Question about Lexmark X6170 All-In-One InkJet Printer
Lexmark 6100 series error message Prop Res DLL not loaded
I want to set my printer to another setting besides the manufacter setting. When I attempt to change the settings in print preferences I receive an error message
Prop Res DLL not loaded.
I have tried to uninstall then install the printer from disk.
I have downloaded print drivers from Lexmark and that did not fix the problem.
Any help is appreciated
    Sergeant:
  • 258 Answers
Download tatest driver sfrom lexmark and use revo to uninstall first
Posted on Apr 22, 2015
Ajkill
  • 2035 Answers
SOURCE: Lexmark 7350 all in one
Before you begin
To pinpoint the cause of the issue, please record answers to the following questions:
Can a fax be sent or received?
Can a fax be sent, but not received?
Has the fax function ever worked in the past?
Any error messages may also help to narrow down the cause of the issues.
Print out the following:
- a settings list to view the current fax settings
- a receive log if there are issues receiving faxes
- a send log if there are issues sending faxes
- an activity log if faxes cannot be sent or received.
Initial checks
If the fax option has worked in the past and does not do so now, check that the same connection is being used and that it still works.
Check to see if any configuration settings have been changed that could have affected the fax settings.
Faxes cannot be sent/received:
If you are using a digital line, you need an analog card, an ISDN adapter, or an ADSL filter in order to send faxes.
If a PBX is being used, an ISDN Adapter/ADSL filter will not be used as these are supplied within the system. (A PBX is normally used within a company to share a small number of public lines among a large number of private ones to save on cost.) For instructions on configuring the X6100 Series machine with a PBX, see How and When to Use the PBX Option.
Check the phone line (without the printer):
Test the line by connecting a phone directly into the phone port.
Check for a dialing tone.
If you cannot hear a dialing tone, try another phone cable. Once you can hear a dialing tone, you know that the phone port is live and working.
Make sure the RJ11 cable is not damaged.
Check that the printer is accessing the dialing tone correctly:
Press the Options button on the operator panel five times until ON HOOK DIAL is displayed.
Press Select. You should hear a dialing tone.
If you can't hear a dial tone, make sure that the speaker volume is set to High. (Go to Fax, press Options eight times until SPEAKER VOLUME is displayed, then use the plus or minus buttons to change the setting to HIGH. Press Select.)
If there is still no dial tone, unplug the power cable and the phone lead, then plug them back in and try again.
Faxes can be sent but not received:
Connect the Lexmark All-in-One directly to the phone port. IMPORTANT: Do NOT connect any phones to the EXT port.
Make sure the Fax receive mode is set to answer the fax after 3 rings. (Press the Fax button on the operator panel and then press Options three times until ANSWER FAX WHEN is displayed. Change the settings using the - or + buttons as appropriate.)
Faxes can be received but not sent:
Make sure that Country Code is set correctly:
Press the Fax button on the operator panel and then press Options 15 times until Advanced is displayed.
Press Select.
Press Options 13 times and then press the + or - button until the right country is displayed.
Press Select.
IMPORTANT! These tests must be carried out with NO EXTENSIONS, i.e. phones or answering machines, connected to the EXT port on the All-In-One.
Posted on Mar 11, 2008
Ajkill
  • 2035 Answers
SOURCE: Printer stays offline on Vista
To help you resolve this problem, try the suggestions below.
The Basics:
1. Check your cables and their connections. Reconnect the parallel or USB cable to the computer and to the printer. Make sure there is a direct connection, with no scanners, switchboxes, or hubs inline. Other devices can sometimes cause communication problems between the computer and printer. For more information on this issue, see 'Scanners and Other Devices' below.
2. Remove the power supply cord and reattach it to the printer. The printer should make a noise soon after the power cord is reattached. Note: This is a general diagnostic that seems to fix minor communication issues.
3. If you are using a parallel port, verify that your computer is set up for bi-directional communications. If bi-directional communication is not enabled on your computer, the parallel port mode setting in the computer CMOS setup will need to be set to either bi-directional or ECP. Do the following:
1. Right click on My Computer and select Properties.
2. Click Device Manager. You should see a section called Ports (COM & LPT). There should be a (+) sign to the left of that section.
