Question about Maytag Washing Machines
What are the spec for R11 & R75 on a Maytag MAH4000AWW washer part # 22002989
5 Suggested Answers
SOURCE: Maytag Neptune MAH4000AWW
Solution Guy.......I found this very helpful. I'm just starting on may Neptune MAH4000AWW.
Posted on Apr 30, 2008
  • 5 Answers
if r 11 is bad you should really check the bearing on the tub you will probably find it to be bad or going bad causing the moter to pull more amps causing r 11 to burn out.
Posted on Jan 23, 2009
SOURCE: I have a burned out resister which I need to replace.
R11 = 3.9 K ohm 1/4 w If Q6 burned,change by NTE5657 ( 600v)
Posted on Jun 17, 2009
oldmanewtoys
  • 414 Answers
SOURCE: mah4000aww no door locked light
The lid/door safety switch needs replaced
Posted on Mar 08, 2010
Neptune front loader. doorlock light quit working. wont spin.
You will need to change the machine control board and door lock wax motor.
MAH3000AWW PART # 'S 22002988 AND 12002535
MAH4000AWW PART# 'S 22002989 AND 12002535
If yo look at your control board in the control panel you will find R11 burned.
Jun 10, 2011 | Maytag Washing Machines
Matag neptune front load washer MAH4000AWW tumbles but won't spin dry. I tried it with and without clothes in the wash.
Check if the "locked"or "door locked" light comes on. If it does not, you need to replace the wax motor in the door lock assembly and the machine control board, which is inside the control panel. The control board is expensive, so instead of buying the whole control board, if you're good in electronic repair and soldering, try checking ebay for the control board repair kit. Search for "MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT". It has all instructions how to do the repair. Good luck!
Jan 22, 2010 | Washing Machines
Washer does not drain. Checked r11 resistor
Unfortunately, you cant replace the resistor, you need to replace the board. The cause of the R11 resistor blowing, is the wax motor for the door lock assembly. When the wax motor shorts out, the surge blows the R11 resistor on the board, requiring you to replace the wax motor and an expensive board. Major enginering error by maytag. The board costs around $240 and the wax motor is around $15
Oct 16, 2009 | Maytag Neptune Washer
Door locks as it should, machine spin cycle will start, but will never reach full speed, pump drains all water out
Hi, this is an issue usually associated with a faulty door lock assy & machine control board, that' s the control in the console behind the timer. If you arr able to remove the control and visually inspect it great. Look for a resistor identified as "R11", if it looks burnt or disoloured badly (it should have stripes from left to right, gold, red, white, & orange). You'll need a new control #22002989. this is most common, but not exclusively the only possible fault, but a good place to start based on your symptoms. Hope that helps, good luck
Oct 03, 2009 | Maytag Washing Machines
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Jan 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Machine keeps tumbling after wash cycle is completed.
Make sure that the replacement R11 is in fact connected to pins 1 & 2 of the Q6 triac. If the copper trace on the backside is open on either leg of the R11 to the Q6 then the wax motor will stay energized and that will cause the tumbling after the wash cycle.
See www.neptunehelpsong.com for a new funny song that explains the Maytag Neptune door latch wax motor issue.
Jan 21, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Machine stops on it own
Take the board out and flip it over and check the r11 resistor. It is usually burned out.
Nov 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH4000AWW washer door will not unlock
no, the board and wax motor is one possible problem but more likely youll need the motor kit with spped control. even more expesive but prove to be a big problem with this washer
Nov 18, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
75 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
