Question about Canon PIXMA MP210 Photo All-In-One Printer
Printer i turned it on and tryed to print but paper does not feed .it starts to feed only on the right side then jams up
  • 4 more comments
  • E Roman Jan 09, 2008
    I also have the same problem. It was fine then all of a sudden it won't feed the paper . It only feeds on the right side and then jams up. I tried it with little paper and with a lot of paper. Regardless it doesn't feed the paper properly.
  • Anonymous Feb 03, 2008
    yep mine does this too. i had about 30 successful prints before it started doing this. ive tried pulling the paper to the left and using just one sheet or many and nothing helps :-( very disappointed.
  • the cats Mar 11, 2008
    i have this printer only a fews weeks and it the paper won't feed for me do anyone have a solution for this
  • Anonymous Mar 12, 2008
    Same as you. This is rubbish!
  • Anonymous Apr 16, 2008
    My printer is new and it's printer maybe 10 pages.  Now it grabs on the right and either stops with and E 3 error or it thinks the paper has been fed properly and prints on nothing.
  • Madtown Apr 16, 2008
    My new printer has printed maybe 10 pages no jams on right side (facing printer) 7 either shows n E 3 error msg or prints with no paper.  doesn't work with a single sheet or with several.
I followed the instructions to clean the paper feed roller ("b" setting of maintenance code) followed by the Bottom Plate cleaning procedure ("J" code). Out popped a piece of walnut!! (I was eating while reading my email lat night).  There were ink streaks on the backside of the paper so I ran about 6 sheets and all seems well.
I now have the paper feed tray covered with a cloth & keep the front one closed unless I print.
Madtown
Posted on Apr 16, 2008
I had exactly the same problem, printer virtually new, printed great for a couple of weeks, then today refused to take paper with E3 flashing. No apparent blockage - all looked clean, tried all the utilities, roller cleaning and plate cleaning, but wouldn't take paper!
Solved it by moving the paper size guide all the way to the left, then folding the top 20mm of a sheet of A4 over and loading it so fold is at the top facing you. This acts as a catcher for anything stuck in the printer. Hold the paper slightly crooked with the left side slightly further into the printer and press the copy button (with nothing in the scanner!). It should draw the paper in now (with some persuasion) and think it is printing (it's blank,of course). Check as the top of the sheet goes in that the fold is still tight and doesn't open up as it feeds in. Lo and behold, mine brought out a 5p piece - printer now prints perfectly!
Posted on Mar 20, 2008
Its waste cannon printer is very worst printer
i hav new one but it isnt work now
Posted on Mar 15, 2008
Mybe u put a lot of paper .try to put just one and place the paper holder to the left side of the paper
Posted on Jan 01, 2008
4 Suggested Answers
SOURCE: Paper feeding
Thank you, thank you, thank you!!!!!!!!
Posted on Oct 27, 2007
cabrooksjr
  • 13 Answers
SOURCE: Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
Posted on Jun 21, 2009
SOURCE: canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Posted on Jul 10, 2009
My Lexmark 4600 printer has a paper jam. do not know how to unjam it.
How to clear and avoid paper jams
Follow these instructions to remove and/or avoid paper jams and misfeeds in your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
Paper jam in the printer
Remove the paper manually
  1. Press pattlnk_10282008_1820-power-icon.gif to turn off the printer.
  2. Firmly grasp the paper, and gently pull it out.
  3. Press pattlnk_10282008_1820-power-icon.gif to turn the printer back on.
NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
Paper jam in the paper support
Paper or specialty media misfeeds
These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
Try one or more of the following:
Check paper condition
  • Use only new, unwrinkled paper.
Check paper loading
  • Load a smaller amount of paper into the printer.
  • Load paper with the print side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
Remove each page as it is printed
  • Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper guides
  • When using media less than 8.5 inches wide
  • To rest against the edges of the paper or media, making sure it does not buckle
Printer does not feed paper, envelopes, or specialty media
These are possible solutions. Try one or more of the following:
Check for paper jams
  • Check for and clear any paper jams. For more information, see "Paper jam in the printer" and "Paper jam in the paper support" above.
Check media loading
  • Verify that the specialty media is loaded correctly.
  • Try loading one page, envelope, or sheet of specialty media at a time.
Check printer default and pause settings
  1. Click:
    • In Windows XP (default Start menu): Start pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows XP (Classic Start menu): Start pattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows Vista (default Start Menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gifControl Panel pattlnk_10282008_1829-right-arrow.gif Printers (under Hardware and Sound).
    • In Windows Vista (Classic Start menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers.
  2. Double-click the print queue device.
  3. Click Printer.
    • Make sure no check mark appears next to Pause Printing.
    • If a check mark does not appear next to Set As Default Printer, you must select the print queue device for each file you want to print.
Banner paper jams
There are many possible solutions. Try one or more of the following:
Clear banner paper jams
  2. Remove the jammed banner paper from the printer.
Review banner printing checklist
  • Use only the number of sheets needed for the banner.
  • Select the following settings to enable the printer to feed paper continuously without jamming:
    1. With a document open, click File pattlnk_10282008_1829-right-arrow.gif Print.
    2. Click Properties, Preferences, Options, or Setup.
    3. Select the Paper Setup tab.
    4. From the Paper Size area, select Banner.
    5. Select Letter Banner or A4 Banner as the paper size.
    6. Select Portrait or Landscape.
    7. Click OK.
    8. Click OK or Print.
Regards,
Ron
Mar 26, 2011 | Lexmark 4600 Multi Function Printer Option...
Canon mx300 printer feeder pulls unevenly causing paper jam
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Paper feeds to the right and Jams
Sounds to me like there is something in the paper chanel, a staple, paper clip or something small enough to get in there. Have you tried turning the printer upside down and lightly tapping the side to see if anything falls out?
Mar 14, 2009 | Dell A940 All-In-One InkJet Printer
Paper keeps jamming
Its right most of printer has 2 or more paper feed but when its feed the path will be one path its one roller path ,therefor i think roller has problem ,clean it ..
Jan 25, 2009 | Office Equipment & Supplies
Lexmark z2300 printer won't pull in paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 03, 2009 | Lexmark Color JetPrinter Z23 InkJet
PAPER JAM
Nov 12, 2008 | HP Officejet 5610 All-In-One InkJet...
I replaced ink and paper..paper keeps jamming when printing and copying. after the replaced inl and paper, i was able to print with no problem however without warning iunable to print or copy without...
Oct 20, 2008 | Lexmark Office Equipment & Supplies
Paper will not feed properly/one side of paper not feeding in straight
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
542
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Paper will not feed into printer
Oct 17, 2007 | Lexmark X83 All-In-One InkJet Printer
Paper will not feed correctly, keeps jamming up.
There IS something stuck in the feed path. If the paper starts to feed and then crinkles on the feed side, there is an object stopping the paper moving forward.
Lay the machine on it's back and take a sheet of very stiff card (A5 size approx) and push it through the paper path in reverse. So start where the paper would normally exit and push the card in. You may need to lift the pinch rollers just behind the print head by hand to aid the card through. Keep the card to the side that would normally crinkle but beware of the paper sensor flag. If you force it you could break it off.
Once you get past the pinch rollers behind the print head, push a little further then start to move the card in and out but along the length of the rollers. You should find that sufficient to push out whatever is in the path and having the machine on it's back will help it fall clear of the feed mechanism.
If it does not fall out using this method you will have to remove the covers and try to remove the ASF to get at the object.
Oct 14, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
345 people viewed this question
old marine
old marine