3. Click on it, and look for ECP Printer Port (LPT1). You may need to contact your PC manufacturer if any of the following are true at this point:
* It does NOT say ECP in the description.
* There is no listing for Printer Port or any variation of'LPT.
* There are question marks or exclamation points next to the LPT1 port listing.
Let your PC manufacturer know what you are trying to accomplish and what you have done up to this point.
4. Go to Start, Settings, Printers. Right click on the Lexmark object and select Properties.
5. Click the Details tab.
6. Under Print to the following port, it should say LPT1 for parallel cables and USB Lexmark or USB00x (<x> = 1-9) for USB cables. You can change these values by clicking on the arrow and selecting a new value from the list. Click Apply, and OK.
If you are using a USB cable and the USB value is not in the list, try uninstalling and reinstalling the driver as detailed in your manual.
If you are using a parallel cable and do not see LPT1, you will need to ask your PC manufacturer to walk you through the process of turning your parallel port on. You will also need to make sure the Lexmark printer is set as default. If not, right click on it and select the default option.
7. If the printer does not work when connected directly to the computer's port and you have complied with the steps above, there may be a hardware problem. In this case you should perform a self-test on the printer. (Click Start a New Search above this solution and enter self test in the search field.)
Scanners or other sharing devices could cause communication problems.
* If you are using a parallel connection, please verify that your cables, scanner, or other sharing devices are IEEE-1284 compliant .
If you are using an USB connection, they need to be at least USB 1.0 compliant.
* If the printer prints normally without the scanner/sharing device and its cables, there might be a problem with the scanner/sharing device. Please contact the manufacturer for information on how to fix such issues.
Note: Although connecting devices through a scanner (or other sharing device) may work, we do not recommend or support the use of such devices as they can interfere with the signal strength that is sent to the printer. Please contact the manufacturer of the scanner/sharing device regarding communication issues for that specific device.
USB Issues:
2. Click Device Manager. Click on the plus (+) sign next to Universal Serial Bus Controllers. The host controller listed here is the software that runs your USB ports. It is linked to a chipset on the motherboard that requires frequent updates to satisfy the needs of newer products such as your printer.
3. Look at the name of the host controller. Some of the more common names are Ali, Intel, AMD, Via, and SIS. You will need to contact your PC manufacturer to get help updating these specific controllers to the newest driver set.
If YOU are the PC manufacturer, check the manual for your motherboard to find out who makes the chipset for the motherboard. Again, Ali, Intel, AMD, Via, and SIS are some of the more common manufacturers of chipsets.
4. Look for either Lexmark USB Printer or Other Devices in the Device Manager.
5. If you see anything with Lexmark..., click on the plus (+) sign to its left and look for Inkjet Color Printer below it.
6. If it is present, double-click on it. Tje next screen should report that the device is working properly.
7. If you see any question or exclamation marks listed in the Device Manager (small yellow icons next to the listings), double-click on those items to obtain information on what's wrong with the items. This information is useful for troubleshooting the system.
8. If not or there is nothing present, you will need to uninstall and reinstall the printer driver software, or download a newer version from our web site. Click here and follow the link to our Drivers & Downloads center.
It is also recommended that you connect your printer to a USB port that is hardwired or "part" of the motherboard. USB ports that are located in the front of the PC and those that are located in the expansion card slots may cause communication issues if used for printing. You should always try to use the USB slot that is located near your peripheral slots, i.e., your mouse, keyboard, parallel and serial ports.
Multiple PCs:
The printer cannot be connected to multiple PCs at the same time. This includes, but is not limited to, using both the USB and parallel ports of the printer and the use of switchboxes. The system board on the printer will get confused at multiple requests for status, even if one computer is off and the other is on.
Docking Stations:
If you are using a docking station, try using the printer with a different, standard computer with parallel equipment as a test. You may want to contact the manufacturer of your other device for information on the correct functioning of a pass-through device. If the printer does not function correctly when directly hooked to a computer, the hardware may be at fault and the printer will need to be run through the self-test.
