Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Could you tell me where the take up reels are.I am looking to clean to sensors underneath.Thanks
  • Philips Master
  • 8,457 Answers
U mean VCR HEADS cleanning tape?Tries Amazon.com or Ebay.com.Buy Scoth brand the best,I use it alot about a decade ago.
Posted on Sep 30, 2009
How do play both sides if what looks like a reel to reel tape that has a side 1 and side 2 ? My Akai 1722II does not have auto reverse . Thanks
You take the spools off and put the right spool on the left and the left on the right.
The link also explains, but i started on reel to reel in the late 60s. :>)
how do play both sides if what looks like reel to reel tape Google Search
Good video here
Reel to Reel Basics
Apr 25, 2017 | Akai Audio Players & Recorders
How do I get my zebco to retrieve the line
Your reel has pickup pins on the spool that will guide the line onto the spool when you reel in.
Try holding gentle tension on the slack line just above your reel and start reeling in. If this does not work then remove the top cover of the reel and look to see if the line is tangled up on the inside around the center shaft underneath the pickup pin cover.
if this is the case, simply unscrew the pickup pin cover from the center shaft. It will be on the tight. Remove the tangled line and reassemble.
Sep 18, 2014 | Zebco 33 Platinum Spincast Reel, 5 Ball...
As I was cleaning my Zebco reel, a shiny piece fell out of it, and it looks almost like a piece of a puzzle. Can someone tell me what this piece out of my reel is and how I put it back together?
the shiney pc is the stop so your reel wont go in reverse.look at where the crank go's through the boby of the reel.there are little teeth on it.the little shiney pc =(reel stop) go'e in that little slot under the crank shaft.
Oct 28, 2009 | Sport & Outdoor - Others
Crank shaft sensor location.
Hey Terry,
You're camshaft positioning sensor wil be located on the end of your valve cover on the oposite end of the pulleys and gears. Look for plugs around that area that are right on the cylinder head underneath the valve cover. If you have any issues I can look further into it and take a picture if need be.
Apr 22, 2009 | 1999 Dodge Intrepid
Emerson EWV403 VHS VCR stops taping and powers off spontaneously
There are probably a few different ailments which can cause this. One is if something is afoul in tape transport. I'd think the problem would occur whether in record or playback however.
If the tape takeup reel drive is slipping, tape takeup might intermittently stop, and cause the machine to power off (this is to avoid spilling tape in the machine). With the cover off, insert a tape, hit play, and see if tape takeup is steady, especially nearer the end of the tape, when the right reel is filling up.
An associated problem is if the reel sensor is intermittent- this sensor tells the logic whether or not the takeup reel is turning- again, this is to avoid massive tape spillage and damage.
Another possibility is a dirty mode switch- this switch tells the logic circuitry what position the mechanicals are in. It is probably located on the underneath side of the deck. Sometimes it can be disassembled and cleaned with a cotton swab wetted with contact cleaner. Others must be replaced.
Hopefully this helps- perhaps another tech has a better solution too.
Nov 12, 2008 | Emerson EWV403 VHS VCR
Thread breakage sensor
Select in the main Futura menu Help->Machine setup Tutorial, lesson 10b, the balloon shows the proper position of the upper thread inside sensor checked area.
Sep 24, 2008 | Singer CE-100 Futura Computerized Sewing...
Cassette player problem
Sounds like the take-up reel isn't turning. Often the linkage for the take-up reel is used for both Play and Fast Forward. So test the Fast Forward.
I would look for a broken belt or slipping drive wheel. The fact that the tapes are unraveling tells me that the capstan is pulling the tape out of the feed reel.
Feb 09, 2008 | Audio Players & Recorders
Need a real trouble shooter
the take up reels on these are weak. I take them apart and stretch the spring. the left side of the cassette housing can become bent down fairly easy. you should be able to gently bent it back up. the reel table is on the right side looking down into the mechanism, may also need cleaning.
Sep 14, 2007 | Sony Handycam DCR-TRV250 Digital Camcorder
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
67 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
