Take the Dakota to AutoZone to have the PCM scanned (free). They will give you the code and a print-out with an explanation. Have them reset the PCM.
Let us know what the codes are and a brief explanation of what is printed. We will advise you on the next step.
Well you can go to local part house kragan or somthing like that and i think amco dose it for free two
Got to an auto parts store and they will loan you a scanner. Scan it and then tell them the code and they can tell you what you need.
Check
engine light comes on and off, these are indication that there is some
error code stored in your vehicles ECM. The engine module computer
needs to be scanned. These will give the code and as per the error code the
further problem can be detected and confirmed. The engine light
indicator blinks or remains steady on dash when engine computer
noticed any problem with any engine electrically operated components.
For
more help, I suggest you to refer the help links provided below. These will let
you know more about which areas to look, check, when there is engine light
coming up on dash panel.
Click
the link below: -------
CHECK ENGINE LIGHT
http://alltypesofpartsreplacing.blogspot.com/2012/12/check-engine-lightengine-warning-light.html
Check Engine Light Reset Procedure?
http://whoisbyme.blogspot.in/2012/06/check-engine-light-reset-procedure.html
These will help.
Thanks.
Check
For
Click
http://whoisbyme.blogspot.in/2012/06/malfunction-indicator-light-on.html
http://howtobyme.blogspot.in/2012/02/check-power-train-message-with-orange.html
http://whatisbyme.blogspot.in/2012/05/2007-toyota-highlander-hybrid-yellow.html
http://whatisbyme.blogspot.in/2012/05/car-runs-fine-but-check-engine-light-is.html
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
http://schematicsdiagram.blogspot.com/2011/12/vehicle-smog-test-failed-due-to-no.html
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-check-engine-light-flashes.html
These
details will help.
Thanks.
Toyota Camry Check engine light flashes while
driving?
----------1999 Toyota Tacoma: Check Engine Light
Read Code P0171?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-tacoma-check-engine-light.html
2007 Toyota Highlander Hybrid: Yellow Check
Engine Light ON dash?
--------Check engine light with codes P2195 and
P2197?
---------Car Runs Fine But Check Engine light is ON?
----------After replacing throttle body the Check engine light starts
blinking?
http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
---------OBD Code is cleared but check engine light
will not RESET?
--------These will help.Thanks.
As per your problem,the check engine light comes on due to technical problems in your car.In this case i suggest you to click the link below :----Check Engine Light On car? http://schematicsdiagram.blogspot.com/2011/06/check-engine-light-on-car.html
------------Basically the computer needs to be scanned to retrieve the error codes stored in ECM.In this issue,i suggest you to click this link:----How to Read Codes from Check Engine Light? http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html----------After scan procedure you will get P4 digit error codes.If suppose you get this error codes,then click the link below,to know more about error codes:----
Check engine light with codes P2195 and P2197?http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
---------------There are many other reasons to for check engine light coming ON,i suggest you to click this link below and go through its troubleshooting procedure:---------Car jerks while going uphill and Check engine light is ON?http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
--------One more reason is as follows :----After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure?
http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
After replacing throttle body the Check engine light starts blinking?http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
This will help.Thanks.
This details will help you.Thanks.