Converters/Adapters:
Lexmark printers do not support USB/parallel adapters and will probably not work. Nor will any USB/Parallel constructed cables. Our printers require either an IEEE 1284 bi-directional parallel cable, or a USB v.1.0 or 2.0 A/B style cable. Some printers can only use the parallel cable, some can use only the USB, and some can use either one. However, Lexmark cannot support printers hooked up to computers with a cable that attempts to cross between parallel and USB platforms, as this will cause communication issues.
Software Interference:
A piece of software may be interfering with the printer's communication ability, or your computer may be experiencing a system resource problem. We can try to alleviate these issues by putting your computer into Selective Startup mode. This will prevent any software applications other than Windows from loading when the system starts. To do this:
1. Click Start, Run.
2. Type MSCONFIG on the Open line, then click OK.
3. When the System Configuration Utility opens, place the marker dot beside Selective Startup. Below that, deselect Load Startup Group Items. Then click Apply and OK. You will be prompted to restart the system.
4. When your system restarts, only the Windows operating system should be running. You should not see any icons in the lower right-hand corner of the screen, beside the clock.
5. Try your action again. If it works, the source of the problem was one (or more) of the applications that were loaded into memory.
6. You can return your system to its original configuration by clicking Start, Run, typing MSCONFIG and clicking OK. This time, select Normal Startup, click Apply and OK, and restart the computer.
Posted on Mar 15, 2008
Ajkill
  • 2035 Answers
SOURCE: Drivers won't download
Use this link to download: http://www.download.com/3120-20_4.html?tg=dl-20&qt=abby&tag=srch
Posted on Apr 03, 2008
JackHeath
  • 1049 Answers
SOURCE: Prop Res DLL window keeps
The printer driver is corrupted or additions associated with the printer are incompatible. Try printing from word to a PDF, MS Imager, or another printer. If you get the error you will need to look under tools > "templates and Addins" or "Options". More likely it is that printer only, in which case uninstall and reinstall the printer driver and software.
Posted on Aug 29, 2008
pineworks
  • 4041 Answers
SOURCE: lost disc to lexmark x75 printer. downloaded
Hi there It is the driver may have not got the DLL files in it could be missing if you want to try again,
You can download a driver Software from my website then you can use the driver to set your printer up.
Just click on this link and it will download for you, and it is best to save it on your desktop so you can find it.
This is for the Lexmark-X75-XP.exe Printer and will work for XP.
Link= http://www.4all2sell.com/driver/Lexmark-X75-XP.exe
Ones you have downloaded just double click and it will take you through the installing
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Posted on Mar 19, 2010
How let Lexmark S305 only use black cartridge to print black. Now the color cartridges getting empty by only printing black, and with "only use black ink" selected. (Besides that, the cartridge...
Please follow the steps below on how to print using black ink only on your Lexmark S305 printer:
For Windows:
  1. With your document/file open, click File.
  2. Click Print.
  3. Click Printing Preferences/ Properties.
  4. In the Lexmark S300 Series Printing Preferences window, select print using black ink only.
  5. Click OK to save the settings.
  6. Click Ok again to print your file.
For Mac operating system:
  2. Click Print.
  3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media in a drop down box and select print in black and white.
If you wish to set this as your default print setting, please follow steps below:
For Windows:
  1. Go to Control Panel.
  2. Open Printers and Faxes.
  3. Right-click on Lexmark S300 Series print object and click on Properties.
  4. In the Lexmark S300 Series Properties window, go to Advanced tab. Click on Printing Defaults.
  5. Under Ink Use, select Print using black ink only. Click OK.
  6. Click OK button in the Lexmark S300 Series Properties window to save the changes.
Your printer will print in black only the next time you send a print job to the printer.
For Mac:
  1. With the file (you wish to print) open, click File.
  2. Click Print.
  4. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Note: The 100 standard cartridges yield around 175 ISO Pages. You can also save on ink and stretch your ink investment if you use only 100XL high yield cartridges. These contain almost 3x as much ink as a standard cartridge for a small increment in price.
Aug 07, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
I have just purchased and installed a J3600 Officejet printer. How do I get it to orient the print for a #10 envelope, which has to be fed in lengthwise?
