive belt tensioner as outlined in Section 03-05.
5. Install wiring terminal and attaching nut on generator output terminal.
6. Install wiring connector bracket.
7. Install engine air cleaner intake tube.
8. Install snow/ice shield.
Nov 05, 2009 | 1995 Ford Aerostar
Broken belt tensioner. How to replace?
HI begin by disconnecting battery , remove alternator then remove the two heater hoses attach to tensioner bracket by removing the to front screws, you will lose coolant so put a pan on the bottom .Then remove bolts attached to tensioner bracket.it will require a little force to pull out yest make sure you got all the bolts out before applying force. Here is a picture tensioner and bracket assembly so you can see what bolts to remove. let me know how it turns out it is not so bad to do5e1c732.jpg
Sep 25, 2009 | 1998 Oldsmobile Regency
Serpentine belt diagram for 2003 chevy cavalier 2.2l ohc
That pulley is the tensioner pulley. It is either manual or automatic. If it is a manual tensioner, the bracket that it is attached to it should have a square hole located on it bracket somewhere. This whole will look inoculous, but will be offset from the pulley. If you have a 3/4" socket wrench, you'll notice it fits nicely into this hole.
You use this hole (and the wrench) to twist the whole bracket and apply tension while you tighten the bracket itself down.
An automatic tensioner will have a spring inside and would pretty much work by itself when a belt of the proper length is installed. Your Hanynes manual would have already alerted you to how to adjust an automatic tensioner.
I hope that helps.
BTW, the tensioner pully usually rests on the back (flat) side of the belt and has no device attached to it.
Aug 15, 2009 | 2003 Chevrolet Cavalier
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
