Question about LG RU-42PX10 42 in. HD-Ready Plasma Television
My HDTV has a black screen. Everything is normal except for a black screen. What can I do?
  • Richard Klein
    Richard Klein May 11, 2010
    Does this set have a video card that you can reinstall?
This may be a connection problem. Here is something to try:
Turn off your system and check the connection to the HDTV system and make sure the cables are plugged in correctly. Then check the connections from the HDTV to your Cable box or Receiver.
Then turn it back on and see if it comes up.
Good luck,
SH
Posted on Sep 30, 2009
My LG 47LN5400-UA flatscreen has a black screen, everything works fine except black screen, when I shine flashlight on screen I can see full color picture, I have replaced the power supply/LED board.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board
Mar 14, 2016 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
I have a Toshiba 51h83. Everything works fine except there is an issue where the colors are slightly lighter on both the left and right sides of the screen.
this is normal with rear projection tv's its from long usage when the tv isnt always in full screen mode. you can sometimes fix this by replacing the bulb/ or the color board for the projector. also you can replace the screen as it seems like it may also be do to image burn in if it wasnt always in full screen mode. (did this for my uncles Mitsubishi projection tv)
let me know if that helps!
Mar 16, 2011 | Toshiba 51H83 51" Rear Projection...
Wifes Acer laptop screen went black, power light is on, fan is running, but nothing comes up on the screen.... We're stumped...
If you reboot it and everything seems normal except there is no display, get a flashlight and examine the screen for a display with no backlight. Maybe it is just the back light power supply that has failed?
Hope that helps.
Jan 15, 2011 | Acer Computers & Internet
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
My Wii was connected to a normal-old TV and was in black and white. Okay, so I then tried to see if connecting it as a HDTV version would work (in the settings)....well, then everything turned into...
What happened when you selected HDTV is that you activated the output to the HDMI output. This turned off the regular connection. Press the power and reset button simultaneously when turning on the unit to return it to the factory default settings. Otherwise, you'll have to connect it to a HDTV with the optional cable to connect it (you'll have to purchase that as well) to go in and change the settings back.
Feb 06, 2010 | Nintendo Wii Console
My Samsung Flat screen TV
If everything is normal except the picture, the problem is the inverter board. It supplies the power for the backlight.
Jul 24, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Black and white format on 26" insignia hdtv (720p)
Go to Best Buy and see if they have your same Model on display and change the aspect ratio and see how it is. If it's normal there then to me it sounds like a software up-grade might be in order. It might just have a software glitch.
Mar 17, 2008 | Insignia LCDTV26 26 in. Television
Vertical black line
does this verticl line go all the way form top to bottom or is it about 5-7 in long in the center of the screen and does it some times change in color with the picture.
Aug 11, 2007 | Samsung HC-P4752W 47" Rear Projection...
LG RU-42PX10 42 in. HD-Ready Plasma Television Logo
330 people viewed this question
Computer Repairing
Computer Repairing