You'll have to choose "#10 Envelope" as your paper size in whatever program you are printing from.
Then pick "Landscape" in the print options menu when you go to print on the envelope.
Apr 15, 2008 | Office Equipment & Supplies
I have a Lexmark X364DN and would like to change the default paper tray for incoming faxes.
1- Go to Fax Settings menu
2- Under Fax settings menu, look for Fax Receive Settings
3- Under Fax Fax Receive Settings, look for Paper Source
4- Under Paper Source You should find three options: Auto (default), tray <x> (the tray number you want it to print from), or manual feed.
Change according to your preference.
Hope it helps!
Jun 21, 2011 | Lexmark X364dn All-In-One Laser Printer
Printer is paused alert ribbon out after scrolling out rolls of ribbon, any attempt to re-align ribbon failed so far. Which printing mode should I be? print jobs make attempt to print but goes back to...
Locate your printer driver under devices and printers Right click on it and select "Printing Preferences" Choose the "Advanced Setup" tab Change media type to "Thermal Transfer" Be sure that "use printer settings" is NOT selected at the top left Click OK and you should be good. Note that any labels created prior to this change will need to be changed inside each label under the label setup.
May 18, 2011 | Zebra S4M Thermal Label Printer
I have hp officejet pro 8500 wireless every time i try to print it want me to fax
Printing with HP Photosmart printers is controlled by the driver software that is installed during the printer driver installation. Changes to the printer preferences can be set and changed in the Preferences dialog box. Changing preferences from within a software application Preferences set from within a software application will only change settings for the application or the current document, depending upon the application. The methods of accessing the dialog box will differ, depending on the software program being used. One of the following methods will usually open the Preferences dialog box from within the application:
  • Click File , Print , then click the Preferences or Properties button.
  • Click File , Print Setup , then click the Preferences or Properties button.
  • Click File , Print , Setup , then click the Properties button.
  • Click Print , Properties , then click Printer Assistant .
Changing the default settings Preferences changed from within the printer driver will change the default settings for the printer. One of the following methods will open the printer driver Preferences dialog box:
  • Click the Taskbar Printer icon.
  • Right-click the applicable Photosmart icon in the Printers folder, then click Printer Preferences from the pop-up menu.
  • Right-click the applicable Photosmart icon in the Printers folder, click Properties from the pop-up menu, and then click the Printer Preferences button on the General tab.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 15, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Cannot change/ save two default settings on X6570 Lexmark printer
you can go to printers and faxes (XP) or printers (vista) in control panel Right click on the printer and click on properties. Go to advanced tab and click on printing defaults. It will pop up the printer printing preferences. choose the desired setting. To disable 2-sided printing, go to advanced tab in the preferences window and turn off the feature. Click ok to save all settings. Go back to general tab and click on printing preferences and set desired settings if there is a need. Click ok to save settings. Then, for all changes to take effect, click ok button on the lexmark 6500 series properties window. Try to print again. Hope this helps.
Feb 17, 2010 | Lexmark X6570 InkJet Printer
Prints backwards
You mean your printer prints from last page to first page, right?
Check your printer settings/preferences and change the page print order settings.
You can change the printer preferences from most Windows applications (click File/Print ..., select you printer, then click on Preferences).
You can also change the settings from Control Panel/Printers or else click Start/Settings/Printers, then select your printer icon and right click on it, then click on Properties and, under the 'General' tab click the printing preferences.
Sep 07, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Hp officejet pro l7680
To solve this problem, you need to set the mirror image to 'off' under the advanced tab of the printing defaults and under the advanced tab of the printing preferences buttons. We had this problem for some time and since doing the above this has stopped.
Steve
Oct 23, 2008 | HP Officejet Pro L7680 All-In-One Printer
How to?
that's in the settings panel, under printer settings..set it for greyscale
Aug 03, 2008 | Epson Stylus RX580 InkJet Photo Printer
Printing from PC
open up your printer properties in windows (for XP it's start->control panel->printers and faxes->right click your printer and click properties). Then go to device settings and the things you want to change should be readily available in this tab.
Jun 30, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Lexmark X6170 All-In-One InkJet Printer Logo
308 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
