Question about Cell Phones
Leak on plastic water line on fridge is there any compound that may fix it very small pin hole thanks jaj
  • 159 Answers
SOURCE: Small crack in rubber seal
the only way to fix it is to replace the bellows. tears are a common issue with front loading washers. Its not a hard job to replace but you may want to have it done for you because the wire and spring clamps can be hard to install.
Posted on Aug 07, 2007
docjohn174
  • 943 Answers
SOURCE: Water leak From Back Of Fridge
hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
Posted on Oct 16, 2008
  • 240 Answers
SOURCE: Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Posted on Mar 14, 2009
SOURCE: bosch fridge leaking water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I have the same problem,warranty just ran out but its been leaking on and off for ages,must be this model.This much Ive figured out,what happens is the drain hole gets blocked from ice freezing over the hole at the back of freezer, the drain water has to go somewhere, since it cant leak out of the drain hole where it suppose to it ends up pooling under the vege compartment before ending up on the kitchen floor.Now if this is your only problem,someone suggested to me to run a piece of copper wire from the defrost heater to the drain hole so no ice can build up there,hence no more leakage.To do this you'll have to take the back panel off and see for yourself,I did this and Im a novice.Make sure you turn off and unplug the fridge first and wait for it to defrost.
Now I think I have other things wrong with mine,after leakage problem the refrigeration compartment wont cool anymore but the freezer part remains working as usual.Ive nailed this down to one of the following not working... Thermostat / timer / defrost heater.So one or more of these needs replacing.Im just trying to look for a manual which shows the nuts and bolts or the refrigerator (not the "How to use" type manual which I have).
Posted on Apr 05, 2009
SOURCE: Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
Posted on May 13, 2009
Water leaks at bottom of fridge
The same thing happened to me then I noticed ice had formed at the bottom of our fridge. It was covering a drain hole so water was leaking out the front of fridge instead of going to the drain pan or wherever the hole goes. After I chipped out the ice and cleared the hole with warm water the leak stopped. I also fixed another leak coming from bottom of fridge caused by a loose brass connection on water line going to the door.
May 25, 2014 | Hotpoint HSS25GFP Side by Side...
Cu2026 not making much ice
Sometimes the water inlet gets clogged. This happens a lot if u are using well water. Take the water line loose from back of fridge. fold the tube to stop water from leaking on floor if it is a plastic tube. have a bucket handy and put line in bucket let the water flow. It should come hard and fast. If not go to water valve where it pirces the main water line. check the hole and make sure it is large enough to supply the water. I had to take a drill bit and make the hole a little larger. That fixed mine. If that is not the problem then I would replace water inlet valve on the fridge.
Mar 20, 2014 | Kitchen Appliances - Others
My side by side refigerator ge model TPX21PRDA is leaking fron underneath when the water line is turned on to the ice maker.....why and how to fix it.
I have found pin hole's in plastic water line. Pull out from wall and get a flashlight to see. Turn water
back on to find leak.
Feb 01, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Water squirts out the back of my Kitchen Aid Superba where the water line enters the fridge. This happens when the ice maker tries to fill with water.
make sure that the water supply line is tight. the line that comes from the wall should be copper or stainless steel braided line. if it is the clear plastic line get rid of it as it is more prone to kink and leak especially at the points where the connections are made... another thing to check is where the supply line connects to the frig.. that is the solinoid valve and on the top is a blue or clear plastic cap and somtimes they will crack or have a small pin hole in them and will spray a very fine stream of water that is hard to see but can be felt on your finger tip.. pull out the frig and empty the ice tray and put it back in and close the freezer door or drawer and wait for the ice maker to call for water and have a bright flashlight ready, when it calles for water you will only have about 5-7 seconds to see where the leak is so make sure to feel around as well.; if your are replacing the ice maker supply line from the wall to the frig make sure to not over tighten the connection to the frig because it may cause that plastic cap to crack....I hope this helps....
Nov 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Leak from bottom of fridge
Two things might be happening. One is the line to the fridge is leaking, this line come thru the floor or wall to the bottom and hooks up to a water valve, it may just need tightening. The other problem is you will have a hose that runs from the filter down in behind the crisper drawers to the bottom and coils up here to hold water for cold use. it then runs thru the bottom pan out to the front, to the bottom door hinge on the freezer side up the door to the dispencer. Check along the hose for a pin hole look at the bottom hinge area first, things bump into it here and can damage the plastic cover.
Jul 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
WATER PUDDLE ON FLOOR
no water will be coming from that line it is going to be a blocked drain line or a rust hole under where you can't see
Apr 17, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Our water line has a pin hole leak.
sure just get a plastic 1-4th in coupling to couple the two parts together and and cut out the section with the pinhole (Use plastic the brass ones do not work well on plastic)
Mar 25, 2009 | Electrolux Refrigerators
Water leaking
Hi
There are several things to check for: The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. Some fridge's have a humidity switch inside the fridge that should be turned on to prevent sweating on the center bar between the fridge and freezer section. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. A kit to repair a separated heat exchanger line, comes with instructions as well. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Please revert for any clarification.
A Fixya rating would be appreciated if you found this to be helpful.
Thanks
Rylee
Feb 16, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Frigidaire Side-By-Side Refrigerator Leaks Water on Floor
I don't have the same refrigerator, but had a similar issue with a GE. Melt the ice at the bottom of the freezer. I think the water comes from the auto defrost feature. There should be a hole at the back bottom of the freezer that water would go into, and run to an evaporator pan under the refrigerator. The tube may be blocked that allows this water to drain, so it is backing up in the bottom of the freezer, and overflowing through the front bottom of the freezer to your floor.
Sep 28, 2008 | Refrigerators
Cell Phones Logo
54 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
