Sensor for remote is not working on the tv
It seems the sensor on the tv is not working, therefore the remote does not work.
  • 8,457 Answers
Tries a little Alcahol with a Q tip clean the tv IR sensor,do the same to the remote and change batteries,tv sensor saldom broken,only remote all the time.Tries this Website 1-800-Remotes Factory Original for new remote get the exact or very close to the original.
Posted on Sep 30, 2009
The sensor on the TV for the remote control seems to have stopped working
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Good luck.
Jan 09, 2012 | Televison & Video
The remote control sensor on the TV has stopped working
Regards.
TV IS NOT RESPONDING TO REMOTE. I'VE CHANGED THE BATTERIES AND HAVE TRIED OTHER SAMSUNG REMOTES THAT WORK ON MY OTHER TVS. ANY SUGGESTIONS...
Sounds like problem is with TV. Make sure the remote sensor on the TV is not blocked, it is located at the lower right part of the front of the TV.
Dec 12, 2010 | Samsung BN5900696A Remote Control
TV LC32SB24U will not respond to the remote control. I check the remote signal using a camara cell phone by pointing the eye of the remote towards the lens of the cell phone camera. I press each button on...
Are you using a remote from a cable issued cablebox or the orginal remote? I noticed my cable company DVR remote stopped working when the OPC setting on the Picture menu of the TV was set to the 'ON' position. Once turned to the 'OFF' position it stopped the OPC feature from activating which seemed to interfere with the response of the remote for some reason.
Mar 22, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Cannot control tv with remote. took remote to my son's house and it worked his tv ok ( same model). Seems it might be a tv problem and not a remote problem. It happened about 3 months ago and then kinda...
the fault is from your the TV sensor. Your remote sensor cannot sense the TV sensor, that's why the remote or any other cannot control your TV.
So its a remote sensor problem.
Take care.
Mar 12, 2010 | LG 32LC2D Television
Panasonic 42 inch HD Plasma TV (2 years old) remote sensor
take your tv and remote to a technician to check on your emitting diode and a photo senser, both are working but not very sensitive. the components are not gone but about to go. if you remove a senser from tv it can not receive, so that senser is sensing some thing, also check an amplifier just after a senser plse do that.
Nov 16, 2008 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Remote Sensor on TV Doesn't Work and Can't Manually Adjust Menu
I just realized that there is no usb port on this tv. Called tech support at vizio since I'm still under warranty. They're sending a new remote. I know it's not the remote because neither the verizon nor the vizio remote works, although the vizio remote will intermittently work if I'm one foot away from the sensor on the tv and holding the remote on a downward angle. Tech support says they will send a new remote to rule that out before they send a tech over. I'll check the posts to see if you find a solution when I finally get the tech guy out here. If not, I'll let you know what he does.
Good luck.
Aug 04, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Remote Control not working for MW24FM3 Toshiba
I have the same problem with my unit. I use the original remote and my Tivo remote. Both stopped working at the same time. Ocassionally they will work for awhile then stop. They always both work or both don't. Therefore it must be the TV; likely the sensor or something connected to it. Sorry I don't have a solution. Guess I need to take it to the shop.
May 07, 2008 | Toshiba MW24FM3 24 in. TV/VCR/DVD Combo
Televison & Video Logo
575 people viewed this question
Top Televison & Video Experts
Electro Med Services...
