Question about Kenmore Dishwashers
Kenmore dishwasher (3384088). The quick rinse light is flashing
I have a kenmore dishwasher (3384088). The quick rinse light is flashing, there is water in the bottem of the washer and it will not run when I press start. What is the problem?
  • ajdunn10 Oct 11, 2009
    Thanks,
    The filter is cleaned and the pannel is dry, but still the quike rinse light is flashing and I can't select any other function or start the washer.
    What else can I try.
    thanks
    AJ
    President:
  • 2,187 Answers
In some cases this may have been caused by a stuck switch due to the accumulated moisture. When you open up the control panel, have the console removed. You should see holes present. Have dry compressed air GENTLY blown into the ready made holes.
The water that has accumulated may be caused by a clogged filter or bad drain or could be a residual of the flashing light issue and may be solved by the first trouble shooting step. If the first one does not solve it, inspect the internals of the unit there may be leaks somewhere,
Posted on Oct 11, 2009
  • Nicolo Carlo Parazo Oct 12, 2009
    try the first solution which is to open up the panel and have the console removed then gently have compressed air into the holes. This is a cheap fix that hopefully would clear out the buttons due to the accumulated moisture. This solves most similar cases and hopefully would resolve yours. Otherwise you may have to have the control circuit checked out.
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
I am trying to start a cyle and everytime i push the cycle button it does not light up and the quick rinse button comes on and flashes nothing works at all if i push heavy wash it comes on and nothing...
You haven't told me how many times the light flashes, but I will take a guess that this is an error code associated with the water entering the machine being too cool. I believe the machine expects the water to enter at 110 degrees F (43 Degrees C).
To clear the error, press "Heated Dry" then release, then press "Normal Wash" then release and repeat this sequence until all the lights on the machine go solid green. Once this happens, hit ""Cancel" and the machine will reset.
The fix for the root of the problem is to increase the temperature of the incoming water in future (Turn up your water heater temperature a little)
Jul 05, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Kenmore dishwasher 16764 Quick Rinse Light won't go off
you can try reseating the ribbon cable on the board however i strongly believe you have a stuck key and the key panel will need to be replaced.
Feb 02, 2009 | Kenmore 16764 Dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Blinking Quick Rinse
brent, After doing a little research on this model, I see that Sears put out a service flash concerning this problem. Dishwasher stops in mid cycle and one or more of the lights are flashing. SF22-715. The correction is to replace the existing board with an updated board that controls the line voltage better. Part number 8530928. You could be covered under this flash. The tech will have to eliminate the possibility of a stuck or shorted keypad which will cause this same effect. You can try to get this back in operation by pressing in this order: high temp wash-air dry-high temp wash-air dry. This will put it into a self test mode. Just let it run through if it works. If you don't have those keys try power scour-air dry-power scour-air dry. Catriver...post back.
Nov 19, 2006 | Kenmore 16639 Built-in Dishwasher
Under cycle setting the quick rinse light keeps flashing and dishwasher does not run.
Hey Jim, if your model starts with 665 there was a service flash on this unit concerning your problem. SF-22-715. Dishwasher stops in mid cycle. The control board was redesigned to eliminate this problem. The service flash states that if only one indicator light is blinking it's usually a stuck or shorted keypad. I would check with Sears and see if you are covered under this service flash. Catriver...post back.
Aug 28, 2006 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwashers Logo
326 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
