Used to be white lettering now top green bottom pink 60 inch rear projection 5 years old
  • SD Tech
    SD Tech May 11, 2010
    WHAT IS BRAND AND MODEL NUMBER? Does picture look 3d?
  • 336 Answers
Hi,do you hear buzzing ,whirling,or high pitch sounds?If you do it could be an issue with the color wheel.The Samsung BP96-00674A color wheels spin anywhere from 6,000 to 15,000 revolutions per minute (RPM’s)--It is one of the few consumable parts in your Samsung TV. The average life expectancy from our data logging shows the Samsung color wheels are fairly reliable with a MEAN average of 5-8 years But it could also be the Dmd board this is how it works: http://electronics.howstuffworks.com/dlp1.htm Baisclly the DMD board creates the images and colors through its chip that has 2 million pixels,when that chips goes out you'll see either lines ,pixelation and dicoloration.One simple way to see if it is the Dmd its to display menu if it's also appears distorted that will be what it is.
Posted on Sep 30, 2009
YOU CANN GREEN AND PINK SEPERATE
my t.v. turns off and on whatis the problem
Jan 28, 2009 | Philips 60P8341 60" Rear Projection...
Color seems to be pealing up from the bottom of screen
If the screen is bouncing...expanding/shrinking you need to get a repair kit from www.TvRepairKits.com
If your screen looks 3d in color, has a stationary bow, or if you can't adjust one or more colors from the "convergence" menu you need to buy a convergence repair kit. You can get one from the same site listed above.
Hope this Helps,
Nov 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Moel #60PP93 5217
You are having a convergence problem. It is the most common problem with all projection TVs. It needs professional repair.
C-Dog
Feb 10, 2008 | Philips Magnavox 9P6034C 60" Rear...
Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Panasonic pt51hx40b
If the bottom 8 inches of the screen is black then you likely have a failed part in the vertical output circuits. If you can still see video clear to the bottom, then your convergence IC's (IC7001 and 7002) may have taken a dump on you. Worst case would be a failure in one or more of the 3 yokes in the set that attach to the CRT's. If the sets less than 10 years old, it may be worth repairing. Otherwise, a nice NEW HDTV would be in order.
Jan 02, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Jan 05, 2007 | Philips 60PP9401 60" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
